Question about Brother IntelliFAX 2800 Laser Fax
Light image on one side
Copies, incoming faxes and reports are very light on right side and normal on the left. Cleaned laser and check for connection on charging contacts.
Thanks
[email protected]
  • samsumik515 Aug 21, 2008
    Talk to owner of fax and he said that drum has been replaced just last week. Unless he got a defective unit?
    Scholar:
  • 99 Answers
You need to replace the drum (DR-250). The drum needs to be replaced every so often. Sorry, it's kind of expensive. If this helps you, please give me a good rating. Thanks.
Posted on Aug 19, 2008
SOURCE:
2" black band prints on right-side of every page
print a report, any report, from your control panel. if it looks good and your band is only on copies and transmitted faxes, that would be your Contact Image Sensor going bad. its located under your document feeder and looks like a sinny piece of glass that runs left to right.
hth,
razors
Nov 14, 2011 | Brother IntelliFax-4100e Fax
Left side very light
I believe this is a fuser issue, the fuser is not heating properly or evenly. It probably also means your dumping a lot of toner into your fax and you may start to notice streaking after a while.
Jun 10, 2010 | Brother IntelliFAX 2800 Laser Fax
Black copies being received
Your image scanner is bad. Try making a copy....if it comes out black but your incoming faxes are fine then your image scanner is bad. You can also print a report from the machine and it should come out fine.
The image scanner is the part that scans your originals before faxing them out or making a copy. There is a light bar that lights up when scanning. Either that light bar(l.e.d. array) has gone bad or the scanner itself is bad. If this is the case it is probably going to cost more to fix than the machine is worth. You could buy a new machine for what it would cost to fix.
Good Luck and Thank You for using Fixya.
Apr 22, 2010 | Brother IntelliFAX 4750 Plain Paper Laser...
Black stripe down right side of incoming faxes and copies, cleaned view window but still there and actually got worse.
pull your drum unit out and look at the top of it. you will see a blue plastic tab. that tab has got to be all the way on the left side. if not, it will cause a black stripe about 3/4" wide.
hth,
razors
Mar 03, 2010 | Brother IntelliFAX 4100 Laser Fax
Copy and faxes come out with a black line on the left side about an inch from the side.
If your INCOMING faxes have the same black line as your copies then the problem lies in the toner cartridge. A line on OUTGOING faxes and copies would suggest something on the scanner glass. This is a small strip of glass under the cover where your originals are fed into. Another way of testing is to run a report from the operation panel. If a report generated from the machine is ok then it is the scanner glass. If the report has a line then it is in the toner cartridge.
Good Luck
Feb 20, 2010 | Canon FAXPHONE L80 Laser
Light Copy. Changed cartridge and it is still light.
It is important to distiguish light COPY from a light received fax. If you are making a COPY and it comes out light but your received faxes are ok the your scanner is dirty and needs to be cleaned. If this is the case then remember that your outgoing faxes are being sent out light as well. If your incoming faxes are light then your laser unit needs to be cleaned. If you can find someone local to service it then a proper charge is somewhere i the $75 range.
Oct 20, 2009 | Brother IntelliFAX 2800 Laser Fax
Same black line on right side problem
take out your drum unit and make the blue plastic corona wire cleaner on the drum unit is pushed all the way over to right side. see if that helps.
razors
Dec 30, 2008 | Brother IntelliFAX 4100 Laser Fax
2 inch black lines on left side of outgoing and incoming faxes and copies as well
Sometimes the drum cleaning blade craps out. Remove cartridge and inspect the drum, it should be clean.
Sep 12, 2008 | Brother IntelliFAX 4100 Laser Fax
Light print of incoming faxes, cannot read
are copies light too? if not then it is sending fax, but most times it is inferior ink or drum causing the problem sometimes damp paper (try printing on reverse side as well)
Oct 31, 2007 | Brother IntelliFAX 2600 Fax
Brother IntelliFAX 2800 Laser Fax Logo
67 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
