Question about Karcher 2500 PSI Pressure Washer
How to connection extension hose
Dear Sir, I brought a 25' extension hose for my Karcher K3.96M pressure washer. I saw the existing hose connection screw head but it was located inside near the bottom of the machine. My hand just impossible to go inside there to disconnect it. I saw some screws connection at the back of the machine. In order to unscrew that I need to have a special screw driver.
Any suggestion and advise please!?
Ernie
SOURCE: Karcher Power Washer Problem
I had the same problem with my Karcher. The recall was lifted Aug. 0f 2007. Tried numerous people at Karcher....head of Customer Service, vice president, etc. No one returns telephone calls not even cutomer service....poor, very poor customer service. Thinking about calling Germany.
Posted on Jun 14, 2008
  • 92 Answers
SOURCE: karcher washer went dead
Dear jimbocom,
The problem is that the spill valve got stuck. When the machine is working and the gun is closed, a valve( spill valve) moves with the accumilated pressure and switches the machine off. So what happened is that when the spill valve did its job, it found no water...and remained stuck. This leaving the machine in an off position. Service and lubrication to the spill valve must be done or completely replacing with a new spill valve. In my opinion you have no serious damage, but this job must be carried out by an expirienced technician.
Regards,
MG.
Posted on Nov 05, 2008
SOURCE: Karcher pressure washer 411A. loss of pressure...
411a when i turn on it gos for 1 min then i have too press it on and off 3or 4 times befor it works and it only stays on for 1 min.
Posted on May 21, 2009
  • 32 Answers
SOURCE: Karcher prssure washer motor will not start
try going to www.karcher.com
then click on europe
the international,
then service and will then see spare parts, enter k620
tick the button for you are a engineer and you are on your machine
download.
micro switch might be at fault.
Posted on Jul 04, 2009
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
How to work a pressure washer?
hook up the water hose before turning electric on have the hose supplying water to it low pressure these units cant take full pressure like over 60psi, thenturn the dial to where you want andconnect power use 3 way adapter prong outdoor style extension with a good outside coded plug receptacle of course
Apr 04, 2016 | Karcher K 2.56 M 1,500 PSI 1.3 GPM...
Karcher k3.575 high pressure quick connect high pressure hose not locking
clean out the dirt and check the hose support that likes to slides down to the end of the hose
Mar 20, 2012 | Karcher K3.68MR Electric Pressure Washer
I have a Karcher Pressure and cannot get any pressure out of the unit.
karcher K3.97 MB when connected up to tap and switched on pressure poor and motor seems slow cleaned hose end, and filter looks clean
Apr 19, 2011 | Karcher Garden
I HAVE A G30500HR PRESSER WASHER AND ACCIDENTLEY
Hey mate,
You should definately be able to get one of these at your local Karcher dealer, Ive worked at a karcher dealer here in australia and you can get any part you want for them...
Brad:)
Jan 02, 2010 | Karcher G3025OH Pressure Washer
Cant change the high pressure hose on a Karcher
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Jun 03, 2009 | Karcher G 2600 VH Gas Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
I can't connect the garden hose to the water inlet. I am using a size 5/8'' hose but it wont connect to the unit. Please help!
Karcher electric pressure washers typically are supplied fitted with the male half of a standard Hozelock connector. You need the female half secured to the end of your hose, and then they just click together.
May 16, 2009 | Karcher PSI Electric Pressure Washer
Worked well, then blew the fuse.
What you should do next is stop using an extension lead. As you've already discovered, there's a risk of the connection getting wet, which is potentially very dangerous, but this is probably not the main problem. Most extension leads (the normal domestic type) are simply not capable of carrying the current needed to run your pressure washer.
Rather than using an electrical extension, use an extension high-pressure hose and work further away from the machine (which also makes it easier to keep the machine dry).
If this doesn't sort the problem, please post here again and we'll try something else.  Good luck!
Mar 10, 2009 | Karcher K2.26 Electric Power Washer
How do i connect the hose to the karcher k399 handle
Pop out the plastic tab at the base of your gun (use point of screwdriver/knife).
Then push the hose connection into the gun and push the plastic tab back into it's slot. This will hold the hose in place.
Jul 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
54 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
