Question about Linksys Computers & Internet
Cannot get Internet connection with my new Linksys WRT310N wireless router
I just replaced my old G Linksys router by a new WRT310N and configured it with same settings. Unfort. I cannot get my Internet connection. I'm using cable modem from my ISP.
  • Anonymous Mar 09, 2009
    I cannot access linksys wrt310n configeration screen.
  • 35 Answers
Power cycle modem and router. Check if getting wan ip address on router. I yes. Enter static DNS on router or on computer
Posted on Aug 19, 2008
I can wire connect but to the internet through the router, but the wireless connection is not working anymore
Is your wireless adapter enabled on the device you are trying to connect to ( is it a laptop)? Do you see your wireless SSID when you search for Available Wireless Networks? shut down the laptop and start up the laptop. reaquire the signal.
Nov 07, 2012 | Linksys WRT310N Wireless Router
Driver Linksys WRT310N Wireless Router
driver download link : has all the instructions you need. Should fix most problems.
1 direct link :
http://www.userdrivers.com/LAN-Network-Adapter/Linksys-Router-Upgrade-Firmware-1-255/
2 scanner :
http://www.userdrivers.com/LAN-Network-Adapter/Linksys-WRT310N-Wireless-N-Gigabit-Router-Firmware-Update-1-0-07/
May 10, 2011 | Computers & Internet
We have windows 7 ultimate on a hp pavilion du 7 laptop, coupled to a linksys wr310n router.It was working fine until our c drive crashed & had to replace , now we can't get the router to work , driver...
For the WRT310n, back to the User Guide (download from Linksys), perform a reset and start over following setup instructions (make sure the router is hardwired to the laptop). Set up a new home network on the laptop using Control Panel. Make sure the adapter settings are correct and good to go. Then see if you can connect to the router with your browser to set it up. After setup, you should be able to connect to the router wirelessly from the laptop, but you have to make sure the wireless transmitter inside the laptop is turned on first (see the laptop user manual).
Jul 05, 2017 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
3 failed attempts to connect HP DV6t laptop
First as a test, turn off the wireless security, and see if the laptop can connect.
If it can connect with security turned off, then it is likely that you are making some type of mistake with the password. (Such as caps lock being on, or having a keyboard error.)
Good Luck!
Jan 03, 2010 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Using the SMC100 Barricade as a Wireless Access Point
use the wrt310n router as the router for the internet (where dsl modem is connected) then just connect the ethernet port (not wan port or internet port) of the SMC to the ethernet port of wrt310n
Oct 31, 2009 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
Lost the internet connection on my laptop that worked before (Linksys wrt310n)
first check if you have internet with the modem if yes then you'll need to reconfigure the router. Contact router's manufacturer to assist you how to set it up.
Sep 14, 2009 | Linksys WRT300N Wireless Router
Used to be able to connect using WRT310N
You should call Linksys tech support now. The router needs to be configured manually. The tech that you hired maybe not familiar on how to configure the Linksys router.
Jun 25, 2009 | Computers & Internet
Cant connect my router to my new internet
Did the old internet come with the router? It may have static settings in it. If so, you will need to configure it with the new static settings, or at least put it on DHCP.
Jun 09, 2009 | Linksys Wireless-G WRT54GS Router...
Linksys wireless router
download the manual from linksys to start with. find out what the local ip-address is. normally it is http://192.168.1.1 Go to start/accessories/dosprompt and type: ipconfig enter read the number behind: standard gateway. that is the ip address. follow instructions.
Feb 23, 2009 | Computers & Internet
I cant get my new wireless N linksys WRT310N router to work
First reset the router by pressing the reset button for 15 seconds and after resetting it run the setup CD fo it to reconfigure the router, if you don't have the setup CD better contact Linksys tech support number and let a tech walk you through in manually configuring the router, this is the number for Linksys 800-3267114...........
Jun 18, 2008 | Linksys ULTRA RANGEPLUS WIRELESS N GIGABIT...
Computers & Internet Logo
694 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
