Question about Sony KP-61V80 TV
Won't Turn on, standby LED lit
My Sony KP-61v80 will not turn on. When I plug it in, it almost sounds like it might turn on. When plugged in, the standby LED blinks once and then remains lit. The power button on tv or remote doesn't do anything.
  • 5 more comments
  • slam_w2k Aug 31, 2008
    Same problem here!
  • copy1 Sep 01, 2008
    Precisely te same problem. Any help appreciated.
  • Anonymous Sep 07, 2008
    Mine just quit today. It was working then went blank!! It smelled as though something burned or was burning. No picture, power is on and wont turn off unless unplugged from AC Help!!
  • jljohnstone Nov 09, 2008
    I have the same problem. The TV went blank led standby timer is lit but the remote has nothing to do about off or on unless tv is unplugged
  • sixlilreds Dec 21, 2008
    my kids turned on the tv it went pop and the red light was on and it started to smell hot i took the back off and plugged it in smoke came from the power board. can i fix this by replacing the whole left side or not
  • bluhm795 Jan 29, 2009
    there was a pop sound, then the sound and picture went off. the standby/on light was still on but nothing. I wasn't able to turn it on or off, so i needed to unplug it. wheni plugged it back in the light would blink 3-4 times then nothing. no sound or picture.
  • slapme1 Mar 28, 2009
    have the same problem. Anyone know a solution? Please help if you can asap.
HI,
I am having the same problem, any solution? Thanks! -Steve
Posted on Aug 31, 2008
Mine just bit the dust too!! How ironic. My grandson was watching it and all of a sudden no picture! The light on the front still showed power to the TV but remote could not turn it off. Only way to get light out is to unplug from AC. Help!!
Posted on Sep 07, 2008
I'm working on my 1996 model KP-53v35 Sony. The problem is that I plug it in and it tries to come on and the red LED flashes and it shuts off.
If the lamp light is blinking, then lamp needs to be replaced. If the standby light is blinking, the try resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then the service may be required.
Jul 26, 2010 | Sony KP-53V35 53" Rear Projection...
No picture or sound, standby led flashes 11 times when first turned on after AC plug has been removed and reinserted into the AC outlet. Every attempt to turn on after the initial attempt yields 6 flashes...
It seems that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur. The flashing LED is justa coincidence I would think.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
Jan 22, 2010 | Sony KP-53HS10 TV
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
4 times flash of standby light shows that TV has problem in Vertical Deflection area and possible causes are IC1509(V out) is broken and / or Q1505(V Pulse Buffer) is broken.
Please check / test above said IF you have experience of TV repair.
Nov 29, 2008 | Sony KP-57WS500 57" Rear Projection...
Sony KP-51WS510, standby led blinks 5 times
It sound like you have a bad picture tube...check your 1k circuit for correct voltage and wave form.
Oct 03, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-65WS500 65 in.
Check your CRT boards on the end of the tubes for burn spots, and burnt components, check the resistors to make sure they are not shorted, burnt, and they read the correct resistance. Check the diodes to make sure they conduct in one direction only and are not shorted or open.
Mar 24, 2017 | Sony KP-65WS500 65" Rear Projection...
Sony KP-61V80 wont turn on
This is a very easy fix actually all you need to do is replace that cap and the set should be fine, this is a very common problem on your model. If you look on the board and give me the location of the cap I will be happy to look up a part number for you.
Tim
Experttv@comcast.net
Sep 10, 2008 | Sony KP-61V85 61" Rear Projection...
Sony KP-61V80 TV Logo
640 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
