Question about Panasonic PT-47WX42 47" Rear Projection Television
Power blinks 3 times, no pic, no sound
Do I need to order 2 convergence ICs they are STK392-110?
Thanks
  • Panasonic Master
  • 8,617 Answers
Yes 3 blinks means convergence, and yes they are both STK392-110 you can get replacement ICs at the following link with free installation instructions with pictures.
http://servicemanuals.vstore.ca/
Posted on Sep 04, 2008
I have a Panasonic Projection Monitor PT-47WX52C.When I turn on power it blinks 3 times .What do I have to do to repair it? Thanks Kathy
You will need to replace both convergence ICs and also possibly the associated low ohm resistors, since the 3 blinks is indicating that the convergence has failed. The PT47WX52 convergence repair kit is available from www.tvrepairworld.com which has the two ICs , heat sink paste, low ohm resistors and the CD with repair instructions.
Aug 22, 2011 | Panasonic PT-47WX53 47" Rear Projection...
Blinking power light
Power light blink 3 times shows that convergence out ICs got defective and need to be replaced.
If you are handy with electronics stuff repair and can solder parts in circuit board with proper tools then replace two big black ICs, convergence out, mounted on aluminum heat sink.
Or call local tech to fix it.
Let me know if you have additional question.
Thanks.
Dec 23, 2009 | Panasonic PT-53TW53 53" Rear Projection...
I have a jvc/av-65wp74 unit. The screen went blank and made a pop,pop,popping sound. we could not shut it off with the power button, which was blinking off and on. We had to unplug from the wall. we waited...
Try unplugging the Convergence amp board, which is located behind the speaker grille. If the set will power up with the Convergence amps unplugged the ICs will need replacement. I have seen many JVC in both the WP30 and WP74 pop through the speakers when the ICs short. Unplugging them takes them out of the equation and the set will power up but the pic will have severe convergence issues.
Dec 03, 2009 | FixYa Service
Panasonic projuction screen tv.
3 blinks is the error code for the convergence ICs. You need to replace both STK392-110 convergence ICs. You can get replacement ICs at the following link and they provide installation instructions with pictures.
Oct 12, 2008 | Panasonic PT-47WX42 47" Rear Projection...
CONVERCENCE PROBLEMS
did you replace the convergence resistors with the ICs? Often the resistors will need to be replaced also when new ICs are installed. 3 blinks means convergence Failure so its either the solder connections on the ICs or the resistors need replacement. If you need more assistance please let me know.
Sep 27, 2008 | Televison & Video
Panasonic TV
thats the error code for convergence. You will need to replace both convergence ICs they are STK392-110 you can get replacement ICs at the following link with free instalation instructions.
Sep 04, 2008 | Panasonic PT-53WX53 53" Rear Projection...
Blinks
you need to replace both convergence ICs that is what the 3 blink error code is for your model. You need two STK392-110 Convergence ICs you can get replacement ICs at the following link with free instalation instructions.
Aug 13, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Replaced convergence ics but now power light blinks 3 times
Your model will not work with STK392-115 in fact I have never heard of those ICs.
Aug 06, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Hewhen lp
The convergence ICs need to be replaced. # blinks is the error code for the convergence. You will need two STK392-110 Convergence ICs you can get replacement ICs at the following link with free shipping and free instalation instructions with pictures.
Jul 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Tv repair
My Tv was doing the same thing, and I had to unplug the set in order to get rid of the blinking light. And what i did was to turn the power on and as soon as i saw the picture i turned it off, I did this 5 times and on the 6th time I let it power and tv stayed on, however something did happend to my set, i found that my convergence was wacky. Tried to center convergence but i could not center the blue. Turns out, i think the problem is with my Convergence ICs that went bad. I can still watch tv but the Image has blue color shadows and the picture slightly bows inwards from top and bottom. To sum this up, i will need to replace 2 ICs, IC C5AA00000203, and this should fix my problem. I will do this repair myself, each part is about $41..
Let me know what happened to your problem.
Thanks
Tony
Dec 01, 2007 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-47WX42 47" Rear Projection Television Logo
55 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
