Question about Sharp Microwave Ovens
I have a microwave drawer that is about 6 months old. The fan and light and timer work but the drawer will not heat. Model # KB-6025ms. Is there any thing I can try to solve the problem?
  • Sharp Master
  • 9,098 Answers
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
But if the oven light is getting power when you try to cook, but the oven won't heat, the next question is this: Does it sound louder or quieter than normal?
If quieter, I would suspect a relay or connection on the control panel.
If louder, I would suspect a shorted high voltage diode or a bad magnetron.
Since it's less than one year old, it should be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can contact Sharp at 1-800-BE-SHARP (1-800-237-4277) or visit them online to arrange service.
Posted on Aug 21, 2008
The lights and timer go on, but nothing from the fan, turntable nor noise from the magnetron
please follow this test and fix it. God bless you
  1. Check the power diodeThis electronic component is responsible for transmitting current in one direction. If the diode becomes defective it will cause your microwave to not heat. Test the diode and replace it if necessary.
  2. High voltage capacitorResponsible for storing electricity, this part is a key component in any microwave. Remove, discharge, and test the capacitor to determine if it requires replacement.
  3. Damaged magnetronResponsible for generating waves and producing heat. When your microwave is no longer heating properly, replacement will be required.
  4. Thermal CutoffsExamine the thermal cutoffs on both the magnetron and the oven itself. Take off one of the leads and using a volt-ohm meter on RX1, check the terminals. If you get a result other than zero, replace the thermal cutoffs.
Nov 09, 2013 | Microwave Ovens
Have a cookworks microwave model AM821AHT-X2, only 6 months old and just suddenly stopped working properly,not heating up,timer and lights are working but no heat at all.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
Dec 12, 2010 | Emerson Black Microwave Oven
My microwave oven isn't heating my food. Everything else works, the fan, the lights and the keypad. The microwave turns and sounds like everything is working but the food won't get hot. It is only 6 months...
Small component called a diode. Open up the microwave and try to find a black (usually) component that is most often connected between the magnetron (the thing that heats the food) and the chassis of the microwave oven (ground). I used to make a fortune replacing these! Costs about 5 bucks most appliance supply stores. Make darn sure you get one of the same value.
Apr 06, 2010 | Maytag MMC5000 Microwave Oven
Light, fan and timer work but microwave does not
Microwaves are pretty much a non repair item. It will cost you more to fix than it would to replace.
Aug 14, 2009 | GE Advantium 120 Convection/Microwave Oven
My GE spacemaker microwave doesn't heat up foods. There is a slight bit of heat generated but not much. All timers, lights, etc. work normal. It is a GE model jvm1440. It is about 3 years old. The problem...
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Cookworks microwave not heating up
If for some reason you don't have your owner's manual, I would suggest calling the dealer where you bought it to see if they have a number for Cookworks.
Jan 04, 2009 | Emerson Black Microwave Oven
My Sharp R-340D microwave works perfectly but Does NOT HEAT FOOD
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
Sep 22, 2008 | Sharp R-1610 Microwave Oven
Lg LMV1630st stainless steel microwave oven
I'm confused. If it's 6 weeks old, you can get it repaired free.
If it's 1-1/2 years old, the manufacturer will cover the part cost of the magnetron (assuming that's what's wrong) and you will have to pay for labor and any other needed parts.
Also, the subject line mentions a model LMV1630ST while your message body mentions model LMV1680BB.
For Goldstar / LG / customer service, help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here.
Chances are your problem is a bad magnetron, but it may be another high voltage part.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 27, 2008 | Microwave Ovens
Microwave won't heat food.
built in 3/94 is it worth fixing how much for magetron
Dec 30, 2007 | Maytag MMV1153A Microwave Oven
Microwave Ovens Logo
206 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
