Question about Sony Playstation 3 (PS3) Console
European PS3 now in the U.S.
Hello.
I have a 220-240V European PAL 60 GB PS3 which I have brought over to the U.S.
I've got the step-up (Voltage) transformer which is needed so it can operate here now.. power switches on fine and machine seems o.k.
I don't get any picture on my Samsung HD TV and I've tried all the ways possible to connect it with HDMI cables and the yellow, white and red cords. At best, I can get sound (no picture) through the TV when I have the AUX (yellow, white and red) cables going from my PS3 to a cable box- I have then an HDMI cable connecting the cable receiver to the television.
Why on earth is this not working for me and so difficult- I've spent all day trying to work this out and scanning the interent for solutions..
Thanks in advance for your gracious gesture of helping me.
    Sergeant:
    Champion:
  • 236 Answers
You need a TV that supports PAL.
Or, if you want to keep your TV, you need a PAL to NTSC converter.
Here's a list of converters.
Good luck with your PS3.
Posted on Aug 19, 2008
How do i make it PAL 60 rather then PAL 50?
PAL 50 is the european broadcast standard, as I am sure you are aware.
There is no "PAL 60" - If you are trying to set up for use in the United States, the correct setting is NTSC.
Not all sets will allow you to change from one broadcast format to the other. You must consult your manual to see if it is capable to set it up for NTSC. If so, follow the instructions and the set up menu.
One very important item.... US households are wired to run off of 110 to120 volt, 60 hz AC. The European standard is 220 volt, 50 hz AC. You must check your manual to see how to set the correct input voltage.... some sets can configure themselves automatically, and some have a small "slider" switch to change from 220 to 115 (or it may say 110 or 120, but they all serve the same purpose). Make sure you do this BEFORE powering up a European set in the US!
Feb 13, 2011 | Televison & Video
BOUGHT A TV I N THE USA BROUGHT TO SWEDEN I CAN ONLY SEE THE HEADS OF THE TV SOUNDS OK BUT IT LOOKS LIKE A LITTLE ISLAND IN THE MIDDLE OF IT CAN,T PULL U MINU CAN IT BE FIXED
I don't know a whole lot about TV's but I don't think TV's purchased in the USA will work in Sweden unless they were designed specifically for overseas use. In North America we use a system called NTSC and I believe that in Sweden you use PAL. If the TV has the ability to change the setting with a switch you should set it to PAL.
I assume you are running it off of a step-down transformer to cut the voltage (if you don't want it to blow). In North America TV sets are designed for 110 volts. Don't you have 220 there?
You may also have to change the hertz rate to the proper rate there too I believe (forget what it is -- 50 to 60 or vice versa. You may have to call up a technician there ask, or somebody on this site might know). Some TV's simply have a switch on the back that will enable you to do this if they have been designed for both North American and European use.
May 12, 2010 | ViewSonic Tablets & eReaders
Will a swiss or german ps3 game work on a US ps3 platform
No European games are in PAL format. US is NTSC. Sorry. Hope this helps.
Nov 20, 2009 | Sony Playstation 3 (PS3) Console
How do i get ps2 games to play on my ps3
The only way how to play PS2 games on PS3 is to have the correct version of the console. Either your Playstation 3 can play PS and PS2 games or it can't, and there's not much to do about it. Most of the PS3 models simply cannot play older titles as they lack the necessary hardware and firmware. However, a few models do have backwards compatibility. The 20 Gb, 60 Gb, and original 80 Gb models all have backwards compatibility, either through hardware or software emulation. The other models lack backwards compatibility, so even knowing how to play PS2 games on PS3 won't help you out much here.
Aug 18, 2009 | Sony PlayStation® 3 (80GB) Console
Can I unlock a US PS3 to play European DVDs in PAL?
Go on youtube and punch in PS3 hack and see what comes up.
Jul 09, 2009 | Sony Playstation 3 (PS3) Console
SR573... Does it support NTSC/PAL?.
There's no mention of either NTSC or PAL in any spec sheet.
This link leads to Onkyo and the rear view of the amp lacks the voltage selector.
http://www.onkyousa.com/model.cfm?m=TX-SR573&class=Receiver&p=s
The manual for the similar model SR575 says the North American model does not have the voltage selector. Too bad. Under the general specs for the variants of this family of receivers they list the following power specs. I have no idea where you have to go to buy one from the "Others" group.
Power Supply North American: AC 120 V, 60 Hz
European: AC 230 V, 50 Hz
Others: AC 120/220-240 V, 50/60 Hz
AC 220 V, 50/60 Hz
Some aliases for the SR575=
TX-SR505
TX-SR505E
TX-SR8550
TX-SR575
You could do what I did over 30 years ago. Join the Army, go overseas and buy one in the PX. Every HiFi product we bought in the PX in the 70's had the dual voltage feature.
Apr 07, 2009 | Onkyo TX-SR573 Receiver
Looking for a PS3 60GB model motherboard for replacement
You can't just replace the motherboard, the blu-ray is tied to the motherboard number, so if you put in a new motherboard it won't read blu-ray games anymore. Check http://www.edepot.com/playstation3.html to find out how it is tied to the motherboard.
Sep 11, 2008 | Sony PlayStation® 3 (60 GB) Console
MY japoneese ps3
The pal ps2 games and dvds will not play on a Japanese ps3 due to region coding. You can play all ps3 games and blu ray films because they do not use region coding. Some games will also play differently on a ps3, for example, Uncharted: Drakes Fortune (I highly recommend the game) will not have any blood on a Japanese ps3. The region coding feature can not be changed/modified. I would recommend returning Japanese ps3 and purchasing a European model instead if that is possible. Bon chance.
Dec 05, 2007 | Sony PlayStation® 3 (60 GB) Console
PS3 purchase from USA
I can answer the first part of the que. They don't make a 60 gb anymore, they only make 40gb,and 80gb, the 80gb is the only backward capable!
Oct 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
