Question about Microwave Ovens
Need to replace Thermostat or Thermal fuse
I have searched everywhere and can't seem to find a definitive location for the thermal fuse. I took off the control panel and nothing seemed to match the pictures or descriptions I have seen. I even looked at the Sears parts diagram and could not find the part labeled.
GE model # JVM2070CH001
Any help you can give me to locate the fuse and thermostat would be much appreciated.
THANKS!!
  • FBDlover Aug 19, 2008
    Thank you so much for your speedy response!
    I need to replace the TCOs because there was a fire in my microwave and now it will not start. Everything looks perfectly fine and it seems the general consensus is that these sensors need to be replaced.
    I suspect the one most likely to be opened is the one in the cavity (#59). I believe I have spotted the one on the "bottom"and the one in the "hood" thanks to your help, but i'm not sure how to access that third one at the top left of the microwave.
    Is there any easy way to access this? or do I have to take the whole microwave down and tear it apart ? :/ I know it varies with makes/models but wanted to know if there is an easier way.
    also, do you think that all the TCOs are bad now?
    Sorry for all the questions!!! Thanks again for all your help.
  • Microwave Ovens Master
  • 9,098 Answers
GE calls them TCOs or thermal cutouts.
There are three in this model and they can all be ordered here.
The reference numbers relate to the drawing here.
REF# PART# DESC
111 WB27X1127 TCO -BOTTOM
59 WB27X10195 TCO -CAVITY
104 WB27X10194 TCO - HOOD
101 WB27X10388 FUSE
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing. It usually shows relative component layout.
Posted on Aug 19, 2008
  • William Miller
    William Miller Aug 19, 2008
    On a built-in, you have to take it down from the wall and then take the outer cover off.
    It's much easier if you have the installation instructions. If you don't still have yours, you can download GE owner's manuals and installation instructions here.
    I recommend two people to take it down due to the weight and awkwardness. It's safer that way.
    The cavity TCO / flame sensor / heat sensor will be on the left top of the chassis.
    Again, the mini-manual usually shows relative component layout.
GE microwave oven fuse? no sign of power
PokMan, Check the attached links,instruction and guides on fuses and thermal fuse breaker. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Where is the fuse located and how do you replace it GE Microwave Oven
GE Microwave Fuse Thermal Fuse Breaker Parts
GE Microwave Oven internal fuse Google Search
Microwave Not Working
Microwave Oven Troubleshooting in MINUTES STEP BY STEP
Jun 11, 2016 | GE Microwave Ovens
Where do i locate the fuse
Although you have not mentioned the model/make, take a look at the video here for replacing a Thermal fuse. Microwave Won Work GE Microwave Thermal Fuse Replacement part WB27X1127
on traditional fuse see
How to Fix Microwave Oven Simple Fuse Replacement
Mar 08, 2016 | GE Microwave Ovens
The part number of the Thermal Fuse? Can anyone confirm that it is WB27X709?
GE WB27X709 - Vent Thermostat. The thermostat opens and closes if it gets too hot in the microwave to run the vent fan.
Oct 28, 2015 | GE JVM1740SPSS Microwave Oven
Yesterday, my sharp carousel r-1460 went dead. I took apart the front keypad and replaced the 20amp fuse behind it. the microwave light and fan work.But, when I start microwave to cook something, pop! fuse...
If the 20A fuse is blowing, it is often the high voltage transformer or magnetron. If this is the case, and the microwave is not under warranty, replace it. Residential microwaves are generally considered disposable. Parts and labor are just too expensive. A magntron or transformer can cost more that half the cost of a new microwave.
Feb 24, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Goldstar mv1502w has no power.Not even on display.
You can find the service manual here.
(Also, the owner's manual is here in case you want it)
I would suspect the magnetron thermal fuse / thermal cutout / thermostat (depending on which it has) or the oven cavity thermal fuse / thermal cutout / thermostat (depending on which it has).
To access some components, namely the oven cavity thermal device, you will need to remove the oven form the wall, in which case the installation instructions are very handy.
You can order L.G. parts from Encompass. Or you can call them toll-free at 866-779-5835.
Mar 14, 2009 | Goldstar MV-1515 Microwave Oven
Overheated microwave
Hopefully the magnetron thermal cutout or thermostat protected the magnetron from destruction!
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 20, 2008 | Whirlpool GH6177XP Microwave Oven
Blown fuse
These items are not expensive
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757868&PPStack=1
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=757867&PPStack=1
Insert your model ( sharp R930AK ) at search tab of link below and select "thermostat/Thermal fuse " at PART TYPE to see parts availability
Jul 05, 2008 | Sharp R-930AK Convection/Microwave Oven
Fire in microwave
Seems like I've answered this one, too.
Two 20A fuses?? In a recent GE?
The interlock is a door switch, not a thermostat or thermal fuse. A thermostat will reset (unless defective) but thermal cutouts and thermal fuses are one-time devices.
If you or someone you know wants to look into this, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
NOTE: There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
May 22, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 2.0 Microwave just died!
If you're getting power at the outlet, the most common problems causing a "dead" condition are a bad thermostat (or thermal cutout / thermal fuse) on or near the magnetron, a blown internal fuse, or a problem on the control circuit board. I would suspect the thermal cutout / thermal fuse in this case. You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383 If it seems to be a problem on your control board, we repair these for $39.95 nationwide in most cases. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk If you need more help, feel free to follow up here, but please include your model number (e.g. JVM1190, etc.) I appreciate your thoughtful rating of my answer.
Oct 02, 2007 | GE JVM1190 Microwave Oven
Microwave Ovens Logo
1,104 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
