Question about Vacuums
Hoover windtunnel vacuum belt
How do I change the belt on a hoover windtunnel vacuum cleaner? It is the one that drives the brushes in the front.
  • Anonymous Sep 04, 2008
    I replaced belt loud noise and it ate it up, I repalced belt wth correct number and followed instructions
    Now no belt it ate it up nwhat ndo nZI need t do next?
  • Anonymous Mar 24, 2014
    The Hoover WindTunnel Ultra Bag Vacuum Cleaner handle release lever is broken. How do you take the old one out and put the new one in?
There are 4 screws that you need to remove. The belt lies between the roller and a pin. With a little effort, you just pull out the roller, and the belt will come loose. When putting the new belt, you need to insert the belt into the pin first and then put the other end of the belt onto the roller. Then pull the roller and put it back into its groove. Voila!
Posted on Aug 20, 2008
SOURCE:
Change drive belt
Flip the thing unside down...the cover theat is over the brush comes off with abotu four screws...then you can pop the brush up and out....take off the new belt and then get the new belt around the motor shaft, then around the brush... it will stretch hard to get it back in place....secure the cover and your good to go!!!
heatman101
Apr 28, 2010 | Hoover U5753-900 WindTunnel Bagless...
How to replace belt on Hoover U6626-900 Wind Tunnel bagless.
Click this to go to a site that will show you (complete with illustrations) how to change belt.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
I hope this helps.
Jan 19, 2010 | Hoover U6630-900 WindTunnel Bagless...
Hoover U5780-900 Windtunnel Cyclonic Bagless
You probably need to change the belts. Here are the belts you need and the manual:
Hoover 5780-900 Belts
Manual
Dec 22, 2009 | Hoover U5780-900 Windtunnel Cyclonic...
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
Hi I have model u64330-900 hoover windtunnel. It
It sounds like your vacuums belt is stretched and worn. You'll need to replace it. Below is a link to a website that gives instructions with pictures on how to change the belt. You should be able to get a replacement belt at any department store or vacuum retailer.
I hope this helps you.
http://www.info-vacuum-cleaner.com/hoover-vac-belt.php
Sep 24, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Belt will not stay on hoover windtunnel s3765
The Hoover Windtunnel™ Self-Propelled models have two belts, a flat belt and the V-Belt. This V-Belt is the one that drives the Brush Roller. After about three months, most belts stretch out causing them to slip. This means the brushroll turns slower or not at all and the self-propelled becomes increasingly harder to push. It is recommended that both belts should be changed at the same time.
May 23, 2009 | Hoover S3765-040 WindTunnel Bagless...
Roller Belt Keeps Slipping Off
You could try contacting Hoover for parts availability. If it's and older WindTunnel and Hoover no longer has the part, try eBay.
May 14, 2017 | Hoover U6437-900 / U6439-900 Windtunnel...
Changing bell on a hoover turbo power 6200
Most Hoovers if you turn the vac over, remove the plate covering the brush roll, then you can get to the belt and brushroll.
Dec 31, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Vacuums Logo
230 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
