Question about Dell Inspiron 700M Notebook
How to install 1GB memory card ??
How do I find slot for memory card??
  • 2,028 Answers
One slot is under a panel on the bottom of the machine, and the other slot is under the keyboard. Here's a link to the service manual for the 700m, it covers just about everything. If you need any further assistance, just ask.
Posted on Aug 21, 2008
Does the acer aspire 5315 2077 require a certain type of memory?
Go to and click on the scan my system button to see what configuration of Memory Modules are installed on your laptop.
Here are some other details:
Each memory slot can hold DDR2 PC2-5300 with a maximum of 1GB per slot.
Chipset: Intel 960GML
Drive Form Factor: 2.5"
Drive Interface: SATA
Maximum Memory: 2048MB
Slots: 2 (2 banks of 1)
Standard Memory: 512MB removable
USB Support: 2.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR2 memory with support for DDR2 PC2-5300 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: Yes.
Jan 14, 2010 | Acer Aspire 5315 Notebook
How do I install a 2g stick of memory into gt5408 ? What nvidia video card can I use to upgrade from the Intel graghics card for around $100. ? Thanks in advance for your responses !
Gateway GT5408/H has 4 slots for memory. Each memory slot can hold DDR2 PC2-5300 or DDR2 PC2-6400 with a maximum of 1GB per slot. It will not support a 2GB stick.
ZOTAC GeForce 9600GT Eco 512MB cards are about that range and give you a good warranty as well.
Oct 05, 2009 | Gateway Computers & Internet
Is it possible to install high desnsity memory RAM on a T42
The T42 can support up to 2 Gb of RAM.
The laptop comes with 512Mb of RAM under the keyboard and a spare memory slot on the bottom of the laptop.
To install 2Gb of RAM put 1Gb in the memory slot under the kerboard - need to remove the old RAM and put the other 1Gb in the memory on the bottom of the laptop
T42 Memory specs.
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Sep 22, 2009 | IBM ThinkPad T42 Notebook
Adding memory to a a75-s211
How much memory did it have before you removed the 256Mb RAM?
If it had 756Mb RAM then the memory in the laptop has 512 Mb plus 256 Mb RAM modules, the 256Mb in the slot you can see and possibly 512Mb in a slot under the keyboard or soldered on the motherboard.
Therefore by removing the 256Mb and replacing with 1Gb memory module will give you a total of 1.5Gb
Jun 22, 2009 | Toshiba Satellite A75-S211 Notebook
Can i install 1GB ddr2 on P4VMM2 Motherboard? i want to upgrade my pc; board is: can i P4VMM2 Motherboard; cani i use 1GB ddr2 on this and a 512 MB if vid.card?
Unfortunetly you cannot use ddr2 memory on this motherboard. The motherboard supports only PC2100/PC1600 DDR memory if you have version 8.1 of the motherboard. If you have v5.0 of the motherboard than you can only use sdram or ddr 266Mhz RAM. The same goes for the video card. The p4vmm2 motherboard is a rather old motherboard so I don't think it will payoff to upgrade the computer. It will be probably the best if you buy another computer.
best regards
Mar 23, 2009 | EliteGroup P4VMM2 Motherboard
Installing 2GB of memory in my Fujitsu Siemens Amilo Pro V2020
Here is the problem, the laptop take 2GB RAM. 1GB in each slot, so get 2X1GB RAM. They are cheap now. You need 2, 1GB sticks of ram. For cheap prices go to
Have a nice day!
Dec 22, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
Jun 25, 2008 | Intel D102GGC2 Motherboard
Memory card installation
does your motorola Razr have a Memory Card Slot?
is you Razr model is V3re or V3 only.. (this models doesn't have MMC slot)
is your razr is V3i or v3x or v3xx then the MMC slot is located at the back closed to SIM card.
Jun 09, 2008 | Cell Phones
MicroSD upgrade
You can add more storage memory for your device by using microSD cards. You can plug the microSD card into the slot provided on the player and then store your files on the card. If you had a 1GB player and added a 1GB card you've effectively doubled your memory. That's probably the memory upgrade you're thinking about.
Mar 18, 2008 | SanDisk Sansa e260 MP3 Player
Dell Inspiron 700M Notebook Logo
42 people viewed this question
Alun Cox
