Question about Panasonic SA-HE90 Receiver
Replace speakers 4 tweeters 12ohm 6PH02E3 IDN 701k 2 woofers 6ohm 12PL21A3 IDN 791f
How to hook up alpine 3653?
Instructions
    • 1 Determine the distance between the system amplifier and the 2-way crossover. Cut this with the wire cutters. Strip 1/2 inch of insulation from the amplifier end of both speaker wires. Loosen the amplifier speaker screws with the appropriate screwdriver. Insert the bare wires under the terminals strips. The speaker wire with the writing or molded ridge is usually used as the positive wire. Tighten the wires down with the screwdriver.
    • 2 Route the wires within the vehicle, avoiding potential hazards such as floors, seatbelt areas, and anywhere where small stressing or abrasion may occur. This usually means under side trim or tucked within the dash. Secure any loose speaker wire with zip ties every 4 inches.
    • 3 Remove 1/2 inch of insulation from the crossover end of the wires. Locate the section of the speaker terminals labeled "INPUT" or "AMP." Insert the wires leading from the amplifier under this strip, following the same polarity used at the amplifier. Screw these down with the appropriate screwdriver.
    • 4 Cut lengths of wire to connect from the crossover to the woofer and tweeters. Strip 1/2 inch of insulation from both ends of the wires. Crimp a 16 gauge insulated connector onto the tweeter end of the speaker wire leading from the crossover. Insert the wires under the loosened screws labeled "TW" or "TWEETER." Tighten these back down to secure.
    • 5 Strip 1/4 inch of insulation from the wire pigtail leading to the tweeter. Insert this into the other end of the insulated connector, and crimp it securely. Repeat for both tweeters.
    • 6 Crimp a 16 gauge female spade terminal on the ends of the wires leading to the individual woofers. Slide these over the appropriate terminals on the woofer, again following the same polarity observed at the amplifier. Insert the crossover end of the wires into the "WF" or "WOOFER" terminal on the 2-way crossover. Tighten them back down to secure.
Read more: http://www.ehow.com/how_7175673_hook-up-alpine-2_way-crossovers.html#ixzz32AMgzu8S
May 19, 2014 | Alpine 3653 2-channel Active Dividing...
I open my b212a and disconnected the speaker and horn wires and know i have completed my repair i am read to reconnect and i don't remember which set of wires are the positive side
Because the system is bi-amplified, it is important to replace the wires correctly to avoid phase problems. I don't know how the wires are colour coded, but if it is any help I downloaded the schematic and the wires are numbered 1: Woofer Active 2: Woofer Earth
3: Tweeter Earth and 4: Tweeter Active. Sorry if that's no help. Otherwise it should be easy to trace the wires to see which connect to earth.
Dec 12, 2013 | Behringer Eurolive B212A Speaker
How to hook up Panasonic SB PM19 speakers to SA-PM23 reciever
yes you can. these are called "bi wired" speakers which means there's a hook up for the woofer and the tweeter individually. If your amp have just 2 speaker hookups it's no problem to hook the woofer/tweeter wires of each speaker together. If your amp had 4 speaker hookups, you could put the tweeters in 1 and the woofers in the other but it will still work fine with 2 speaker hookups.
Mar 21, 2013 | Panasonic Audio Players & Recorders
How to install spr-17s
The six 1/2 speakers are your woofers,connect the positive and negative wires from the speaker to the 2 connections labeled on the crossover as W(woofer)+ pos and W(woofer) -- neg,hook the tweeters to the crossover connections labeled T(tweeter)+ pos and T(tweeter) -- neg,then hookup the 2 remaining connections labeled Amp to your amplifier,amp must be 2 or 4 channel stereo capable and give out enough power to properly drive the speakers so they achieve optimal performance.
Mar 05, 2011 | Alpine SPR-17S Car Speaker
Diamond 8.4 serie are there 2 way or 3 way
These speakers are 3-way there are 2 woofers and 1 tweeter per speaker. Here are the technical specifications of each speaker:
Two 6.5-inch Kevlar woofers and 1-inch silk-dome tweeter per speaker
86 dB sensitivity
20 to 150 watts recommended power (per channel)
6 ohms impedance
30 to 20,000 Hz frequency response
Please rate my answer if this helps.
Many thanks,
Chris
Mar 02, 2011 | Wharfedale Diamond 8.4 Main / Stereo...
How do i wire the crossover on the dxd210/213
If the crossover is made to accept speaker level input from amp then.....Amp/head spkr output + to crossover + input. Amp/head spkr output - to crossover - input. Crossover midbass + out to midbass spkr + input. Crossover midbass - out to midbass spkr - input. Crossover vari-tweeter + out to tweeter spkr + input. Crossover vari-tweeter -3 or -0 or -6 out to tweeter spkr - input. You have to choose for your preference. 0db makes the tweeter respond normally. -3db mean 3db lower in volume...and -6 means 6db lower in volume. Choose based on your liking.
Apr 12, 2010 | MB Quart - 5.25" 2-Way Component Speakers...
The woofer on one of my speakers stopped working. The tweeter seems fine. My DMM shows that the resistance across the 2 internal leads that connect to the woofer continuously cycles from 0 through...
The voice coil is open, you can look real close at the spider wires that are soldered from the two terminals to the cone to see if they are bad, otherwise you will need new woofer, you can try getting the woofer from partsexpress.com
Feb 14, 2010 | Boston Acoustics Micro90X Speaker
I have floor speakers that i replaced all the speakers in it with 4 ohm speakers and i just bought a onkyo receiver n it gets really hot and shut off 1 time....i was wondering if there is a way to wire it...
Home audio is typically 8 ohms. If the speakers you used were designed for mobile audio then this would be why the receiver is overheating. You may be overloading the output
Dec 04, 2009 | Audio Players & Recorders
Need to replace 11L tweeter
the best solution I've found is this:
1. Remove all the tweeter screws.
2. Take a thing metal rod (a coat hanger should work) and lightly tap the tweeter through the top port in the rear until it is loosened and comes out. The tweeter is totally sealed so you probably won't damage it if you need to do this to a working tweeter.
This method also works for the woofer but you need to be very careful to tap the frame or magnet of the woofer and not the cone.
Jun 25, 2008 | Quad 11L Main / Stereo Speaker
Karaoke speaker,no woofer or midrange working, only tweeter
Hi, it's probably that the 8" woofer and the midrange of the "amped" enclosure is open. One way to test is to remove just one wire from the inside of the enclosure to the woofer or midrange in question and with the use of a continuity tester (or a VOM), check for the resistance of the coil of each the 2 speakers. Both should read anywhere from 4-8 ohms, if there's no reading (VOM needle will not move) then the coil(s) are open. In the absence of a tester, a single AAA or AA battery would do (pls. some would argue that this is not a sound practice, however this should be enough for you to be able to determine the condition of the coil(s)). With the use of the battery and a single short length of electrical wire, apply power from the battery to the terminals of the speaker, if the cone moves, then chances are it is good, if they don't then you would have to replace it. Am not sure if available in your area, but there are some trained people who can rewind the coil should a replacement speaker be not readily available. Hope this be of help. Please let us know how things turn up. Regards.
Apr 15, 2007 | Vocopro PV420 Main / Stereo Speaker
Panasonic SA-HE90 Receiver Logo
127 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
