Question about Jeep Liberty Limited XT Urban Earth Jogger
Broken wheel axle
I ran over the wheel of the stroller and it broke off from the metal axle. Where can I get the part?
  • Anonymous Jan 20, 2009
    Ran over the tire and snapped the rear axle. Where can I buy a new axle??
  • 48 Answers
Go to kolcraft.com and pick the contact us link and that will give you a number they are real good with parts.
Posted on Mar 01, 2009
How do I tighten the wheel assembly on a 2005-07 Mountain Buggy Urban Jungle Double stroller?
This is a press or pound on type nut usually a one time use! But if you are carefull you can unscrew with a pair of plyers by turning both ways but pulling hard on them! Once you get it off you can put washers on the axle to take up the play. Then before you put the press nut back on make sure you didn't bend up the little pieces of the metal. They should be bairly slanting to the inside of the nut. If they are slanting to the out side bend them in gently. them tap the nut back on!
Mar 18, 2015 | Mountain Buggy Baby Gear
Wheel has broken off
When you say the wheels has broken off did they break of at the spokes (making the wheels useless) or did they just come off the metal stub axles? I've fixed a lot of strollers and the most common problem is a failed Star-lock washer. Most strollers use a star-lock to hold the wheels on, either a shiny domed one in plan view or a plain flat one hidden behind a plastic hub cap. Check this out www.bakfin.com/starlock/starlock-movies.html
Dec 14, 2010 | Baby Gear
The entire back wheels fell off our double eddie bauer stroller - both wheels on the right and the left. We've tried to replace wheels without success. Can we order the wheels somewhere? thanks.
When you say the wheels fell off did they break of at the spokes (making the wheels useless) or did they just come off the metal stub axles? The Eddie Bauer is not a brand available in new Zealand but I've fixed a lot of strollers and the most common problem is a failed Star-lock washer. Most strollers use a star-lock to hold the wheels on, either a shiny domed one in plan view or a plain flat one hidden behind a plastic hub cap. Check this out www.bakfin.com/starlock/starlock-movies.html
Dec 03, 2010 | Eddie Bauer All Terrain Tandem Double...
I have a stroller that the front double wheel was ran over and broke. Do you have a wheel?
What is the specific product name? You should be able to find the manufacturer's website and phone number to call and order another wheel...
Jul 05, 2010 | Baby Gear
Removing rear whells from Phil andTeds Classic pram
Press the button and pull the axle out as far as it will go. At the button end is a metal collar - hold this firmly and push the button, without pushing the axle back in. This will loosen the 2 ball bearings at the other end of the axle and you can pull it out. It is a bit fiddly but i just managed it after the same problem.
Sep 05, 2009 | Regal Lager Phil & Teds Vibe Jogger
Broken rear wheel on graco duo stroller
You can order replacement parts from the Graco website.
http://www.gracobaby.com/
Go to the Help Center, then Order Replacement parts. You'll need the model number and serial number or manufacture date. Site helps you locate the information on your product.
Jun 09, 2009 | Graco DuoGlider 7444 Twin Seat Stroller
Where can I find replacement parts - front wheel assembly
Call perego at 1800-671-1701,they havy any parts you need in stock.
May 18, 2009 | Peg Perego A3 Newport Standard Stroller
BEBELOVE JOGGING STROLLER BROKEN WHEEL
I have a problem with my rear wheel. I lost the black round support that goes between the shaft and the wheel. Maybe we can make one good stroller out of two of these. email me at mcwolie@hotmail.com if you can sell me the support or if you want to purchase the wheel.
Sep 07, 2008 | Baby Gear
Front wheels are not functioning well
I had this exact same issue. Needed to take axle out of wheel, larger metal cap pops off, then remove all rust from axle, then re-fit axle.
Jun 11, 2008 | Bugaboo Cameleon Jogger
GRACO STROLLER FRONT WHEEL BROKEN
I have the same problem, the airline broke ours the last time we flew. I just found on Graco's website that you can order replacement parts. Here is the link, http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
You'll need the model number and serial number. I found ours on a sticker under the footrest. For our stroller it's $19 plus shipping for the front wheel assembly.
Hope this helps.
Jan 13, 2008 | Baby Gear
Jeep Liberty Limited XT Urban Earth Jogger Logo
468 people viewed this question
Top Jeep Baby Gear Experts
Dorel UK
Dorel UK
Are you a Jeep Baby Gear Expert? Answer questions, earn points and help others
