Question about Sony PlayStation 2 (PS2) Console
Ps2 game won't spin
My cd won't spin
  • footballman Aug 22, 2008
    thanks the advise really helped now it works almost like new
  • 53 Answers
Now you can have some fun and take the PS2 apart which can be done and make sure the ribbon that powers the disc motor is hooked in correctly and risk the fact that you'll waste about an hour doin this or you're most likely gonna have to break down and get a new PS2 console. tell me if you need a walkthrough on taking the console apart.
Posted on Aug 19, 2008
    Problem Solver:
  • 37 Answers
Try clening it. Tilt the ps2 on it's side so that you can see the disc, then spin the disc manually . Now, turn on the ps2. If it doesn't work, get a new game.
PS2 PROBLEM! It destroys my CD-s and it cannot spin cd with full speed!
Ok, pirated or burned cd/dvd/games, not unlike the first versions of the psx or ps1, caused the motor to work excessively, causing quick wear and tear. I would replace the eye, and the motor as an assembly, if you have some parts just laying around. If you are thinking of buying them, it might be cheaper just to replace the system with the current 9x PS2 system. Good luck.
Apr 08, 2013 | Sony PlayStation 2 (PS2) Console
I want to play duplicate dvds on my ps2 but i am not able to do what should i do can i do it at home
  1. If you have backed up a game for ps2, you're going to need a mod chip or swap magic for your ps2 so it can read the disc, so first things first, BUY A MODIFICATION TOOL!!!
  2. 2You should try using Swap Magic, because it's the easiest, and you won't need to modify your PlayStation too much.
  3. 3But if you use SWAP MAGIC, you will also need a special mod chip, SLIDE TOOL, or a FLIP TOP COVER, you can learn more about those on the swapmagic website
  4. 4Read directions on the installation of mod chip, and swap magic before you do anything (you don't want to mess up, or else your ps2 won't work properly).
  5. 5Install your modchip/flip top cover/slide tool. (This is important, because it allows the disc to be removed and "swapped" without the PlayStation knowing).
  6. 6Follow directions that came with your swap magic discs, and you're basically ready to go!
  7. 7HOW TO USE SWAP MAGIC,Note you must have Swap magic 3.6 to boot on slimline ps2 and you need to do a none solder modding(no soldering)
Purchase a flip top (recommended). Let's assume you have the flip top and a copied ps2 game
  1. 1Now Insert the swap magic disc into the ps2,
  2. 2Press power on button until screens comes up.
    • With option that says load cd open the top cover of the flip top.
    • And take out the cd when it stops spinning.
  3. 3Now insert your Copied game and click Load CD.
  4. 4its that easy
May 30, 2011 | Video Game Consoles & Games
Ps2 wont SPIN disks it tries to read and spins for like 1sec PS2 SLIM
If it's having issues reading ANY kind of discs (CD's, DVD's, PS2 games) it might be due to a malfuctioning lense or a disk rotator motor issue.
Since it's agaisnt the PS2 TOS to modify or take apart your PS2 you should contact customer support or tech support with this issue.
If there's that option is not aviable you should try ordering the required parts online from different distribuitors:
Mar 05, 2011 | Sony PlayStation 2 Slimline Console
It wont spin the games
A known temporary fix for the PS2 was to turn the console upside down to see if it will still spin the cd's at all...
If this fails then you will need to have the cd drawer replaced, or just buy a new one :( unfortunately without opening the console yourself to check the cables are plugged in, that is the only solution i can give you.
The upside is that PS2's are now quite cheap and can be found easily at second hand dealers or trading stores like Game Traders.
Hope this helps... sorry for the bad news.
Nov 23, 2010 | Sony PlayStation 2 (PS2) Console
My ps2 Cant read my disc!
clean the disk with disk cleaner clean the lens of your ps2 with a cd cleaner meaning a cd with brushes on the other side of it or with some rubbing alcohol then it should let you read your games
Jun 19, 2009 | Sony PlayStation 2 (PS2) Console
Disc won't spin so I can't play the game/DVD/CD
replace the motor. The motor has burned out causing the disc not to spin.
Jan 20, 2009 | Sony PlayStation 2 (PS2) Console
Ps2 disc wont spin and laser wont come on
it seems there has been a malfunction within your CD Drive, this is what is causing the CD drive to not spin or read the disc. these problems can be only generally resolved by either getting the console repaired/replaced unfortunately.
The PS2 will still turn on and run because the CD Drive does not dictate whether the console works or not, but because the CD Drive is broken, you will not be able to play games or watch DVD Films unless you have the CD Drive Repaired.
Hope this Helps ?!
Oct 27, 2008 | Sony PlayStation 2 (PS2) Console
Won't work. disk won't turn
sounds like a faulty spindle. this is the part that spins your cd for the laser to read. if your using a fat ps2 its prolly the spindle. if your using a slim ps2 it could be the laser causing the problem not the spindle. the slim ps2 laser make the spindle work. if the laser isnt working right the cd might not spin or it might not spin fast enough or flat enough.
Mar 06, 2008 | Microsoft Xbox 360 Console
Can't play original playstation game on my ps2
Maybe the disk speed isn't set right, sometimes. Older PS1 games require a higher or lower spin speed than what you have set, try changing it to either high or low and see if that helps any. Also, have you checked the disk for scratches?
Aug 19, 2007 | Sony PlayStation 2 (PS2) Console
Slimline PS2 disc not spinning
my friend i have a ps2 that its cd does not rotate ( i open it completely ) and the lens is working the lens is producing a red ray and it is movinng up and down but just the cd motor doesnot rotate so i checked the smd fuses using my fluke dgital multimeter i found one that is open when i replace it the ps2 work perfectly fine for your information the smd fuses are marked ps1 ps2 ps3 ps4 etc
Apr 30, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation 2 (PS2) Console Logo
85 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
