Question about HP Deskjet F340 All-In-One Printer
No ink, still need to scan
I think I need ink, however am I still able to scan. I placed the document face down under the lid and pressed scan and nothing happens, not even a light. The scanner should work ?
  • kczwart Aug 19, 2008
    It is plugged into the power strip.
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 564 Answers
Sure..is it plugged directly into the wall outlet or a power strip?
Posted on Aug 19, 2008
  • Patrique Davenporte Aug 19, 2008
    then you'll need to plug it directly into the wall..most AIO's need that solid ground to work..
Lexmarx X4975 disable complete-a-print
The Lexmark X4975 Professional is a multifunction thermal inkjet printer that not only prints documents and photos, but also makes two-sided printouts, scans and copies materials and accepts line-connected or wireless device print requests. Three color ink cartridges--cyan, magenta and yellow--and a single black cartridge rest inside an ink cartridge carrier. Printer cartridge replacement is not difficult. Each cartridge is secured in place with a cartridge carrier lid that opens with the simple press of a lever.
  • Turn on the Lexmark X4975 printer. Lift up the entire scanner unit to rest in an open, angled position that reveals the interior of the printer.
  • 2
    Press down on the lever in front of the printer cartridge that you need to replace to open the cartridge carrier lid.
    • 3 Pull the old cartridge from its slot in the carrier.
    • 4
      Grasp the tab attached to the tape covering the electrical contacts and ink nozzles on the back and bottom of the replacement printer cartridge. Pull the tape away from the cartridge carefully without touching the contacts or nozzles.
    • 5
      Insert the cartridge into the empty slot--the electrical contacts facing the back of the slot inserted before the front of the cartridge.
    • 6
      Flip the cartridge carrier lid over the top of the cartridge and then push down on the top of the lid until you feel the lever lock the lid in place.
    • 7
      Repeat the replacement process with the other printer cartridge if necessary. Lower the scanner back into position when finished.
      Increase Engine Horsepower.
Jun 02, 2012 | Lexmark X4975 3-in-1 Wireless Inkjet...
Printer will not scan
he HP All-in-One product displays one of the following error messages on the control panel when scanning or copying:
  • Scanner failure, power off and on
  • Scanner System Failure
  • Scanner failed, cannot make copies or fax
  • Scanner failure. Unable to scan, copy, or send a fax
  • Scanner failure, cycle power
Additionally, the scanner bulb might not turn on during scanning.ry the following solutions in the order presented to resolve the issue. When one of the solutions resolves the issue, there is no need to continue troubleshooting.Solution one: Check the scanner lightFollow these steps to check the scanner light by making a color copy of any document.
  1. Load plain white, unused, letter size paper in the paper tray.
  2. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
  3. Make a color copy.
  4. When the product starts to scan the document to copy, slightly lift the scanner lid to see if the scanner light turns on. It is not necessary to lift the lid completely CAUTION:Do not look directly at the scanner light.The scanner light should be visible under the scanner glass to the right or left.Figure 1: Scanner light visible underneath the glass
    1 - Area where scanner light is visible2 - Scanner glass
    • If the scanner light does not turn on when the scanner mechanism moves across the scanner bed, continue to the solution to reset the product.
    • If the scanner light turns on , continue with the next solution.
    Solution two: Check the power connectionFollow these steps to troubleshoot the power connection.
    1. Press the Power button (c01602202.gif ) to turn off the product.
    2. Unplug the product power cord from any surge protector, extension cord, or power strip, and then connect the power cord directly to a wall outlet.
    3. Press the Power button (c01602202.gif ) to turn on the product.
    4. Load plain white, unused, letter size paper in the paper tray.
    5. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    6. Try again to make a color copy.
      • If these steps resolved the issue , you do not need to continue troubleshooting.note.pngNOTE:If the product works properly when plugged directly into a wall outlet rather than a power strip or surge suppressor, the power strip or surge suppressor might not allow enough voltage for the product to work properly.
      • If the issue persists , continue with these steps.
    7. Press the Power button (c01602202.gif ) to turn off the product, disconnect the power cord from the wall outlet, and then reconnect the power cord to a different wall outlet.
    8. Press the Power button (c01602202.gif ) to turn on the product.
    9. Try again to make a color copy.
    • If the issue persists , continue to the next solution.
    Solution three: Reset the productFollow these steps to reset the product.
    1. Press the Power button (c01602202.gif ) to turn off the product.note.pngNOTE:The product might not turn off after pressing the Power button. Continue to the next step regardless.
    2. Disconnect the power cord from the rear of the product.
    3. Unplug the power cord from the electrical outlet.
    4. Wait 30 seconds.
    5. Replug the power cord into the electrical outlet.
    6. Reconnect the power cord to the rear of the product.
    7. Press the Power button (c01602202.gif ) to turn on the product.
    8. Load plain white, unused, letter size paper in the paper tray.
    9. Lift the scanner lid, place the original face down on the scanner glass, and then lower the scanner lid.
    10. Try again to make a color copy.
Dec 11, 2011 | HEWLETT-PACKARD Officejet 4500 All-in-One...
I have a lexmark 2600 all in one machine. How do I scan more than 1 page at a time?
This photocopier can only copy 1 page at a time. This is due to only being able to place one sheet on the viewing surface per scan.
To make a scan follow these instructions:
  1. Open lid and put the document or photo face down
  2. Close the lid to press the document flat and avoid dark edges
  3. Have the printer connected to the computer and both turned on
  4. Press the scan icon on the printer
  5. Follow onscreen instructions
  6. Repeat for each document needing to be scanned
Sep 14, 2011 | Lexmark X7350 All-In-One Printer
How do you stop a test page from printing every time the printer is turned on?
Welcome to FixYa!
Here's how to stop the unwanted print out of test pages.
1. Let the printer print the test page.
2. Place the printed test page in the scanner face down and wait for 10 seconds.
3. Press the scan button of the printer to scan the printed test page.
Make sure that the printer scanned the document properly.
That's it. Every time you install a new cartridge, the printer aligns the print cartridge as well as testing/aligning the scanner.
Note: Try to look at the top of the test page, it should have instructions to place it in the scanner.
I hope that this will help.
Thank you for using FixYa.
Jas247
Mar 07, 2011 | HP PSC 1315 All-In-One InkJet Printer
How do I scane on my mx310
You will need to plug the printer andcomputer together with a USB cable in order to use the printer's scanningcapabilities. The scanning unit on theMX310 features an automatic document feeder on top of the printer, which willscan multiple pages itself. You can also choose to load documents on thescanning glass, which is covered by the scanner's lid. This is how to do it. 1. Turn on the printer by pressingthe "Power" button until it illuminates and turn on the attachedcomputer. Wait for the printer to finish its initialization process beforecontinuing. 2. Place the document face up inthe automatic document feeder if the document's papers are uniform in andfit in the feed tray. Adjust the paper-width guide to the of thedocument's papers. 3. Place the first page of thedocument face down on the scanning glass after you have lifted the scanningunit's cover, if you choose to not use the automatic document feeder. Close thecover again slowly so the document does not shift on the glass. 4. Press the "Scan"button on the printer's control panel, then press either "Black" or"Color," depending on the type of scan you would like to perform. 5. Retrieve the scanned documentfrom the automatic document feeder's output tray once the scan job is over.Otherwise, click on the "Yes" button on the computer's screen,indicating you would like to scan another page. 6. Lift the scanning unit's cover,remove the document from the scanning glass and place the next page of thedocument face down on the glass. Close the scanner's cover and click on the"OK" button on the screen to scan the next page. Repeat this processuntil all of the document's pages have been scanned.
Jan 13, 2011 | Canon PIXMA MX310 All-In-One Printer
When I load papers into the document feeder on top of my HP Officejet 7210 All-in-One printer to scan these documents, the PDF file (scan results) have a multi-color series of lines from top-to-bottom on...
  1. Remove all originals from the document feeder tray.
    NOTE: It might be easier to work with the automatic document feeder if the document feeder tray is removed first.
  2. Lift the cover of the automatic document feeder. Figure 1: Lifting the ADF coverc00222493.gif
  3. Lift the lid on the HP all-in-one, and locate the notch near the top right edge of the lid backing. Figure 2: Locating the notch near the lid backingc00222494.gif 1 - Notch 2 - Lid backing
  4. Place one or two fingers in the notch, as you lower the lid of the HP all-in-one. Keep your fingers in the notch until the lid is almost closed. Figure 3: Inserting fingers into the notchc00222495.gif
  5. Push against the top of the face plate with your thumb as you pull the bottom away from the right side of the HP all-in-one with your fingers. Use a slight twisting motion to help release the face plate on the right side.
    CAUTION: Do not pull the face plate all the way off yet. There is a plastic catch on the far left inside of the face plate that helps secure the face plate in place. If the face plate is pulled straight off, the plastic catch on the inside of the face plate might be damaged. Figure 4: Releasing the face plate from the right side of the HP all-in-onec00222496.gif 1 - Releasing the right side with a slight twisting motion
  6. Slide the face plate to the left until the plastic catch on the left side is not touching any part of the HP all-in-one, then pull the face plate away from the device. Figure 5: Removing the face plate from the HP all-in-onec00222497.gif 1 - Sliding the face plate to the left 2 - Pulling the face plate away from the HP all-in-one
Cleaning the rollers or separator pad Follow the steps below to clean the rollers or separator pad.
  1. Once the face plate of the ADF is removed, use the blue-green handle to lift the pick assembly. Figure 6: Blue/green handle and the pick assemblyc00222498.gif 1 - Blue-green handle 2 - Pick assembly This allows access to the rollers and the separator pad. Figure 7: The rollers and the separator padc00222499.gif 1 - Rollers 2 - Separator pad
  2. Lightly dampen a clean, lint-free cloth with distilled water, then squeeze any excess liquid from the cloth.
  3. Use the damp cloth to wipe any residue off of the rollers or the separator pad.
  4. If the residue does not come off using distilled water, try using isopropyl (rubbing) alcohol.
  5. Use the blue-green handle to lower the pick assembly.
Reattaching the face plate of the ADF Follow the steps below to reattach the face plate to the front of the automatic document feeder.
  1. Hook the face plate onto the left side of the HP all-in-one so that the plastic catch on the far left inside of the face plate catches on the notch on the front of the automatic document feeder. Figure 8: Hooking the face plate into the left side of the HP all-in-onec00222500.gif 1 - Notch 2 - Plastic catch
  2. Line up the right edge of the face plate with the right side of the HP all-in-one, and then press on the right side of the face plate until it snaps securely into place. Figure 9: Snapping the face plate into the right side of the HP all-in-onec00222501.gif
  3. Place your hands towards the center of the face plate, and press until the center of the face plate snaps into place. You should hear two clicks; one when the left side snaps into place, and one when the right side snaps into place. Figure 10: Finishing re-attaching the face platec00222502.gif
  4. Close the cover of the automatic document feeder.
  5. If you removed the document feeder tray, reattach it.
Dec 07, 2010 | HP Officejet 7210 All-In-One InkJet...
How can I scan to email. I can scan and reprint plus I can scan to memory card
To use this feature in Windows, a destination must be programmed in the scan setup before scanning to a destination. See Set up the product Scan To button.
Load the originals that are to be scanned face-up in the automatic document feeder (ADF) input tray, with the top of the document forward, and adjust the media guides.
Lift the flatbed scanner lid and load the original that is to be scanned face-down on the flatbed scanner with the top, left corner of the document located in the lower-right corner of the glass. Gently close the lid.
On the product control panel, press Scan To.
Use the arrow buttons to select a file destination.
Press Start Scan or OK to scan the document to a file.
Scanning to e-mail is supported by any e-mail program that supports the Messaging Application Programming Interface (MAPI) protocol. Many versions of popular e-mail programs seem to be MAPI-compliant. See the support information for your e-mail program to determine whether or not it is MAPI-compliant.
-or-
Nov 25, 2010 | HP PhotoSmart C5150 All-In-One InkJet...
How do use the Scanning Feature ?
navigate to your scanner through cannon utilities lift the lid lay a document/paper face print side down then press preview document which will scan document after this you will have to save this document somewhere
hope this helps
Sep 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Faxing
if using the feeder probably face up as it will likely pull the document in and invert it to lay face down on the scanning glass.
if you lift up the feeder (like lifting the top of a copy machine), then it would be face down on the glass.
there should be an image on the feeder illustrating how the document should be placed - if it looks like a page with lines on it with a bent corner then it is face up.
Apr 22, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Copier leaves an ink line down the front of the document when fed through the unit.
Hi there if the line appears when you use the document feeder then there is usually either Correction fluid or pen ink on the small piece of glass to the left of the main glass when you open the lid you can easily clean this by wiping the glass with windowlene or some sort of glass cleaner and this will get rid of your problem.
If the line appears when coping from the glass then the printout from the computer will be the same and that usually means that the print heads need cleaning. Take them out and using a soft cloth wipe the print heads clean from any dried toner.
Hope this help you
Thanks J
Jan 13, 2008 | HP 5510 4-in-one Printer
50 people viewed this question
Ben Johnson
