Question about Acer Computers & Internet
How to connect the built in cd burner? - Acer Computers & Internet
  • 197 Answers
This should have been connected when you bought the computer but you should have a ribbon and a power , one is gray and the other should be white the gray ribbon plugs into the bigger slot on the back and the same with the white one
hope this works for you if not email me at
[email protected]
Posted on Aug 19, 2008
SOURCE:
I want to install it in my coputer but dont I dont have a disk, what can I do?
There is no need to install any software before/after connecting the LiteOn device,
because Windows XP/Vista/7 already contain the necessary device-drivers.
So, just connect it, and restart Windows, and it will be ready-to-use.
Windows Media Player can be used to play DVD-movies,
and Windows has built-in software to write onto CD-recordable disks.
Feb 19, 2011 | Lite On LTC-48161H CD-RW/DVD-ROM Burner
How do i burn the cd
Windoze has had a built in burning app since XP, simply right click on the file/files you wish to burn and select send to, then select the drive letter associated with the burner, alternatively you can install a stand alone burning application
Jan 07, 2011 | Dell (0R649) CD-RW Burner
WINDOWS 7 DRIVERS FOR DVD DRIVE
You don't need drivers to use this cd dvd burner in Windows 7 because they are built into Windows. If the device isn't working, it probably isn't any good.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jan 12, 2010 | Computers & Internet
DVD+/-RW/CD-RW NEC AD-7203S drivers No problem - just simple me need drivers for this device? for installation on other PC, new system not understend this device and ask driver
Windows 2000 & XP & Vista & 7 have "built-in" drivers for *ALL* CD/DVD drives. So, no specific "driver" should be necessary.
What errror-message(s) do you get?
Does Windows ask to connect to the Internet to search for drivers?
Did you permit it to connect?
Jan 02, 2010 | Sony NEC Optiarc AD-7200S DVD-RW Burner
WHen I try to burn a cd it says connect a burner
hi,
check whether your burner is properly connected or not.
if it is properly connect then the software your are using for cd writing is not compitable with your burner.
Aug 18, 2009 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
It says for me to connect my burner
get an external dvd burner,it connects via an usb cable
Jul 01, 2009 | QPS Que! CD-Rewriter CD-RW Burner
When i try to burn music...my cd burner quits at 12% and fails
the only solution is to buty an external cd/dvd burner with a buffer under burn built in in use a decent burning program like nero, or nti or any other ones that let you choose the burn speed as I use 8x for cd's and dvd's but somtimes the burner won't alow me to change speed.
I know this is the one way or have the burner looked at by an engineer thats the other solution.
Good luck with this one
Nov 23, 2008 | Gateway (5501610) CD-RW Burner
My dvd burner doesn't burn dvds
You need to check that with blank DVD's you are using compatible with your drive.Because the DVD's may work with your extranal drive but not with your builting drive. If this doen't slove the problem I would recommend using a different burning software other than "sonic record now" and "vista o/s Built-in dvd burner".
Sep 07, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
Cd/Dvd burner stopped working on my laptop
when i try to burn discs i get message connect burner, my laptop is compatible to do all this
Aug 03, 2008 | Dell Inspiron 1000 Notebook
Need help
The most likely problem is that the Burner is shot and will no longer function. How long have you had this burner? Have you run tests on the burner? Has your system crashed before this began to occur? I can only solve your problem with this information.
RCF
May 27, 2008 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
14 people viewed this question
Ekse
Alun Cox
