Question about Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport WSW8300 Washer - Thumping noise by extractor pump at the end of wash and rinse cycles for several minutes.
At the end of the wash cycle and both rinse cycles, the washer pump extracts the water from the machine, but then continues to try and pump water for several minutes, even though it is empty. I believe the extractor pump is now pumping air and it makes a horrible thumping noise that continues for several minutes at the end of each cycle. The washer is located in our kitchen and I have to leave the room because of the noise. I had the unit replaced shortly after I purchased it, and the second one made the same noise. I had two repairmen come who both initially thought the unit had a problem, but after discussing it with the Whirlpool technical staff, they told me it was 'normal'. As an engineer, I can't believe the unit could have been designed this way! Can you help? Thanks.
  • chas127 Aug 19, 2008
    To jsrock516 - that's pretty much it in a nutshell. I guess we just have to live with it!!
  • 5,911 Answers
Believe it or not, this is normal. The pump runs until the water is extracted and begins to cavitate as it pumps air. These pumps will make some noise. As long as it is draining properly, and your clothes are coming out pretty dry, I would not replace it. However, if you are experiencing louder than usual noises, you may have something caught in the pump reservoir. You do have to clean the pump occasionally. The following link explains how:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
A new drain pump will run you in the neighborhood of about $70 to $80. You can order them online at searspartsdirect.com. If you've already had two repairmen look at it, replaced the unit once and it did the same thing, AND had the Whirlpool staff tell you this is normal, you may want to consider that there's nothing wrong with your unit. I know its hard to believe that someone would design something this way, but the manufacturers aren't perfect. I've worked on these units numerous times with similar problems and had to either tell the customer that there was nothing wrong with the unit and basically deal with the noise, or replaced the pump at their persistence. I just thought they were throwing their money away on something that probably will not change. I hope this gives you some answers, and hope it will help you in some way.
Posted on Aug 19, 2008
SOURCE:
Why does it beep through the entire. Wash cycle. No code showing.
Whirlpool Duet GHW9150P Front Load Washer Beeping ...
www.fixya.com > ... > Whirlpool Duet GHW9150P Front Load Washer
Question about Whirlpool duet Washing Machines ... my front loader is not workingwhirlpool washer flashes and beeps will not finish a cycle 1 Beep/E10--Error: Water... It beeps through the wash and rinse cycle every couple of minutes. ... Cycle signal which tells you that the cycle is complete beeps through the entire cycle.
[PDF]front-loading automatic washer use and care ... - Whirlpool
www.whirlpool.com/.../U...
Translate this page Whirlpool Home AppliancesWash. This is the main portion of the wash cycle. You will see the washer tumble the load. ... Spin cycle. If the laundry is still wet, take half of the load out of the washer and try again. .... Using recommended AFFRESH® washer cleaner, add.
[PDF]DISHWASHER USER INSTRUCTIONS - Whirlpool
https://www.whirlpool.co...
Translate this page Whirlpool Home AppliancesThe first cycle using the sensor will run longer to calibrate the optical sensor. Rinse Aid. Using rinse aid will optimize your drying and wash performance. This dishwasher is ...... laundry detergent, hand soap, or dish detergent for hand washing .... models) you will experience more starts and stops throughout the entire cycle.
Continuous Beeping - Whirlpool Duet Sport Washer - The ...
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 25, 2016 | Whirlpool Washing Machines
Whirlpool Duet Sport won't work past the wash cycle. It's full of water and will not drain.
check the pump filter it could be blocked or the drain hose try blowing down the drain hose to see if its clear you should hear a bubbling sound if not its blocked
Nov 27, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
We have a whirlpool duet sport washer, and the Rinse in the rinse cycle isnt going on. It fills with water for the wash cycle but nothing for the rinse, any help?
They have a double or is some case triple solinoid valve. Your rinse sounds like it maybe faulty. You need to find a spare parts place and order one for your particular model. Hope this helps
Feb 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport Washer Does Not Work, Door Lock is stuck
have you checked the belt to see if it came off or maybe broke off,if its not the belt then maybe the motor whent bad or needs reset,that just some of the possibilitys you might want to check,some motors have a reset butten on thim
Mar 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet. Strange noise and F 02 error code
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Feb 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Front Load Duet Dryer
Holding the End Cycle button for a few seconds worked! Yes
Aug 20, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washer makes loud thumping after finished spin cycle
I replaced the drive block and it solved my problem. (thumping noise at the end of spin cycle) Easy repair. Videos on utube show all the steps.
Jun 07, 2006 | Whirlpool LSR7333 Top Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
650 people viewed this question
Marvin
Marvin
Gerry Harvey
Gerry Harvey
jimorris77
