Question about Toshiba 37LX96 37 in. LCD TV/DVD Combo
37LX96 reboot problem
I have a Toshiba 37LX96 that I bought new early in 2007. I have never had any problems until Saturday afternoon. Suddenly the TV went dead...no sound..no picture. The only sign of life was the yellow blinking light on the front where it says disc. I checked the owner's manual and it states this is normal for this to occur because it was rebooting this is not a sign of malfunction and would only take a few seconds. About 3 hours later, I decided to do a hard reset and unplugged the TV for at least 12 hours. The next morning I plugged the TV back in and the reboot started again. It has been almost a day and it is still rebooting. Please can you give me some guidance as to what the problem may be.
  • jerry shope Aug 22, 2008
    SAME PROBLEM LED BLINKS 3 TIMES OVER & OVER
  • 65 Answers
SOURCE: Toshiba 47HL167's screen has gone Completely Black
I don't know if you guys are still looking for an answer but turn the TV on where you can here that something is actually playing on the TV then grab a flashlight and turn all the lights off. Get real close to the screen and shine the flashlight on the screen. Can you see something on the screen? If you can then there is a very good chance that one of the inverter boards are out. This could be the slave or the master. For the 47" I actually have the same issue and have ordered the master inverter board. For the 42" I have both the master and the slave board and they are both working. So for the person that has that issue on the 42" TV if you want a board for your TV email me at ced70@hotmail.com. For the one with the 47" flip a coin and order an inverter board for it either master or slave and try it. To determine which inverter board it is you would have to take the DC voltage across the start and then the end to see if you are getting any power. I hope this helps. By the way inverter boards usually run between 60-120 dollars each and the slave board on both these TV's are easy to install. The master is a little harder due to the power button board is in front of it and has to be removed first. Let me know if this helped.
Posted on Jun 20, 2009
SOURCE: Doesn't power on - Amber LED Blinking
Here's how I fixed mine...
Look inside the back of the TV just above the power cord - there are two small LEDs, one green and one yellow (no need to open the case - you can see them through the cooling slots). In my case, the green LED would light for a few moments after plugging the TV in, then the yellow one would light and stay lit.
Go to the Toshiba site and download the latest firmware upgrade.
Copy the firmward upgrade to a SD memory card using your PC (SDHC cards larger than 2GB don't appear to be supported by the TV, so use a smaller one). I copied *both* the zip file as downloaded from Toshiba, and the contents of the zip file. That is, I expanded the zip file and copied the contents to the SD card as well.
There's a metal cover over the SD card slot on the back of the TV. Remove it (a single screw)...at one point, Toshiba has directions on the firmware download web site.
Unplug the TV and insert the SD card. Plug in the TV again, and in my case, those little LEDs stayed green. I saw none of the instructions on the TV screen - rather I just let it sit for about 10 minutes, then I unplugged the TV, removed the SD card, and plugged the TV in again. Viola - the TV works.
I'm thinking perhaps Toshiba uses a type of memory that requires battery backup, and if the TV is unplugged for an extended period of time, it's necessary to re-flash it.
Posted on Jun 21, 2009
  • 50 Answers
SOURCE: I have sound but no picture. Not even the menu text will appear.
Hello, You most likely have a bad Y sustain board! Part #'s are:
6871QYH053A, 6871QYH053B, 6870QYH005B, 6871QYH953A, 6870QYH105B.
Here is a link to the part you need!
http://www.discount-merchant.com/Y-SUSTAIN-PN-6871QYH053A-6871QYH053B-6870QYH005B-p/vizio-sku9506.htm
I hope this help you! Please feel free to give me a call or message me if you have any questions! Ask for Dave!
Thank you! :-)
Dave
1-503-432-9904
pleasefixitdave@yahoo.com
Posted on Aug 26, 2009
  • 13 Answers
SOURCE: The red LED light at the bottom flashes three
Sorry but you are out of luck, the unit will need repair. It could come back to life in any moment but most often is related to this:
My previous post here
good luck,
mrwindex
Posted on Nov 08, 2009
  • 396 Answers
SOURCE: yellow light blinking - blank screen - won't turn on
I had the usual problem with a Toshiba 32HL67. Shortly after the warranty period ended, the TV would not turn on. The yellow light would blink three times ad infinitum until I unplugged the TV. After those incidents, the TV worked fine for about a year. Several weeks ago, the same problem started again.
Took the TV to a local repairman and discussed it with him. His thoughts were that it either involved the digital video board or the power supply. He suggested that I find the video board on the internet and let him install that. I located this part at discount-merchant.com for $49.95 plus shipping. Received it last week and had him install it. TV has worked fine since then. Got my fingers crossed.
The video board is Part V28A000320A1.
Posted on Mar 03, 2010
When a dvd is inserted it says reading then ejects it
simple: it cant read this disk , try using a commercial copy of a dvd (movie?) if it works then the disk your trying is in wrong format 4 it too use
Jan 22, 2016 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
We have a Toshiba Model 37LX96 LCD/DVD Combo Can't turn on, after a recent power outage There is power going to the unit, but it will not turn on using the remote or using the "power"...
Common problem with the main board. Only happens after losing main power, not just turning the TV off.
I found that blowing hot air with a heat gun down the vents above the DVD player (don't melt the plastic housing) will warm the main board up enough to get the TV powered up again.
You'll be good to go until the next power outage then back to the heat gun.
Also the spec sheet indicates max humidity at 80% so keep the TV in a space with lower humidity.
The Toshiba 37LX96 is a quality TV, not a throw away if you can keep it running.
Schmidty
Aug 25, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Not sure how to remove bottom stand from the tv
Lay the tv down to flat cushine surface like a bed maybe.Take all the tv Philip screws out of the base stand,give it a little tuckles like fordward or backward of the tv base stand will come wright out.
Jun 17, 2011 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
Motorola i776... can not hear unless im talking on speaker phone
did your phone just start doing it? because mine started doing it about 930 tonite. but was working fine early in the day.
Mar 23, 2010 | Motorola Mobility i776 Cell Phone
My touch screen is not working at all. My phone has not been dropped or anything like that. It worked saturday morning then saturday afternoon it quite.
This may or may not help but is worth a try. To reboot the phone's software, remove the battery and SIM card for a few moments. Reinsert and start the phone up.
Let me know the results.
Feb 23, 2010 | LG Xenon GR500 Cell Phone
Browin mark middel of screen slowiy getting bigger how do i fix it
Sounds like display is going bad, cost as much or more than you paid for set to repair.
Jan 07, 2010 | Toshiba 37LX96 37 in. LCD TV/DVD Combo
My 2005 Model HT32744 Sanyo has cracking thunderus sounds periodically expecially in afternoon and early evening. Then works well until another time. Have had cable problems corrected by comcast before....
To check if its cable or circuit failure,try to fed your TV with audio from a dvd or cd player and observe it for a long time.If the still the problem occurs then the problem is in the your TV circuit.If not the problem is in your cable connection.
Jul 11, 2009 | Sanyo DS31520 31" TV
Fault on TV
something fried .. sounds like the vertical has gone ,
call a tech.
Mar 07, 2008 | Televison & Video
Problem with Projection TV
This set is very common for the str typr power regulator to go out on it. Its not a consumer replaceable part. Please find a trained tech to assist you with this repair. Good Luck
Aug 09, 2006 | Toshiba TZ55V61 55" Rear Projection...
Toshiba 37LX96 37 in. LCD TV/DVD Combo Logo
674 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
