Question about SanDisk Sansa e250 MP3 Player
Recordings from FM not showing on PC.
When I go into the sansa by itself it shows that I have recorded data from F.M. however when i try to access the files on my PC they don't show up in the folder. I have tried renaming the folders, changing which USB port that I am using and I have also tried accessing the files via winamp and windows media play and still nothing. Any ideas?
  • 8,596 Answers
They should be in the Voice folder
Posted on Sep 08, 2008
Problem to transfere recordings from sansa express to computer
the same problem with my sansa mp3 player is is showing me an mtp device but could not find any folder in pc
Nov 23, 2009 | SanDisk Sansa MP3 Player
How do I recover a recording deleted accidentally from Sansa e250
It is possible to recover your lost recordings.
First things first: DO NOT take any more recordings with the MP3 that you want to recover records from in case you may quite possibly ruin your chances of recovery.
Then Connect the MP3 to your computer as it should appear as a "Removable Drive" or put the card in a card reader attached to your PC.
Next, if you are comfortable with using a PC then you can download a data recovery utility that will recover your recordings with Wondershare Recovery Software from the following link:
Video Audio Photo Recovery (if you are running Windows OS)
Mac Data Recovery (from MacUpdate site)
Do NOT try & write anything back to your MP3 until you can recover your recordings safely!
May 10, 2009 | SanDisk Sansa e250 MP3 Player
Can not down load voice recording to computer: Sansa 280.
You can try few simple steps like changing the USB ports, turning off & turning on the mp3 player and then reconnecting it, and then changing the USB mode on device: Menu --> Settings --> USB mode: MSC or MTP
If these don't work, try the steps here: Sansa e250 Not Detected in PC
Feb 01, 2009 | SanDisk Sansa e250 MP3 Player
No sound for FM radio mode
The radio is weak on this device - try different areas of the house, and see if you can get reception on one good station. I have heard that the Sansa e200 series had the radio function ruined by a firmware upgrade, but it wouldn't apply to the Sansa Clip. As a last resort, you can reset all of your settings within the player itself- the user manual will show you how to do this.
-Tha Mp3 Doctor
Jan 08, 2009 | SanDisk Sansa Clip MP3 Player
How do you delete voice recordings?
Connect your sansa to the computer via usb. (assuming you have windows) Now go to "My Computer". If your sansa is in automatic mode, it should show up as "sansa c205". Double Click on that. Now double click on "internal memory". (If you don't have that, just skip it) Now double click on "recordings". Double click "Voice". Now a list of your recordings show up. Simply delete the ones you don't want, such as "001" and "002".
Hope this helps!
Jan 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e280 fm recordings
First, try to copy the files to your PC. Make sure you have a CD burning program and drive of some kind. WAV files are very large compared to Mp3 files, so you may be only to fit a few on an AUDIO CD. If you burn the WAV files to CD as a DATA CD, then you will be able to fit more files onto a single CD, but you will not be able to play that same CD in a CD player.
Feb 26, 2008 | SanDisk Sansa E280 MP3 Player
Recording to computer
Does it show up as a drive on your PC when you plug it into the USB drive of the PC? If so, you should just be able to access it like any other drive and drag/drop the recording files onto your PC.
Jan 24, 2008 | SanDisk Sansa c140 MP3 Player
Voice recorder
Just plug the USB connection to your PC and delete the Record folder from your PC for the drive that the Sansa shows up on your PC.
Aug 16, 2007 | SanDisk Sansa m240 MP3 Player
Fm Recordings
Ok, If you mean you have an MP3/4 Player and it has an FM Radio that you can record on air music etc, to ya MP3/4 player's memory, and if that Player shows up in My Computer as a "Removable Drive", it should be a fairly simple matter to find the files on the Player, possibly with an MP3 extension, and copy & paste to where ever you want..
Aug 04, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
Lost data
solution step 1 connect the device to your computer and check whether the computer shows any data if it shows one then try to access the player through the step2 computer if you cant access the contents in the player then right click on the dirve icon and select tools and make a backup of the disk and save it to your system step 3 now use the bundled software with you too accsees the player if you can do it now then you can copy the contents to the hard disk if step 1 is negative then all of your data have been permanatly erased and so then nothing can be done
Jul 09, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
