SOURCE: Door lock light flashing
Shame to say it but yes..
You board behind the control pannel is blown. this is caused by either a faulty door swtich or the motor.. Your model number tells me its most likely the door switch.. The control board will need replacing and the door swtich.
Getting to the board is easy only three screws near the soap draw. make sure you write which wires go where and to getto the door lock undue the door rubber if you needany further advice let me know
i have worked on more the 300 of these machines
SOURCE: Door Lock Light - flashing
does the door still lock? becasue it sounds like a faulty lock. It may need to be replaced.
SOURCE: hotpoint first edition few 12p,not working
parts are free but a call out charge is made approx £80.00
SOURCE: Hotpoint Aquarius WF440 Washing m/c - Door Lock light
You have probably knocked of the connector or the catch (and on these it is very fragile as I have changed the catch 3 times on mine) is broken
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
