Question about HP PSC 1610 All-In-One InkJet Printer
Will show "out of paper" message even when paper is loaded
When i try to print something, the printer will tell me after a minute or so that there is no paper loaded, even when there is.
  • Anonymous Aug 26, 2008
    Actually, I didn't specify enough. It would try and try to feed, but it is a whirring sound like a car has when it had a bad belt, and it never feeds.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Well..try it with just a few 'riffled' pieces of paper
Posted on Aug 19, 2008
SOURCE:
Message window shows "load mp
The printer tells you to insert a letter format paper in the mp (multi purpose) feeder (the manual tray).
If you press the GO key the print probably proceeds with print job (if has the paper loaded in mp feeder)
Jun 15, 2011 | Lexmark T634 Laser Printer
Printer screen shows " Out
Hi tpuette
Be sure that the paper in the paper try rests within the guides. Also, ensure the that paper try closes properly and is not loose. Be careful also with the amount of paper you load into the printer, don't load too much into the tray or it may cause a paper jam.
Once the paper is loaded the printer may want you to confirm this by pressing a button, this will usually be a button with "OK", "Yes" or "Enter" printed on it. Check the little screen on your printer for such a message.
Hope this helps :)
May 15, 2011 | HP PS C4780 All in One InkJet Printer
The printer is not reading paper. Message iskeep
Make sure you inserting the paper not deep inside just insert and stop it when you feel any resistance .and try to print something. If it is print then well otherwise you have to show it service center.
Jan 21, 2010 | Office Equipment & Supplies
Showing out of paper even though paoer loaded
Nov 10, 2009 | HP DeskJet 3940 InkJet Photo Printer
Printer loads paper incorrectly when trying to print
in the tray where you put the paper, there are two pieces of plastic that site on the side ,,,,, bring them close to the paper as to touch the paper.
this way the paper cannot go left or right when loaded and now will go in straight.
this oughta do it.
Mar 26, 2009 | Dell 922 All-In-One InkJet Printer
The led screen shows genera error
you need to reset your printer try doing this
  • Press and hold “Stop”, “Maintenance”, and “Power” buttons for about 10 seconds. A message will come on the screen saying counter is reset and to turn the printer off. The R200 and others don’t have a screen so just wait until the 10 seconds is up.
  • Turn the printer off, unplug the power cord. Wait about 1 minute and power the printer back up. The counter will be reset. That’s all there is to the reset procedure.
Nov 24, 2008 | Epson Stylus Photo R300 InkJet Printer
Paper loading message says load paper even tho there's paper there
It sounds like the loader assembly motor has failed/is failiing in the printer. Considering the printer can be bought for $50 and the motor costs $25 and $45 labor to replace, you're better off just replacing it.
Oct 15, 2008 | Samsung ML 2010 Laser Printer
Epson R300 printer
ok " if you look in where the paper is loaded on top there is a small switch with a finger , may be bent. tells printer when paper is low
rubber wheels that pull paper threw may be glazed , take sand paper and go over wheels to ruff up
Jan 22, 2008 | Epson (C31C411016) Printer
Will not feed paper
There could be a small piece of paper or other matter blocking the feed. Try feeding a piece of thin card- simple load and eject don't try to print anything. Or Put a vacuum nozzle in the slot to suck any debris out. Come back for more advice if this is not the answer.
May 08, 2007 | Canon PIXMA MP150 All-In-One InkJet...
HP PSC 1610 All-In-One InkJet Printer Logo
62 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
