Sandisk sansa fuze mps player plays but the screen is blank, why?
Mp3 plays fine.... screen was on, after charging... screen was blank when went to turn on
  • 1 more comment
  • phe1 Dec 30, 2008
    I charged the fuze and then when I turned it on the screen lights up but is blank. It plays music you just can't see anything.
  • Anonymous Jan 11, 2009
    i sturned on my sansa fuze and it was blank
  • Anonymous Mar 13, 2014
    When turned on, it shows "Loading firmware file not found" Plays fine hooked to lap top and continues to play when unhookied as long as its not turned off.
  • 13,434 Answers
Is it still covered by warranty? do you see anything on the screen for example if you place it under a lamp, do you see anything on the screen? that would mean the backlight is faulty.
you may have a faulty backlight or loose connector. If you got warranty that will cover the fix.
warranty and user guides
http://www.sandisk.com/Retail/Default.aspx?CatID=1679
you can also try updateing the firmware of the device. sandisk website go over here
http://www.sandisk.com/DriverDownload/index.asp
select your sansa fuse from the list, click find driver
on the new page select sansa firmware updater click continue
click skip registeration
download the firmware updater
install the updater
plug in the device when asked and follow on screen instructions.
Posted on Aug 19, 2008
SOURCE:
Whtie screen only after charging
Push the the On Button Up while Clicking Home at the Same Time. Once The Screen is Black, Turn On the Sansa Fuze and it should be fine.
Apr 21, 2011 | SanDisk Sansa Fuze MP3 Player
Can i play SanDisk Sansa Fuze 2GB MP3 Player while charging
It depends. What's charging it?
If it's connected to a computer's USB port, then no, you can't listen to it.
If it's connected to a USB charger, such as you might find for cell phones, then yes, you can listen to it.
May 14, 2010 | SanDisk Sansa Fuze MP3 Player
Theres a blank screen after charging mp3 it wont turn off
Press the power and the Play (>||) button together for 20 seconds to reset the unit
Feb 28, 2010 | SanDisk Sansa Fuze MP3 Player
.my MP3 sansa turns on but it's a white blank
my daughters MP3sansa was just charged then it turned white screen
Dec 29, 2009 | SanDisk Sansa Fuze MP3 Player
Screen went blank
Hi, I experienced the same problem this morning, my sansa player (e280, 8Gb) froze in the middle of a song, the screen went blank but the wheel still had its blue light on and i didn't know how to fix it bur then i figured how. If that's the case with your player too, then the solution will be to press and hold the power button till the blue light goes off (abt 8-10sec) and then just restart the player. It should work.
May 08, 2009 | SanDisk Sansa Fuze MP3 Player
How to unlock sandisk sansa fuze
Please follow this link to obtain the manual for your device...
http://www.sandisk.com/sansa/assets/English/products/Fuze/fuze_userguide_en.pdf
I hope that helps..
Please rate accordingly
Thank you
Computerrep
Jan 23, 2009 | SanDisk Sansa Fuze MP3 Player
Blank screen
Typically this is an indication that your battery is dead. If the music is still playing but the screen is blank I would say a hardware failure and replacement would be the best option.
Jan 06, 2009 | SanDisk Sansa m240 MP3 Player
921 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
