Question about Panasonic NV-DS55B Mini DV Digital Camcorder
NV-DS55B panasonic digital video camera.
Mini dv tape will not load into camera. it goes part way then ejects after a few seconds. fault code F 05 showing in view finder. I have the same problem. When I switch on, I can only obtain camera mode, but when I try to insert a tape there is an unfamiliar whirring sound and the tape is ejected. F 05 is shown in the display.
  • stiwen Aug 19, 2008
    I didn't mention that in spite of only being able to get camera mode, none of the functions such as menu or focus work other than the zoom lever.
    I have also noticed that although the auto/manual switch is in the auto position, rotating the multi-purpose jog dial seems to vary the brightness/contrast of the image shown in the display
    The camera switches off after about 1 min. of inactivity.
  • 4,234 Answers
Unless you have worked on camera before and have the equipment to re-align the parts when you are done, please do not attempt this repair. This can be a simple repair to a servicer. In many cases, there is contamination in the head/drum assembly that can be cleaned up freeing the heads to rotate. Once that is complete, a re-alignment must be done.
Please bring this unit to an authorized Panasonic service center for repair.
Dan
Posted on Aug 19, 2008
    Master:
  • 623 Answers
F 05 fault code = Rotation of the video head has stalled or too fast
it would be better to take it to a repairman
  • 6,487 Answers
Cylinder error (F05) usally caused by poor/oxidised contacts on cylinder drive fpc cable to pcb, sometimes caused by seized cylinder or drive.
The cylinder is the round thing that the tape wraps around that has the heads to record to tape, just in case you didn't know.
  • Mark Gil
    Mark Gil Aug 19, 2008
    This is a mechanical problem already , you may need to dismantle the unit nd check for any misaligned parts...
    Good luck......
Nv ds55b pause record button loose
The little silicone diaphragm spring, which carries a small graphite connector, will have split. There is no glue which will stick to the silicone, so you have to replace it with a new one.
May 23, 2012 | Panasonic NV-DS55B Mini DV Digital...
I cant eject my Panasonic NV-GS55 Mini DV Digital video cassette
Try ejecting cassette whilst powered from AC Adaptor. Secondly, try operating Eject from powered off mode. If operation LED starts flashing after any of these attempts, the mechanism is probably jammed or has become mis-timed. Unfortunately this requires professional intervention to avoid further damage to your equipment.
I hope this information is of assistance!
Jan 01, 2010 | Panasonic NV-GS55 Mini DV Digital...
PANASONIC EX3 MINI DV FAULT CODE PLEASE HELP
Hi
I have the same camera and just had a warner F02 code on my screen and the red light flashed twice. I have just taken out my tape and switched off then switched back on and all the functions are working. Hope this helps.
Oct 06, 2008 | Panasonic NV-EX3EN Mini DV Digital...
Playback problems with previous recorded miniDV
Just check your setting and make your camera in default setting try to use the recommended tapes only
May 05, 2008 | Panasonic NV-DS55B Mini DV Digital...
Panasonic NV-DS55
Try to restthe setting by default setting and try to take out tape if is there inside.
Apr 09, 2008 | Panasonic NV-DS55B Mini DV Digital...
Transferring video from panasonic nv-ds55b to pc
please try to first use in your friends win 98 then you think smething else.
Mar 15, 2008 | Panasonic NV-DS55B Mini DV Digital...
Exactly the same problem as everyone else. There's bound to be someone who can offer advice on what to do. The camera obviously recognises the fault as F05, but where can you reference the remedy to this F05 code? It's not in the manual as far as I can see
Feb 20, 2008 | Panasonic NV-DS55B Mini DV Digital...
No sound or vision playback of dv tape
From my poin of view cyliner (rotary head) have poor conection or this parts will be replace.
Aug 06, 2007 | Panasonic NV-GS11B Mini DV Digital...
Fault indication
I had this problem before.. It is the carrieage that is out of alignment... It cost me £225 approx to send it back and have it re-adjusted... Hope this helps
Aug 17, 2006 | Panasonic NV-DS55B Mini DV Digital...
Panasonic NV-DS55B Mini DV Digital Camcorder Logo
275 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
