Question about Bosch Dishwashers
MY DISHWASHER IS NOT DRAINING. I REMOVED THE DRAIN IT DOESNT SEEM TO BE CLOGGED .
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 108 Answers
Yes i think it could be pump just take hose of and see if its shoots any water ouit into a bucket,if it dopesnt thenb the pump usually
Posted on Apr 24, 2015
  • 706 Answers
When you say that you removed the drain, are you talking about the filter screen and you removed all sediment from previous wash cycles? If so, does your dishwasher drain into and thru a garbage disposal in under your sink? Sometimes that gets clogged and when the DW tries to drain thru that, it just builds up and doesn't empty the DW properly. A quick yet not so painfree check can be to detach the dishwasher drain hose from wherever it is clamped on ( under the sink ) and run the dishwasher thru a cycle //but allow it to drain into a good sized bucket.. If that works OK and you have a good flow .. then chances are your drain system is restricting it from draining.. Conversely, if the DW drains very slowly then there is a good chance your pump, the line into or out of the pump may be clogged or the pump itself is malfunctioning.. Those are the main components to look at..Hoe that helps you !
Posted on Aug 19, 2008
Samsung dishwasher not pumping water out. "delicate" light blinking and it doesnt appear the pump even tries to come on. the machine just stops after wash cycle then I get the error light.
The Delicate light flashing on Samsung dishwashers indicates a drain error. Possibly a pump/motor assy.
Samsung Dishwasher Not Draining
Doesn't sound like a clogged ECS because it's not draining at all.
Jun 12, 2017 | Samsung Dishwashers
Water doesnt drain and water nozzle doesnt spin...but it cycles
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 02, 2011 | Hotpoint 24 in. HDA3400G Built-in...
Kenmore dishwasher 15522000 will not drain at end of cycle I took off front lower panel removed clamp at drain and water is barely dripping
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Jan 07, 2011 | Kenmore Dishwashers
My dishwasher doesnt drain away
Hi
Daniel
Jan 01, 2011 | Dishwashers
Dishwasher will not drain. We cannot get the screen out to check for clogs. There is a grey plastic box that prevents the screen from coming out.
Hi
Daniel
Dec 13, 2010 | GE Profile PDW8480JSS Built-in Dishwasher
Dishwasher is not draining
Hi
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
Dishwasher is draining slower than normal and sometimes doesn't drain at all, I have replaced drain hose...still having same problems.
The drain pump /valve is the faulty component and must be checked , this is at the drain of the chamber and water is flushed . Normally it gets clogged due to dirt accumulation of the dishwasher.
So have it removed ,give voltage to test outside or replace. Also make sure that there is voltage to the pump when the drain cycle happens.
Sep 29, 2010 | Frigidaire FDB1050REM Dishwasher
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Standing water in my kenmore dishwasher after complete cycle
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
z
Jan 04, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Dish washer not draining
hi
If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposal, be sure the knockout plug for the dishwasher was removed when the connection was made
1) Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink), and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line.
2) Once the dishwasher is cool, shut off the power to it, and—if your dishwasher is made to allow this—remove the strainer, located under the bottom spray arm at the base of the cabinet (see illustration). Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, and then replace it.
3) Determine whether the sink trap or house drain line is clogged.
4) If the dishwasher still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repairperson. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
Hope this helps
Nov 08, 2008 | Kenmore Dishwashers
Dishwashers Logo
196 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
