Question about Dremel Variable - Speed Multipro Rotary Tool 395
Have a multip speed dremel 350
The dremel quit running and I replaced the brushes but it still is not running . Do have any solutions?
  • kjsgerard Sep 10, 2008
    I have a 400 xpr and it was a hesitation when it runs and sometimes it will not start unless I give the collet a little twist to get it going. i inspected the brushes and cleaned the area where they run, and the slots looked clean. Any Ideas??
  • Anonymous Mar 15, 2014
    dropped dremel now runs slow and quits sometimes
I have another brand besides the dremel brand and mine quit running also. I ordered new beushes thinking that would fix it but no luck so I opened the tool up and there is a plastic sleeve that is about 1 inch long that has grooves in it and that fit into the gooves of 2 pieces of metal. This is what makes the tool turn. This plastic piece in mine was broken to pieces So that is the problem. I have not found that little tiny piece of plastic and I cannot think of how to improvise to make another one but I am not giving up yet. Any ideas please let me know. I hope this helps each of you. Thanks Mamabear
Posted on Oct 03, 2008
  • 25 Answers
Clean the slots that hold the brushes, sometimes they get cloged and the springs do not push the brushes all the way to the armeture.
Posted on Aug 19, 2008
How can i test if it's brushes or speed switch fault on Piggin Dremel
Problem sounds like the switch. Easy to replace and a lot cheaper than a new Dremel. One other thing comes to mind. Blow out the Dremel with compressed air. I could be to dusty and overheating.
Aug 28, 2014 | Dremel Tools & Hardware - Others
Why does my Dremel run for 1 sec. then switches off If I knock against te side it runs 1 sec before cutting out off
sounds if your tool has a loose or broken brush this is a small carbon object inside that makes motor run, dremel does sell replacement brushes for most of what they mfg. look where ever real dremel bits and tools are sold ck package back to see if your model number is serviced by this brush pack
Aug 16, 2014 | Dremel Tools & Hardware - Others
Dremel 4200 stopped working
No.. the issue issue is the switch inside. when your Dremel 4200 stop working, press firmly the grey area between the speed selector and the brush housing. I think this a defect in the design of the 4200. 9f840401-fb84-4f7b-8c68-75a9be3ceb9e.jpg
Dec 31, 2012 | Dremel Tools & Hardware - Others
Unit wont run at all, yes I do have power, took apart and 1 of the brushes was stuck in slot and it looks like its been really hot.do I need to replace the switch assy. dremel 395 type 4,
I would think that just the brushes, they should slide freely in the slot. check also the condition of the armature for arcing or raised commutator bars.
Aug 07, 2010 | Dremel Variable - Speed Multipro Rotary...
My Dremel 395 type 4 does not run until I spin the chuck and then only runs at high speed.
Sounds like a switch or brushes. You can go to Dremel.com and they have a toll free number for their tech services and you can also download a breakdown for this tool.
Jul 13, 2009 | Dremel Variable - Speed Multipro Rotary...
Dremel 400 xpr stopped working. checked brushes looked ok but replaced with new ones. still not working. tool is still fairly new with only light to medium use.
It could be the fuse between the brush and variable speed control switch. I have the same problem and found the fuse blown. I am hoping that I can replace the fuse without having to buy the complete speed control unit which is about $17.00 from Dremel. If yours is still under warranty you could send it back. If I can find a fuse for mine I will let you know where to get them. joatmontag
Mar 31, 2009 | Dremel 400 Xpr Rotary Tool
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Is there a reset button for a Dremel Multi Pro?
When the brushes go on my Dremel, it just stops, sometimes erratically - no smell or burning.
May 04, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
449 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
