Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Problem for Philips 30PF9946 30 in. HDTV-Ready Plasma Television
Screen Problem fixed?
By smackywentz on Aug 19, 2008
Well I managed to fix the dreaded Philips Black Screen of Death.... I think. Nothing worked for me, it wasn't temperature related, or the inverter, or any other board on the back, nor was it the lamp. It turns out it was that I need to lean it forward. Any reason why this would solve the problem. Is there some leveling problem?
Comments:
Aug 19, 2008
- Thanks for the fast response gooruflash. I actually had the back of the screen off and the no cords are pinched. What I am thinking though is the power supply board has a short on the ground. When it is leaned forward the power supply board doesn't touch to its ground after some earlier troubleshooting I tried and a lack of a screw there. Could that be what is wrong?
Same Problem
Nov 08, 2008
-   I have encountered the Philips version of the BSOD (Black Screen of Death) recently. This is with the 32" LCD (Model Number 3)PF9946D/37. After being off for an hour or so, it works well for about 3 minutes and turns black. It turns on again if I switch off/on the TV, but for a shorter period of time.
It is out of warranty.
I haven't yet tried the "leaning" technique. Will check that. Otherwise, I will open the box and see if anything interesting shows up...
BeeGee
-   subra-2008
Solution #1
posted on Aug 19, 2008
Not Rated)
gooruflash
Rank: Wiz
Rating: 83%, 22 votes
There isn't any known issue with this unit that would force you to have to lean it forward, what I would do is disconnect the LVDS cable and check the connectors for corrosion and clean it if neccessary or maybe the set has the chassis pinching in on that cable, I would check for any kinks or pinches in the cable itself
Was this helpful?
Yes
No
Popular Solutions for Philips 30PF9946 30 in.
Questions and Unsolved Problems for Philips 30PF9946 30 in.
Do you recommend Philips 30PF9946 30 in. HDTV-Ready Plasma Television?
Answer
Answer
My Sanyo TV just shut off by itself and I can't get it to turn on again either by remote or the... (More)
Answer
I have a Phillips 30PF9946D TV. The video drops out in response to sudden high input such as a... (More)
Answer
Have you fixed it or gotten rid of it yet? Because if not, I have a solution for you. I had the... (More)
Answer
I use this tv for a PC monitor, HD satellite viewing, and XBOX 360. I was having intermittent... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in Boardman, OH
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
