Question about Sanyo DS31520 31" TV
TV Won't power on
The TV was on, playing fine with no signs of trouble when it shut itself off and now won't turn back on when using the remote control or the 'on' button located on the television .
  • 4 more comments
  • scottj671 Aug 19, 2008
    Thanks. Will have someone check that out
  • Anonymous Sep 24, 2008
    I have the same problem
  • HarleyJeff Oct 23, 2008
    I turn TV on using ON button. 15 minutes later it shut off by itself and wouldn't power back up utilizing either power on button or remote.
  • Anonymous Oct 28, 2008
    I WAS WATCHING TV AT NIGHT AND IT TURNED OFF OK. IN THE MORNING WHEN I CAME TO PUT IT ON, IT WON'T COME ON WITH THE REMOTE OR MANUALLY, WHAT COULD BE THE PROBLEM?
  • Anonymous Dec 12, 2008
    yes, my tv was on playing just fine I walk out of the room and when I returned it had done shut off and would not come back on.
  • Anonymous Dec 26, 2008
    my rca turns on then right back off within 5 seconds someone help i need my tv
    Champion:
  • 230 Answers
Maybe need replaced Capacitor beside relay ( 470uf 25v).
Posted on Aug 19, 2008
Sylvania 32 inch LC320ssx
It seems that the set itself changes inputs. Place it remote control away from the vicinity of the tV. and check. If it does the same, do a hard reset next. To make it a hard reset, unplug the TV from AC mains wall socket, and replug it back after 10 minutes or so. If these do not help you, be sure that the main system control memory IC to it is faulty and should be replaced.
Jun 05, 2013 | Televison & Video
What's the matter with my Mitsubishi Big Screen Tv Model VS-5041?
just re-read the trouble-shooting section of your owners manual and check the setup on your remote
May 26, 2013 | Mitsubishi VS-5043 50" Rear Projection...
Why won't tv turn on by remote or power button unless we try 4-5 times?
My TV has the same problem.
At first, it was an issue with the button itself, somehow some gunk got down under the button and kept it from pressing down all the way most of the time.
A few days after we fixed that, it started to mess up again, this time it was an issue with the way it transmitted signal to the TV.
If the button being blocked isn't the issue, replace the batteries. If the batteries aren't the issue and you don't have a soldering gun, then you'll need to purchase a new remote.
I bought one from walmart for ten dollars and it works just fine for basic use.
Jan 15, 2013 | Televison & Video
The TV will turn on from remote many times and then won't turn on at all from the remote or directly from the TV itself so we end up unplugging the power which seems to reset the TV and then it
Having to unplug suggests a issue where the set is getting confused, if using any kind of box for signal or have a receiver in line remove power from all and after several minutes plug back.
Dec 17, 2012 | Vizio VS420LF1A TV
My RCA Truflat T.V won't turn on and the FPA lock is turned on, I have the original remote. what should i do?
TV won't turn on • Press the TV button. Make sure the TV is plugged in.• Check the wall receptacle (or extension cord) to make sure it is "live" by plugging in something else.• Something might be wrong with your remote control. Press the POWER button on the front of the TV. If the TV turns on, check the remote control solutions on page 26.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).Buttons don't work
• If you're using the remote control, press the TV button first to make sure the remote is in TV mode.• The front panel controls may be locked (disabled). Use the remote control to unlock the front panel controls by selecting the Lock Fr. Panel in the PARENTAL CONTROL menu and press OK (box won't have check mark).• Unplug the TV for two minutes and then plug it back in. Turn the TV on and try again.TV turns off unexpectedly • Sleep timer might have been activated. Go to page 24 for instructions.• KidPass might have been activated. Go to page 21 for instructions.• Wake-Up timer turned on the TV and no remote or front panel buttons were pressed for two hours.• Electronic protection circuit may have been activated because of a power surge. Wait 30 seconds and then
turn on again. If this happens frequently, the voltage in your house may be abnormally high or low.
• Unplug TV. Wait five minutes. Plug it in again.
Sep 16, 2011 | RCA 20F420T 20" TV
Tv just shuts off by itself
Don't use the power button on the t.v. itself to turn power on or off. Use the remote. The power button actually gets "stuck" and causes the t.v. to turn on and off, seemingly at its own accord. Make sure the button is all the way out and flush with the cabinet, then just use the remote to power on/off. Hope this helps.
Mar 28, 2009 | Samsung DLP HL-P5663W 56" TV
TV Won't power on
1. Check Power
2. Check Fuses
3. Check Relay
WARNING HIGH VOLTAGE: Do not attempt to work on your set unless another human being is present who is trained in CPR.
Thank you for selecting FixYa!
azkeyz@fixya.com
Wizard Division
Sep 24, 2008 | Televison & Video
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Remote was hit, shut set off, and can't get it back on. Sounds like timer is on.
    First try turning the TV on from the Power button the set itself (assuming it has one).
    If not, unplug the TV from the wall, wait a half hour, then plug it back in. It should come back on.
    Also check that none of the buttons on the remote are stuck down, and that the batteries in the remote are OK. The toy might've stuck a repeating button down (like volume) which may have then drained the remote's batteries.
    Apr 07, 2008 | Televison & Video
    Sanyo DS31520 31" TV Logo
    147 people viewed this question
    Top Sanyo Televison & Video Experts
     Grubhead
    Grubhead
    Jerry Greenberg
    Jerry Greenberg
    Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
