Question about Dryers
Kenwood dryer not heating up - Dryers
  • Anonymous Dec 09, 2008
    dryer not heating up problem
My dryer is not getting hot what do i do
Posted on Sep 17, 2008
    Genius:
  • 2,920 Answers
Your heating element is out
Posted on Aug 19, 2008
Kenwood KCD1W tumble dryer not heating up replaced element and all three stats still not getting hot ?
Check main cable connections and power from main circuit. Possible one leg is open because of circuit breaker defective, open circuit from breaker through connection on the back of the drier. Sometimes the connector internal at the power connection will fail (see second image).
Check Thermo-fuse. If this thermo-fuse fails it will need to be replaced. (see first image).
If only one leg that supplies 120 volts is powered then motor and controls can operate. the heater elements are the part of the dryer that requires the other leg for the 240.
Hope this helps?
Nov 29, 2016 | Dryers
How do I fix a drive belt to a kenwood KVT1W tumble dryer please
Hello Linda;
My name is Peter. I am a retired field service appliance technician.
Go into the following web link. It is not for a Kenwood but the base tasks are there. Whirlpool Kenmore Dryer Repair How to Remove and Replace Belt 341241
Jun 08, 2015 | Dryers
Kenwood 400 tumbles but not heating.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 07, 2011 | Dryers
Heat doesn't work. It is a gaz kenwood dryer
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Mar 05, 2011 | Kenmore Dryers
My kenwood dryer
check the heating element and limit switches
Sep 17, 2008 | Dryers
Kenwood KD-76F Turntable Problem
There is an adjustment in the postion sensor switch of the tone arm located under the support housing. BE VERY CAREFULL in lifting or fliping the unit over. If you can lock the arm in postion please do so before proceding. There may be some dust in a optical sensor or the postion sensor switch may be loose and just need repostioning to the correct location. If your not technicaly inclinded I suggest a strong blast of air in this area may solve your dilemma, possibilty hair dryer(NO HEAT), air compressor(max 20 to 40psi) or a good seat of lungs.
Jul 10, 2008 | Kenwood KD-291RC Turntable
Kenwood
replace both 30 amp fuses in you fuse box and try that.
Dec 23, 2007 | Dryers
Manual for KVT1W
http://www.espares.co.uk/parts/tumble-dryers/kenwood/kvt1w-1123-547-15000/p/1088/435/0/631602
Try this site and see if they can help you out. I would imagine that you are overseas somewhere, can find anything washer or dryer type for Kenwood here in the states. Let me know if they cant help you, will do a little more looking for you. JIM
Nov 21, 2007 | Dryers
Dryers Logo
967 people viewed this question
Top Dryers Experts
