Samsung tv model ct29f7sw.....no vertical deflection.
3 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: i have a problem in
The deflection board is part of the Main board and is not available---you do have an option---contact PTS Electronics--get a quote from them----they repair/rebuild all kinds of circuit boards---This set was made around 2002 and it is not unusual that boards are not available for it any more---someone in the chat should have known this and told you.
Let me know if you have questions or need any help.
SD TECH
Posted on Oct 03, 2009
  • 139 Answers
SOURCE: TV MODEL CS 2725R HAS NO VERTICAL DEFLECTION
DO YOU NEED TROUBLESHOOTING HELP. THERE ARE SEVERAL CAUSES, BUT I'D SAY CHECK FOR B+, REPLACE THE IC AND ANY CAPS THAT LOOK OVERHEATED
Posted on Dec 27, 2009
Vertical foldover on bottom of 32 inch samsung lcd tv about 3 inches across bottom of screen
usually on all image related problem on all LCD comes from faulty t-con board..but for sure try to play dvd movie to test if the problem is on tv/t-con...
Jul 18, 2012 | Televison & Video
No picture. Just a vertical line accross the screen.
When this kind of set comes in for this problem, it is typically caused by a leaky/intermittent diode D402, located next to the heat sink for the vertical deflection IC. I will typically also replace the vertical deflection IC at the same time, just to avoid repeat failures.
Jul 06, 2009 | Toshiba 32DF46 32" TV
How do you fix a white horizontal line across top of Orion TV?
Hello eatkinson,
This denotes a problem with the vertical deflection circuit. This is more then likely the result of the vertical coupling capacitor failing. You will need the schematic diagram of the TV to find the capacitor in question. it is located between the vertical output stage and the vertical deflection winding of the yoke transformer. In addition check the continuity of the vertical winding of the yoke transformer this can cause the same problem. In any event the problem is that the vertical deflection signal is not getting to the yoke transformer or the yoke transformer is malfunctioning.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 08, 2009 | Orion1934 19" TV
Screen Smaller on Orion1934" TV
Hello Falken94,
Your TV is losing what is called vertical deflection. This might be caused by the vertical coupling capacitor going bad, or by the vertical deflection coil on the yoke transformer going bad. In any case there is not enough vertical deflection signal getting for the vertical output section of your TV to the vertical coils on the yoke transformer. I would suggest that you get this looked at by a qualified TV technician, due to the nature of this problem.
I hope this helps,
Thank you,
Shuttle83
Jun 19, 2008 | Orion1934 19" TV
Vertical problem,
chek tje vertical deflection yoke winding and the socket. readjust the vertical height control.hope this will help.
Feb 05, 2008 | Samsung TXM3096WHF 30" TV
Samsung ck-5339zb TV
only horizontal line it is a vertical section failure. caution keep brightnenn as low as possible till it is rectified & you put on tv before it this just to avoid screen burn. solution 1 check for loose contact or crack print or loose deflection coil connector. 2 check supply to vertical section. 3 check vertical ic. 4 vertical (50)Hz signalto vertical section. good luck
Sep 27, 2007 | Samsung TXN3271HF 32" TV
Samsung syncmaster 204b
Yes. There is no vertical deflection. The circuit that controls vertical deflection is bad. This is an easy fix for a TV tech. Take it to the TV repair shop.
Dec 14, 2006 | Samsung SyncMaster 204B 20.1" LCD Monitor
Rear projection
That's a collapse of the vertical deflection. Need the model number to tell you what Ic controls the vertical in that unit - but I can tell you that it would't be all that expensive to repair... It's a common enough problem...
Have a great day!!
Bill
Dec 13, 2006 | Panasonic PT-53WX53 53" Rear Projection...
20 inch T.V.
You have a bad vertical output IC, or the sweep power supply that drives the IC is bad. Your going to need the service schematic diagram and the know how to fix solid state electronics.
Sep 01, 2006 | Durabrand DWT1905 TV
replace vertical out deflection ic
Aug 19, 2006 | Jensen J50-MCTV Television
Televison & Video Logo
154 people viewed this question
Top Televison & Video Experts
Electro Med Services...
