Question about Siemens SpeedStream 4200 (13A4200001) Bridge
Utorrent port forwarding
I have done everything asked in forwarding my port correctly for u torrent though i still have the orange triangle indicating that i have not properly forwarded my port
i dont know what else to do
please help
When ya say done everything what ya mean bud????
Posted on Sep 29, 2008
Iv got a BT home hub 2 cant get conections for utorrent even though opened firewalls
There are ISPs that block utorrent. I found this explanation of how to do port forwarding on the BT home hub, though: http://portforward.com/english/routers/port_forwarding/BT/BTHomeHub/Utorrent.htm
So, all I can suggest is to open the ports on your home hub as suggested above and to connect your computer straight to your home hub rather than to your CWR-854 (unless you actually have no such router and just picked that to ask the question under).
It is possible that someone has decided that you should not use torrents (they slow down everyone because they actually have the nerve to use the internet) and they are associated with thieves. Not to mention that there are tons of legit uses for them,
This could be someone in your ISP or your house. So do you have access to everything? You can poke around with telnet - can you access the ports on the other systems that utorrent accesses to make itself part of the network of systems that are downloading and sharing the torrent?
But if one knows the ports it is easy to block torrent.
If you have multiple routers that do nat, the home hub has to forward to your router, not to your system. So if your router is 192.168.3.12 and your system is 192.168.5.6, the BT home hub has to forward to the port on your router, on 192.168.3.12 , and your router has to forward to your system on 192.168.5.6. If the home hub tries to forward directly to your system (if you have multiple routers, which you might have because of the way you asked your question) then it won't work since your router hides 192.168.5.6.
Jan 09, 2010 | Cnet CWR-854 Router
I need to open a port to use utorrent
first u download a software called ultra surf from anywhere on the net...then this software will search for most suitable port and it will open it for u...
OR
simply u can change the port no. between ' 6880-6889 ' in the preference option in utorrent....I think this will solve ur prob...KSHITIJ
Jun 17, 2009 | D-Link GamerLounge DGL-4300 Router...
Utorrent port not working
Here is a great website: http://portforward.com/routers.htm
Get your model number of your router/modem, and find it on the website list, then it gives you the instructions on how to foward ports.
Hope that helps.
Jan 02, 2009 | D-Link DSL-504T Router
Utorrent
yes that indicates that there are no incoming connections..when u click on the triangle you come to an option that says to check if port is forwarded properly and to configure the connection speeds..
i am a regular u torrent user and my port is never forwarded correctly..despite the orange triangle i get very good download speeds..a trick i use is to use the"force start" option on the downloads..right click on a downloading torrent and use force start option..i also noticed that over time the triangle becomes green..hope it helps!
Oct 31, 2008 | Enterasys Distributed Forwarding Engine...
It doesn't need to be port forwarded unless it is not downloading. But if you must, check portforward.com for instructions specific to your router.
Aug 14, 2008 | Enterasys Distributed Forwarding Engine...
Utorrent. the port problem had been solved. but the connection is still yellow
please check if the port allocated for u-torrent is port-forwarded properly..also check you have assinged a unique port number for u-torrent program..go to options tab in u-torrent and speed guide options in it and check the assinged port number!..or u can visit www.port-forward.com to port forward for the u-torrent!..thank you !!..
Jun 17, 2008 | Microsoft Windows Vista Ultimate Edition
Problem downloading a torrent file
which torrent software is it?
try with utorrent its great and it works good
Jun 14, 2008 | Microsoft Windows Vista Ultimate Edition
Cant get decent speeds from u torrent
I recommend checking out http://portforward.com/english/routers/port_forwarding/Belkin/F5D7230-4/eMule.htm
This is a great tutorial on configuring port forwarding on your particular router. This example is for emule but it will be very similar to uTorrent. You will want to determine what port uTorrent is configured to send data on and use that accordingly.
Jacob
Mar 18, 2008 | Belkin (F5D7230-4) Router (587009)
Port Forwarding
First off, the have the wrong IP address set for the router. The 10.0.0.138 address they are shopwing you would be replaced by 192.168.0.1 (default for D-Link). You can always tell by going to the command prompt (start/run/cmd) then type "ipconfig". This will tell you the the default gateway (router) and the ip address of your computer. The 255.255.255.0 is your subnet mask. Now try following those very confusing directions.
In the D-link, forward ports in the DMZ or RIP section of the router.
Personally, I don't know Utorrent and would not open a hole in my firewall for it. Bit Torrent is the original and most trustworthy of the 'torrent" programs.
Dec 30, 2007 | D-Link ADSL2/2+ Modem/Wireless Router...
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
264 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
