Question about IBM ThinkPad T40 2373 Notebook
How to use the S view port - switch monitor
I have a IMB laptop type 2373. I requestsing assistance in using the S view port. I need to make a presentation, however I do not know how to switch screen.
  • 35 Answers
Press the blue FN button and one of the F1-F12 buttons. It should show two screens. Also make sure you have changed the display settings in windows. Under the advanced Tab check the box that says "extend my desktop to this screen" after selecting the 2nd screen in the window above it.
Posted on Aug 19, 2008
Can i play the image which is Jpg format directly on projector saved in USB?
I started an answer to this post earlier, but my browser closed
Here we go-
Simple answer is yes, if your projector has a USB slot. If so, the ability to view it will be a choice in the projector's set up menu
If it does not have a USB slot, then it is still possible to view it using your computer
Step 1: turn off computer & projector, then get this type of cable (seen below)
Step 2: connect cable to the VGA ports on your projector & computer. On the computer, this is where your monitor us currently connected. It will only fit on the ports intended for this purpose, so don't worry about goofing it up
Step 3: turn both computer & projector on. Newer computers will recognize the connection automatically. For laptops, there will be a button to push (on the top row of keys usually). It looks like a monitor most times.
You may need to go into the projector's set up menu to specify which connection. It should say VGA. Select that and you will be able to project your computer/laptop screen.
Insert the USB media (thumb drive?) into the slot on the computer and on newer computers, a notice will appear asking you what you want to do with the newly inserted device. Select "view file/contents on drive", then choose the JPG file(s) you wish to view
Good luck & Let me know if you need further assistance
Nov 18, 2016 | Cameras
How to hook up another monitor to t42 2373 window 7 ultimate?
I take it you have changed your graphic cards settings? updated drivers?
Apr 09, 2014 | IBM 23738ZU ThinkPad T42 2373 - Pentium M...
Does Lenovo 3000 Y410 support dual monitors
Yes.
1) Laptop OFF, monitor OFF.
Connect a VGA monitor to the VGA port, on the back of the laptop.
The VGA port is on the right side, as you view the back of the laptop.
This is a basic example of a VGA cable, and a VGA port, (Connector),
http://en.wikipedia.org/wiki/VGA_connector
NOTE* Color does Not matter.
You can use a CRT monitor, (Looks like a small TV), or a flat LCD screen monitor if it has a VGA cable.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on.
By default the display should show on the external VGA monitor.
IF not;
Press, and hold down on the Fn key, and at the same time tap once on the F3 key.
No?
There are at least 3 display options;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and tap again on the F3 key.
(The Fn key is down at the bottom LEFT corner of the Keyboard.
The F3 key is at the top of the Keyboard.
The F3 key is the Display Toggle-Over key )
Need more information post in a Comment.
Regards,
joecoolvette
May 18, 2012 | Lenovo 3000 Y410 (59012354) PC Notebook
How to connect dual monitors to docking station
one monitor you have onto laptop, second monitor connect to laptop connector for external monitor and in menu Start - Settings - Setting panels - "Icon - Viewing" and for this dialog window select folder "Settings" and configure secondary monitor
Apr 21, 2012 | IBM ThinkPad T40p 2373 Notebook
Need ibm thinkpad t40 2373 bios password and bios circuit name
FOR IBM/LENOVO PASSWORD
Hello sir read these instruction. Solution for all IBM/Lenovo laptop
check this site... http://ja.axxs.net. you need to buy this device Key maker pro...
OR
there is one more way to break password for many laptop ..you need to made serial port or printer port and there is software for it ...
check this site http://www.lancos.com/prog.html Thanks
Dec 02, 2010 | IBM ThinkPad T40 2373 Notebook
I got black screen a few seconds after reboot my LENOVO type 0689 - 2BS, Laptop run normally without screen light, I need to flash screen in order to read it. I tried unplugging the battery and AC Adapter...
It seems to be an issue with the backlight of the notebook.Since we require to shine a flashlight on the screen to be able to view the screen,it has to be the backlight
Feb 28, 2010 | IBM ThinkPad T40 2373 Notebook
My imb t40 laptop keep getting a black screen if it get moved or bumped a lil
Your issue is Board Flex... The t40/t41 have a split mid section and over time the lifting of the laptop from the base will flex the motherboard which can create a short in the layers of the board, it can also lift the heatsink from the graphics chip which will trigger the thermal controller,
put pressure on the palmrest area to the left side of the touchpad.. then attempt to move the laptop.. see if it stops the shutting down
Nov 15, 2009 | IBM ThinkPad T40 2373 Notebook
Computer is on, black screen?
If you have an external monitor try hooking that up, if it works then either your LCD is bad orTry toggling the Fn + the function keys with a monitor on it You may have your output mode switch to the external port on your laptop.
If you power it on and you see nothing at all, not even the BIOS then your motherboard is toast
Nov 02, 2009 | IBM ThinkPad T40 2373 Notebook
IMB ThinkPad T40 wireless connection...
You need to go through the eternet port or even the usb port to access the internet..When online you can vist the manufactorors website and get all the drivers needed for the wireless adaptor...
Jan 03, 2008 | IBM ThinkPad T40 2373 Notebook
KVM Monitor resolution out of frequency and will not display
Restart your system in a VGA mode (you will find this below Safe Mode, by pressing F8 before windows is loading) This way yours screen resolution will be at the very low frequency then you can change it back to the resolution you like. Eg. 800x600 or 1024x768. Remember to keep your Screen refresh rate lower like 75Mhz
Oct 30, 2007 | Compaq (242697-001) 8-port KVM Switch
IBM ThinkPad T40 2373 Notebook Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
