Singer CSP1 Iron Logo
Posted on Aug 19, 2008
Singer Magic Steam Press CSP-1 will not heat up when turned on now. Can hear it click on but no heating of plate or steam. What is wrong? Can I fix it myself? Where in Tampa, FL can I have it serviced if not?
2 Related Answers
Anonymous
  • Posted on Jul 17, 2009
SOURCE: lost intruction manual Magic Steam Press csp-1
Follow the link or copy it to your browser - http://www.singerco.com/accessories/manuals.html - and search for your Singer.
Kind regards Ryno
Anonymous
  • 43501 Answers
  • Posted on Jul 14, 2010
SOURCE: singer steam press csp-1 iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Circuit diagram for ESP2 singer steam press
I do not have access to specific circuit diagrams for the ESP2 Singer Steam Press. However, I can provide some general information that may be helpful.
The ESP2 Singer Steam Press operates by using an electric heating element to heat a water reservoir, which produces steam to press clothes and fabrics. The electrical circuitry of the steam press includes a power switch, heating element, thermostat, thermal fuse, and indicator lights.
The power switch controls the flow of electricity to the steam press, allowing the user to turn it on and off. The heating element heats up the water in the reservoir, producing steam that is released through a pressing plate. The thermostat controls the temperature of the heating element, ensuring that the water is heated to the desired temperature. The thermal fuse acts as a safety device, preventing the steam press from overheating and potentially causing a fire. Finally, the indicator lights inform the user of the steam press's current operating status, such as whether it is heating up or ready to use.
If you're experiencing issues with your ESP2 Singer Steam Press, it's recommended that you consult the user manual or contact a qualified technician for assistance. Modifying or repairing electrical equipment without proper knowledge or training can be dangerous and may cause injury or damage to the equipment.
Singer magic steam press 7
singer magic 7 is used carefully as it is closely to iron so check if wires are connected correctly
1helpful
Instruction manualfor csp-1 singer
Located here
http://www.amazon.com/Singer-CSP1-Magic-Steam-Press/dp/B00006IV4K
26helpful
4answers
Lost intruction manual Magic Steam Press csp-1
Kind regards Ryno
1helpful
Steam press
Try sew4less.com--has tank & hose for about $16.00. I'm looking for a water tank cap for the same model if you have a source--Thanks
Singer steam press csp-1 iron
heatman101
Top Singer Irons Experts
john h
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Singer Iron Expert? Answer questions, earn points and help others
