Question about Jenn-Air Electric Double Oven
SCD302 Thermador oven
The control panel display is getting dim. Do I need to replace the complete control panel, or is there a part inside or connected to the panel that I can change?
Thanks,
Ted Heine
[email protected]
    Scholar:
  • 54 Answers
I can't guarentee you have the same problem but my Jenn Air did the same thing.
BrianGem posted a great solution back in May of '08, I just completed that fix on my own Jenn air, took me about 30 minutes once I got the correct capacitor.
The display board apparently has a weak spot in the design, most likely heat related, (probably low priced components from offshore sources)
Fix: Replace heat damaged capacitor labeled C3 on display board, Hard part will be obtaining the 35Volt 68uF capacitor, I'm lucky enough to have a Brother in the electronics design field who found me a couple of high reliability caps designed for hot applications, He does not recommend changing sizes without design review for fear of overloading another component, however several other posts have indicated that a 35V 100mF cap has worked fine for them.
My control panel was attached to the oven with 4 screws accessed from above the top oven door, the panel slid up about 1/2 " and lifted off, Unplug the ribbon cables and the panel can be removed to a convenient work surface. The display board itself is mounted with 4 screws and connected with a wide flat ribbon cable, the suspect capacitor is surface mounted to the reverse side of the board, two plastic clips need to be released (gently) and the ribbon cable unplugged. Capacitor is likely discolored or leaking, De-solder it and replace with new, match polarity marks and don’t use any more solder than needed. TURN OFF POWER TO OVEN PRIOR TO STARTING ANY REPAIRS.
If you run into trouble drop me an e-mail to [email protected] and I’ll try to help.
Good luck.
Thanks for this site..
Posted on Aug 13, 2009
SOURCE:
I have double wall unit Thermador oven. After self cleaning, the door can not open. Or may be I hit the panel lock , so the door is lock. How to unlock?
Hello April,
If any OVEN FUNTION is being used...
The controls cannot be LOCKED off...
So no... REQUIRES PUSHING 2 buttons & holding
for four (4) seconds... (not likely to be accidental)
The steps to Lock & Unlock are the same...
(see reference page (click here)
Thermador SCD302 Care And Use Manual Child Lockout
Touch and hold the COOK TIME pad and
the STOP TIME pad simultaneously for 4
seconds.
Likewise SELF CLEANING is described in great detail.
(double click this URL)...
Thermador SCD302 Care And Use Manual Page 29
ELSE...
Please contact THEM if you have questions or comments.
Phone: 1-800-735-4328 or reach THEM through their
website at www.thermador.com
Hope this helps
Carnac the Magnificent
Dec 20, 2017 | Thermador Ovens
Thermador oven control panel light is very dim
FixYourBoard.com fixes this problem, and they back their work with a two year warranty!
See the photos of what your new display will look like below.
Feel free to ask questions-- [email protected]
Apr 24, 2017 | Thermador Ovens
The control panel display is so light that it can not be read. I have a double built in oven SCD302. What can be done?
Hello, welcome to FixYa.
There are two common scenarios with these Thermador wall ovens fitting what you've described. The harness to the display from the control board is loose (not likely) or the display itself is failing (most likely).
The issue with these displays is they lose their intensity over time because of the fluorescent tube technology they use, hence the only remedy is to replace the control/display kit...the display only is not available, but a "kit" is.
You can find these "display kits" at "repairclinic.com" and similar to what I've attached here...
**Your other option, and the one I recommend, is to have the existing display and control rebuilt...the down side is this will require the parts to be removed and sent away**
You may find other suggestions or "band aid" remedies on-line, but in my experience this is the sure way to go. Here you'll find all the info pertaining to this option by clicking on the link I've provided below
http://www.corecentricsolutions.com/CCSWeb.nsf/published/bosch
Hope this helps move you forward. Let me know if I can assist you further and good luck.
Regards,
Macmarkus :)
Oct 14, 2011 | Thermador SC302T Electric Double Oven
Thermador Built in oven scd302 not heating upper oven, lower oven fine. Heating element not glowing red as the oven below it does.
Hi.
Problem is usually either temperature probe or heating element.
Grab a multimeter and set it on impedance (Ohms).
Remove first temperature probe and then heating element.
If either probe or element is reading open (ohms infinity), then replace the part.
If both probe and elements are not open, then the problem is either wiring or oven electronic control. The most common fault resulting in no heat is the temperature sensor located inside the oven cavity.
Regards.
Ginko
May 31, 2011 | Thermador SECD302BPSS Electric Double Oven
The control panel is very dim on my Thermador RDSS30 oven
Cannot Read Display or See Temperature Thermador RDDS30
FixYourBoard.com repairs this failure and back their work with a two year warranty.
May 14, 2011 | Thermador Ovens
Thermador SCD302 NO Illumination on Display window
Bullet fuse to control panel Melted due to excessive heat from self clean mode. Just a guess> Typical fuse:49b75ce.jpg
I have a manual around here somewhere Oh yeah in my TIP
Thermador 301/302 wall oven repair manualHelpful?
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 27, 2010 | Thermador SC302T Electric Double Oven
THERMADORE DOUBLE OVEN NEW OLD STOCK
Thermador SCD302 upper oven preheat does not work; the heat temperature goes up very slow.
Sep 03, 2008 | Thermador SC302T Electric Double Oven
Thermador model sc272t oven 2 doors have dim display
there is a dispay kit you can order from bosch to fix this problem. it will come with a new display board and power control which is located behind control panel as well
Nov 18, 2007 | Thermador SC272T Electric Double Oven
Thermador Display
Have 2 Thermador ovens, SMW272 and SC302. Both have display failure. Just repaired one with replacement display. It did not require a new control unit or harness. Have not opened up second unit yet as display is still dimly/slightly visible.
Called Thermador and received no offer of replacement parts or service. Numerous other web reports of similar failures. My neighbor has 2 dead ovens also unfixed because of outrageous repair estimates ($600 each). Do not recommend this brand.
Full kit including display, control, and harness ordered on Ebay for $170.
Sep 21, 2007 | Thermador SMW272 Electric Double Oven
Jenn-Air Electric Double Oven Logo
468 people viewed this question
Top Jenn-Air Ovens Experts
Nathan Van Boven
Nathan Van Boven
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
