Question about Crosley 0187SST Turntable
The ac inside the player is broken
No power runs through the player. the ac adapter is fine though and has power, but when plugged in the light doesn't turn on.
is there any way to replace the power supply in the player?
  • mwblackeye Dec 30, 2008
    Same problem with my CR249 - Crosley Radio Keepsake USB Turntable. After plugging in and turning on the player, the light does not turn on and the motor does not start up.  The player worked fine for 6 months, then stopped.  I checked the switch and it appears to be functional, along with the cord and the the power is being transferred to the plug in the player, but no response.  Wires all seem to be intact...
  • Anonymous May 07, 2009
    our CR249 worked for more than a year and then just stopped. I've checked the AC power adapter and it's putting out the voltage. (18v actually vs the 12v shown on the turntable, but it's the p/s that came with the player)
    Anybody got any solutions?
    Habit-Forming:
  • 15 Answers
I have the same problem with my Crosley Turntable stereo. I've been able to determine the proble is the power Transformer. 115v in, and nothing out. I attached a separate transformer and it powered up. The problem that remains is finding the correct power rated transformer. The transformer that came built in has no information as to it's power rating.
Posted on Jan 25, 2009
OW TO GET MY ACET ASPRE ONE IT STOP BLACK SCHREEN NO POWER
Step by step troubleshooting.
Verify power outlet is good
Verify power adapter is good
verify connection to computer is good
fully charge battery
test
=======do this
Check power source, plug known good light into AC receptical.
If AC cord has connector to power block verify it is properly seated.
plug adapter into AC outlet
Verify Power is present at power connector with another similar computer or voltmeter. (12V to 20V)
When plugged into computer, charge (not power) indicator MUST light either red, amber, or green. If not, connector on computer may be broken.
leave overnight or until charge light is green
turn on normally.
most likely causes:
- loose connector
- broken wire from power adapter
- broken power plug on computer.
- anything else is probably beyond ur capabilities to fix.
Aug 10, 2014 | Acer Aspire One PC Notebook
Approximately 5 weeks ago I started getting the message when on AC power that the "smart AC adapter is not providing enough power" (something like that anyway!) And even though plugged in would...
first, you need to try to power on your laptop with another battery with the AC adaptor plugged in. if your problem was not solved you need to check the power jack on your mothernorad.
Jan 02, 2011 | HP Compaq 6735s Notebook
Our year old Dell Inspiron 1545 currently won't turn on anymore, for the past week it would not charge so we were just keeping it plugged in. It claimed the ac adapter was unknown, even though we had been...
You have a bad or loose DC connector on the system board:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN jack on the system board. If it
Dec 16, 2010 | Dell Inspiron 1545 Notebook
Not charging
which green light?
light from the ac power adapter or the light from the battery?
if ac power adapter you are referring to try a diff power wall socket if ac power adapter still off then replace ac power adapter alone.
if battery light is off but the laptop works fine with ac adapter alone try updating the laptop BIOS.
if ac adapter light turns off when it plug to the laptop replace motherboard.
Oct 13, 2009 | Dell Latitude D531 PC Notebook
Plug is broken
You can buy a new Durabrand Dual car adapter by clicking on the hyperlink:
buy replacement car adapter power charger cord for Durabrand Dual 7b portable dvd player
You can buy a new Durabrand Dual wall ac adapter by clicking on the hyperlink:
buy replacement wall ac adapter power charger cord for DURABRAND Dual 7b PORTABLE DVD PLAYER
Jun 20, 2009 | Durabrand Portable DVD
Acer laptop Aspire 7000 does not power on
If the laptop does not power up (not a slight sign of power flowing through it) even if the AC adapter is plugged into it, here are the possibilities:
1. You AC adapter might be broken and need to be replaced. Some AC adapters have a light on it to signify that there's power flowing from the power outlet to the power cable.
2. If your AC adapter is working fine, maybe your power supply is broken. If your laptop is with in warranty, have Acer replace it. If not, find a repair center who does.
Apr 10, 2009 | Acer Computers & Internet
Sony all-in-one VGC-JS 155 will not power up
Try to power on the computer with no battery inside.
If still no luck, then the AC adapter must be tested by reading voltages on the connector, no matter if light is on. This is done using a multimeter.
If the AC adapter is fine, and the laptop has no power at all , then it is usually a broken solder contact on AC socket on laptop.
All this can be tested at any local repair shop.
Mar 08, 2009 | Sony VAIO PCV-W10 PC Desktop
Battery compartment disconected by the AC adapter
That could be any number of things. Broken solder joint on the board where the battery terminals connect, dead batteries, and now that I think about it, if the connection is broken or loose in any way inside the hole where the ac adapter goes, it's not going to work with batteries. It needs that completed circuit regardless if there isn't an ac adapter inserted.
Jul 14, 2008 | GPX CDPW8806 Personal CD Player
Supersonic SC-299TDVD
Battery back needs to be connected to the DVD player when charging. connect the batter pack to player. Run the DC/out from the battery pack to the DC/in in the player. plug the charger into the wall.
if that does not work, you have a bad battery
Dec 27, 2007 | Supersonic SC-299TDVD
Crosley 0187SST Turntable Logo
356 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
