Question about Dell Inspiron 1501 Notebook
Inspiron 1501 When my daughter turned her computer on it appeared by the lights to come on, but the monitor stayed dark. She has turned off the power and restarted several times but the screen won't come on. Help, please
  • djtljohn Jan 04, 2009
    You heard a sound like the computer is coming on, but it doesn't. The screen is black. Right after my warranty went out, this is when it did it. I did the FN and power button like dell said for the diagnostic to begin, but it doesn't do anything.
    Genius:
  • 2,028 Answers
Two things that you can check that cause this are the battery and the memory. Remove the battery and start on the power supply only. Then remove the memory and try each chip, one at a time in each slot. These are the two main causes of a no start with Dell machines. If it's not one of these, then the problem is going to be with a motherboard component, and you will need to take it in for a professional diagnostics in order to track down the exact problem area.
Posted on Aug 21, 2008
SOURCE:
Inspiron 1501 wont start
Does it look like it is running with the exception of the screen being black?
Does it ever post anything on the screen when you hit the power button?
Beep tones and blinking lights tells thetechnicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lightscontinuous.
Apr 06, 2012 | Dell Inspiron 1501 Laptop
I just bought a monitor to add to my Dell Inspiron 1501, and hooked itup - it recognized the new monitor and resized the display automatically, but now, every time I try to close the notebook, it turns the...
Your power settings must have gotten changed. You have to go to the control panel, power options, click on the advanced tab and there should be an option asking "when I close the lid on my portable computer:" There should be a selection list for you to choose from.
Apr 24, 2010 | Dell Inspiron 1501 Notebook
How do I get rid of a blank screen on my laptop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 16, 2009 | Dell Inspiron 1501 Notebook
Lcd on dell inspiron 1501 wont start up (dark) no pictures
Give it sufficient time to dry, then try again.
Also, you may actually need to send it back to Dell - and I wish you luck with that, because Dell's service is known for being the worst in the business.
Jun 20, 2009 | Dell Inspiron 1501 Notebook
Screen IS black, BUT EVERYTHING ELSE IS OK
there is a invertor in LCD. it makes your lcd bright white shine. if it doesnt work you can have dark view. i mean something going on the lcd but you cant see clearly. take to tecnic service your computer.
i hope it works.
May 27, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 push power button no screen or sounds
Have you hooked it up to an external monitor? If you can see windows booting up on the external monitor then u may have a bad lcd screen or inverter or video card? Still lots of questions to ask.
Apr 11, 2009 | Dell Inspiron 1501 Notebook
Dell inspiron 1501 work fine turn off last night now wont turn on
You mentioned trying a different battery, try a different AC adapter.
When plugging in the ac adapter to the wall, see if the POWER LED comes on on the adapter, then when you connect it to the computer, see if the LED stays on.
If the issue occurs with both AC adapters (No battery installed) then the motherboard has failed. If one ac adapter works but the other doesn't then the adapter is bad
Feb 01, 2009 | Dell Inspiron 1501 Notebook
My daughter was on my dell inspiron 1501 laptop, all fine, i asked to use it for 5 minutes, i unplugged it from the adapter and used it in another room, i returned it still on my daughter plugged it back...
The inspiron has known issues with overheating and heatsink fan issues.. Contact dell tech support if under warranty or just buy a new motherboard cause yours is probably dead now.
Jan 18, 2009 | Dell Inspiron 1501 Notebook
Dell Inspiron 1501 Notebook Logo
90 people viewed this question
Ekse
Clive
Clive
