Question about Acer Aspire 5100 Notebook
How to onnect burner?
How do i connect the built in burner?? i dont know how it got disconnected.
  • 476 Answers
Normally there is a slot and you push it in until it clicks into place.
Then to hold in place there is normally a screw,
that is acessible from the bottom that holds everything together.
Quite posible there is a screw under the keyboard too
Apart from that its a software thing.
Once fixed in place reboot and try use the drive,
if it don't work then update drivers and try again
It should auto recognise,
Let me know of your outcome thanks
Misterdj
Posted on Aug 19, 2008
Viking grill burner low flame
If this burner has tube type, You can loosen a screw in the front of burner and slide open air rater vent just a little just make sure not to open to far. blue-ish/orange flame is what your looking for
Apr 10, 2015 | Viking 500 Series VGBQ53002RELSS 30"...
I want to install it in my coputer but dont I dont have a disk, what can I do?
There is no need to install any software before/after connecting the LiteOn device,
because Windows XP/Vista/7 already contain the necessary device-drivers.
So, just connect it, and restart Windows, and it will be ready-to-use.
Windows Media Player can be used to play DVD-movies,
and Windows has built-in software to write onto CD-recordable disks.
Feb 19, 2011 | Lite On LTC-48161H CD-RW/DVD-ROM Burner
My Weber Genesis Silver only lights on the first burner. The second and third burner are not lighting.
Close the propane tank valve and disconnect the hose/regulator from the tank. Reconnect the propane tank and very slowly open the tank valve. You may have opened the valve too fast causing the built-in excess flow to close to a trickle. If you still have issues, let me know and I'll dig deeper. Douglas
Oct 08, 2010 | Weber Genesis Silver A Grill
Ancient (1971) Frigidaire Cookmaster electric Compact 30 Range/Oven, model number RBG-533N, has two surface mounted red indicator lamps; one for the oven & one for the burners. The surface burner...
The stove has 4 burner switches with a # 2 terminal on each switch. This contact is similiar on all four switches. One of the switches # 2 contact is stuck. The burner switch should disconnect both legs of the 240 volt circuit, one leg through the # 2 terminal and one leg through the thermostat built into the burner switch. Disconnect the pilot lamp wire on each switch unti the light goes off and then replace that burner switch. This should correct the problem
phucks001@horrycountyschools.net
Oct 08, 2010 | Frigidaire Kitchen Ranges
No flames coming through the burners?
Many newer grills have a safety feature built in where the valve will not
allow gas to flow if the burner valve is in ON position when the valve on
the tank is opened.
Try this - Shut of all valves, disconnect and then re-connect hose to tank,
turn on valve above LP tank, THEN turn on burner valve, light w/ spark or
match...
This feature can be really frustrating if you don't know it is in
operation...
Sep 07, 2010 | Char-Broil Professional Series Grill
This si the second time I have had a problem when I changed tanks. It started working the first time but not this time. The tank valve is open and the pressure guage is in the green, until you tirn on...
the tank is opened.
match...
operation...
Sep 06, 2010 | Brinkmann Charmglow Stainless Steel LP...
Fail to connect with internet
Pls check the internet settings you receive from other service providers . Sometimes it happens that service providers dont have requested settings for the phone. First check if your service providers are supporting internet settings for your phone.
Jul 10, 2009 | Samsung Cell Phones
When I turn on my computer I getting no signal to the monitor.
I connect my monitor to my computer and I recieve no signal but my computer screen work just the other day, this problem come about when I disconnected my monitor to view on another PC. And now I rec onnect it to my computer and I don't get any signal.
Dec 28, 2008 | Acer AL1916W 19" LCD Monitor
Amp
i dont know how my brand new 80W speakers go onnected..Where can I find the setup for the speaker andsome easy crash course..
Jul 04, 2008 | Audio Players & Recorders
(2) front Burner igniters on my new Matag 30" Cooktop continue to click
Sounds like water got into one of the switches. This usually happens when you wash the knobs. Water stays in the holes and runs down the shaft when replaced. Maytag has issued a recall on some stoves because this can be a fire hazard. UNPLUG THE COOKTOP UNTIL THIS IS FIXED!!!!!!!!! This has happened to me with a whirlpool unit and it tripped a breaker and shot sparks across the kitchen. First go to Maytags web site and see if yours has a recall. If so Maytag will fix it free. While you are waiting leave stove unplugged and light with a match. If you need to fix this yourself disconnect the wires from the two switches this should stop the sparking. Connect one switch at a time and see which switch is bad. Most of the time the electric part of the gas valve can be replaced seperately. and you can do this yourself. If you must actually disconnect a gas pipe unless you really know what you are doing call for service.
May 15, 2008 | Maytag 30" Built-In Gas Cooktop - White
Acer Aspire 5100 Notebook Logo
22 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
