Question about Honeywell Heating & Cooling
During a violent thunderstorm, our air conditioner unit stopped working. The unit looks ok, but I wonder if the thermostat might have been surged?
    Problem Solver:
  • 7 Answers
Turn fan from auto to on, if it comes on low voltage should be ok.
Unit may have a breaker or fuses located inside if it's a package unit.
Posted on Aug 19, 2008
My power was cut off ....it was off for one
If the power was OFF because of a thunderstorm or electrical outage, it may have experienced a sudden SURGE of electrical energy which may have caused the windings within your transformer to OPEN. Or, a sudden SURGE of electrical energy may have caused damage to your START/RUN Capacitors in both your OUTDOOR and INDOOR units.
Aug 30, 2014 | Heating & Cooling
Where is the fuse box?
Does the indoor unit run?
It sounds like you're looking in the right place. Check your power panel for a tripped circuit breaker (maybe more than one) or if the home is older, it may have fuses. It's possible that the outdoor disconnect also has fuses but that's not as likely. You can check around the outdoor unit and see if you smell anything burnt.
You can aso turn off the unit at the thermostat, wait a few minutes and see if the unit starts back up, but check the items listed above first.
Jul 17, 2010 | Goodman CKL42AR42 Air Conditioner
We had a thunderstorm and my thermostat died (carrier), now my upstairs unit is not working!
You amy have a blown fuse in your AIr Handler. There is a small 5 amp auto fuse on the fan board on the inside unit. You can replace this yourself. Just open up the panel and you will see on top a solid stae board with a 5 amp fuse plugged into it. Shut off power before you do this ok. Rud
Jul 18, 2009 | Heating & Cooling
My maytag m7y12f2a stopped working is their any reset buttons
All devices that have circuit boards or digital displays need a surge protector or turn off during storms. If none of the functions or dispays don't come up, there may be an inline fuse on the panel. More than likely the board or transformer is fried. For that you need a Tech.
Jul 09, 2009 | Heating & Cooling
Stopped working smells like something burned?
If this is a ducted unit with a wall mount thermostat, remove the inside cover from the AC unit. There is a silver box with the electronics inside. Remove this box and remove the cover. Visually inspect the connections where the 120VAC connects. If that looks ok, then check the relays on the printed circuit board. If these look burnt, replace the control box. If they look ok, check to see if there is power coming in to the unit. If not, check the breakers and make sure they are ok.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
AC/Heatpump units cycle numerous times blowing ambient air.
If the compressor never kicks in, I would check the start capacitor, thermostat and the compressor windings. Most times the start capacitor is defective. Some window air conditioners the fan will run while the compressor stop through the thermostat switch. If the thermostat switch is bad every thing runs except the compressor. Let me know, Thanks, Sea Breeze
Feb 07, 2009 | Dometic Rooftop RV Air Conditioner
Heater/ac unit does not work after power surge during storm. Thermostat still works.
there is usually a built in delay if power in interupted.Usually 5 minutes.
Aug 05, 2008 | GE Heating & Cooling
13500 unit will not come on year 2000
Assuming you have central air (controlled by a wall thermostat), chances are the control unit in the A/C was hit by the thunderstorm. These are fairly common to be ruined by power fluctuations and bad weather as is the control unit in the refrigerator. The controls unit "runs" both the cooling and heating. If you ever notice right before your furnace turns on, there is a clicking noise in the A/C. Thats the control unit. It tells what "system" to turn on They are not cheap. They are about $150-200. The best thing you can do is unplug your unit when not in use. I have replaced TONS of control boards, etc. because people leave their unit plugged in and they have been hit by bad weather. Good luck and happy camping.
Jun 18, 2008 | Dometic Rooftop RV Air Conditioner
Compressor is not kicking in
Probably power surge shorted out the main board. If so it will need to be replaced. Gotta call for service.
Jun 09, 2008 | Danby Portable Air Conditioner
Heating & Cooling Logo
51 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
