Question about Jenn-Air JJW8130D Electric Single Oven
Jennair single oven...
Don't know what started this...but hit bake and the fan came on...hooks the door (like its cleaning) then turns its self off with a f8 error...when the fan stops the beeper goes off continually until you hit the timer button...then when you want to bake the process starts all over again
  • 116 Answers
Hey marygilfilen
F8 error is associated system failure. I suggest you need to replace your clock (controller)
Regards
Posted on Sep 07, 2008
Cleaning a self cleaning oven
I couldn't find any information on that specific model number, but here is a link to a generic Jenn-Air Electric Range - Use and Care Guide which seems to be model non-specific. The instructions for performing a self-cleaning (as well as other tasks) might be the same for yours.
http://www.jennair.com/assets/product/8113P619-60.PDF
Jan 05, 2008 | Ovens
I am trying to start my self clean and a minute after I hit start a beeping with this code appears: FSEI
Make sure that the door latch is completly locked and then try again. If it is locked and you are getting this code the door latch assembly is bad. The oven sensor would be fine since you get no codes during normal baking. Problem is in door lock system
Feb 28, 2010 | Whirlpool RBS275PD Electric Single Oven
When baking my oven door is not locked is it supposed to be?and if so how do we lock it.
The locking of the oven door is a safety feature used only during automatic self cleaning cycle, this is because temperatures during the self clean cycle can reach upwards of 600+ degrees creating a dangerous situation if the door was opened, it will remain locked after the self cleaning cycle is complete until the oven interior temperature is below 100 degrees. So no the door is not normally locked during the bake cycle. Good luck !
Nov 26, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Accidently started clean, food inside,hit cancel,can't open
you would have to disassemble the cook top in order to get the the locking mechanism to manualy unlockit
May 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore oven locked door light on but not, won't bake
Check your breakers and also your wiring. Try to turn off the breakers for about 10-15 seconds. Your board inside the control panel may be bad since you are getting mixed signals.
Jan 12, 2009 | Kenmore 47783 Electric Single Oven
How can i quit cleaning oven?
During the self clean cycle, oven temp will exceed 900 degrees F. At these temps, if you opened the door, the food inside would immediately catch on fire when the supply of oxygen hit it. When you turn your self clean cycle off, the oven door will remain locked until the internal temp drop below aprox. 550 degrees F for your safety. Once the oven cool below this temp, you will be able to start using the bake or broil again. This should be a Fix-Ya for your oven.
Dec 29, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
I can't get oven to work on broil or bake; only self-cleaning.
Hello
Welcome to Fixya
My name is Huum,
Try turning the breaker off for 5 minutes and see if this resets the system.
if not you may have a defective Control board and you will need to have a HANDS on tech to diagnose these parts to be sure! They will have the diagnose equipment !
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 21, 2008 | GE Profile JTP18 Electric Single Oven
Lock for selfcleaning oven did not retract all the way
try setting the self clean letting it lock and then hitting the cancel button. usually take a min or to to see if it will retract itsself. the only other option would be to tap it lightly with a hammer so you can use the oven and replace the latch
Dec 07, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
How do I clean my frigidaire self clean gas oven
after the three hour prompt comes up hit start while the door lock light is blinking and let me know what it does
Jan 09, 2008 | Frigidaire FGB24S5A Gas Single Oven
Jenn-Air JJW8130D Electric Single Oven Logo
101 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
