Question about Hitachi 50V710 50" Rear Projection HDTV-Ready Television
Power button my tv has a long delay when I hit power off to turn the tv off
  • 3 Answers
That's normal. just a cool down period.
Posted on Aug 28, 2008
Panasonic tc-p50c2 won't turn on
Probably the A board faulty, Visit this site on Youtube
https://www.youtube.com/watch?v=awnrE3k_G2M
Oct 19, 2015 | Televison & Video
Ge adora washing machine beeps when pushing start with door closed
Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal. Post any error codes.
Dec 07, 2012 | GE WSXH208A Front Load Washer
Have PT50LC13 that will not light up when power button is turned on. The power button just blinks orange 5 times consecutively with a 2 second delay between intervals.
The light flashes 5 times consecutively with a 2 second delay becuase it denotes there is some internal problem in the TV.So please consult your near by service centre.They will come and fix the problem.You cannot do anything .
Thanx
Jul 23, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
T.v. turns on but won't stay on
You need to replace the power source part in your tv. This is what's causing the problem.
Jul 17, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Delayed turn on
The power supply board is beginning to fail and you will need to have it repaired or replaced. Samsung is covering the cost of repair on some models for this problem. You can call 1-800-samsung to find out if yours will be covered.
Mar 24, 2010 | Samsung LN-S4041D 40 in. LCD HDTV
07lg lcd with dvr is delayed to turn on but has no pic or sound
I would contact the dealer & arrange for a service engineer, this problem can be related to an older version of software in the TV & would need to be upgraded, which can only be done by the repir centre.
Sep 12, 2009 | LG 42LC2D 42 in. LCD HDTV
Logitech Harmony 880 LCD / TV screen ''check signal cable''
This is a configuration problem. My guess is that when you set up the "Watch TV" Activity, the input source was not properly selected. Remember, you should almost never need to control devices separately,(as you would with a typical remote). In fact, the only time you need to specifically control a device would be a situation where you need to access a little-used function that was not programmed as part of an 'activity'. Sometimes, you may need to control a device to tweak an activity that did not start correctly, but apart from these situations, you will almost always be concerned with starting "Activities". This is very different from your typical universal remote! Instead of operating 'devices' like your TV, cable box or DVD, you configure and select "Activities" that automatically control the devices that are used during that activity. So, go back into the Logitech software and make sure that your Watch TV activity is selecting the appropriate input. If everything is setup correctly, and you still are unable to go to the correct input, you may need to adjust some of your delay settings, especially the Power-on Delay. Power on delay is the amount of time it takes for the device to turn on and start accepting IR commands. On most electronics when you first turn them on if you hit other buttons too quickly the device will not respond to them. This delay helps to keep that from happening. Hope this helps!
Dec 10, 2008 | Logitech Harmony 880 LCD Remote Control
TV won't turn on, delay/timer light flashing
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
Dec 02, 2008 | Sony KV-27S45 27" TV
I HAVE A 2004 CHRYSLER PACIFICA AND THE HEATER MOTOR SOMETIMES DOES NOT WORK IT SEEMS IF YOU CYCLE THROUGH ALL OF THE OPTIONS IT THEN STARTS TO BLOW. IF I HIT THE RECIRCULATION BUTTON IT SOMETIMES BLINKS.
Have you run the recalibration sequence for this? you put the ignition in the on position, then hold down the power and recirculation buttons for five seconds until you start getting flashing lights on your led panel. Let it finish flashing - 20 seconds to two minutes. That will recalibrate your driver/passenger side modes. The other thing is you do know that the pacifica is equipped with a delay, if the delay is lit up on your panel, it counts down so many minutes until the engine is warmed up and then your heater will blow, while it is in delay mode the blower automatically shifts to the lowest setting. hitting buttons like you said, you are probably eventually turning off the delay and then the blower motor will kick up.
Nov 04, 2008 | Chrysler Pacifica Cars & Trucks
Ge Adora front load washer not working
I don't know how you could have got it into diagnostics mode by accident - - but here's how it goes . Hit the power button until there is NO display . Unplug and wait a minimum of 30 seconds , plug back in and within 30 seconds hit SIGNAL button then DELAY START button then SIGNAL button again then DELAY START button again. door should lock and display t01 It is now in test mode . There are 14 different test it can run through in this mode , but all we are trying to do is check for error codes now and maybe get you back to normal, So turn the knob one click clockwise and hit the START/PAUSE button and see if any error codes come up. To exit the diagnostic mode - hit signal button then delay start button then signal button then delay start button and you are out of service test mode and back to normal
Sep 30, 2008 | GE Energy Star 3.7 IEC Cu. Ft. Front Load...
Hitachi 50V710 50" Rear Projection HDTV-Ready Television Logo
37 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
