Question about HP iPAQ RX3715 Pocket PC
Ipaq rx3715 won't reset.
I have an ipaq rx3715. I have done a hard and soft reset and it only goes to the HP screen. I've taken the battery out for 24 hrs. and also removed the SD card. It still won't takeme to my Ipaq homepage.
  • mcluxton1 Sep 28, 2008
    Hi Bogdan,
    Active sync did not recognize my Ipaq 3715. Nothing came up. The only time I see anything on my ppc is when I have the power cord plugged in and then I see the HP Ipaq Mobile Media Homepage. I tried to download mtty.exe and it keeps showing "com port 2" but when I click yes to download it to com port 2 it doesn't do it. Could you give me some instructions on how to load mtty. I've done some searching on the web but haven't found how to do this and I have no clue. Again, I want to thank you for your time trying to help me. It's very much appreciated.
    Regards,
    Mike
  • Motoi  Bogdan
    Motoi Bogdan May 11, 2010
    Please try the following:
    Charge the ipaq for 2-3 hours then connect it to an usb cable to your computer. Check to see if active sync does recognise it. If it does a rom update would solve the problem. If it doesn't you'll need to get a small program called mtty and run some bootloader commands. Then the device will accept a new rom software install.
    Please let me know how your device behaves when connected to active sync and I'll explain the next steps.
    Bogdan
    Novelist:
  • 164 Answers
The description you are providing indicates the PDA has problems in uploading the booting firmware to the memory.
Unfortunately, this means that it needs a professional technician to open and perform a diagnostics on it to fix it.
It may be a defective integrated circuit, or moisture or humidity that got inside de PDA.
Some times is possible to fix it with minor internal cleaning or with minor replacement of electronic parts, but other times is possible to fix it only with the replacement of the main board.
Bottom line, you need to have a quote for diagnostics and repair of it, and make the decision if is better for you to repair it or buy another one.
Best regards,
Posted on Aug 25, 2009
I want to restart of shut down my HP iPAQ rx3115
For the HP iPAQ rx3115 and rx3715 models, hold down the Mobile Media button (on the far left) and the iTask button. Then press down the reset button with the styles for a few seconds until the screen goes dark.To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Mar 01, 2011 | Cell Phones
Itask button not responding & 5 way navigation will not scroll down when depressed
There are two things you can try:
1)remove the battery and reinstall it back
2)Go for a hard reset
Aug 05, 2008 | HP iPAQ RX3715 Pocket PC
My Ipaq rx3715 won't charge. "AC only"
its obsolete now, why use this thing?
wait for battery? then post?
or go to HP and ask them,
we are not HP, this is chat bs boxes here.
ever heard of HP? this is the official HP forum, try it?
If HP cant help you who can,
learn this ,when compelled to mess with obsolete products
buy 2 of them for like $3 on fleabay (most are in the trash now)
then mix and match parts, all day.
its obsolete, so doing tests on it lacking full spares is impossible.
why not buy a $3 used smart phone from same place,
https://h30434.www3.hp.com/
Aug 04, 2017 | HP iPAQ RX3715 Pocket PC
The PC is not switching on
Hi. I assume that you plugged in your original battery after it was out a while. When your device's battery is drained, all the data in your device may be resetted (changes according to your backup battery's condition). So you should first try to plug it into AC power source for a couple of hours without touching it (Let the battery become usable enough). Then, your device should open without any error, but it may take a while because it will install the Operating System from ROM. In most cases, pluging out your battery won't destroy any internal parts of your device, it may just reset it to factory default settings. If there is an error, here is how you can hard reset your device:
HP iPAQ rx3715 Hard Reset:
1. Hold down the Mobile Media button (on the far left) and the iTask button.
2. Then press down the reset button with the styles for a few seconds until the screen goes dark.
3. To turn on your HP iPAQ after your hard reset, either press the reset button again, or plug it into an AC power source.
Hope this helps.
May 31, 2009 | HP iPAQ RX3715 Pocket PC
Hp ipaq 3715
Hopefully you can do a warranty repair, I'm pretty sure the main board is damaged since a hard reset should have taken you back to the factory defaults.
Dec 10, 2008 | HP iPAQ RX3715 Pocket PC
Lying ipaq H5550!
It's a problem with either the memory board or the button board. With my h5550, the bottom buttons started to stop working and eventualy the PPC stoped charging all together. You can find parts for it online. If all the buttons are working fine, then it's most likely the motherboard. Otherwise it should be the button board.
Dec 29, 2007 | HP iPAQ H5550 Pocket PC
HP Ipaq rz1710
Have u recharged it????
try to reboot it. there is a small hull in the bottom on left side, push in it with the pin u have tp your PDA. that will reboot the system
Sep 16, 2007 | HP iPAQ RZ1710 Pocket PC
Ipaq RX3715 hard reset
hard reset: Button 1 and 4 and press reset button with stylus
Jul 11, 2006 | HP iPAQ RX3715 Pocket PC
Hanging
Do you think you could provoke a hard reset by leaving the battery out overnight?
Sep 08, 2005 | HP iPAQ RX3715 Pocket PC
Rx3715 will not recover from a hard reset
try removing the battery - for a few minutes to begin witj, then a few hours if that doesn't help.
Sep 08, 2005 | HP iPAQ RX3115 Pocket PC
HP iPAQ RX3715 Pocket PC Logo
488 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
