Question about InFocus Proxima UltraLight X350 Multimedia Projector
I have an Infocus X3 projector. All of a sudden, on the right side of the screen, there is a dark band, about 12 inches on a one hundred inch picture. The band is not black , but it darkens the image in this section. I've restarted the projector and it is still there. There are no error messages in service, and the green light is on meaning the bulb is ok.
  • Anonymous Nov 26, 2008
    I have the same problem with an infocus x1a, it shows a grey & browm band from top to bottom of the screen on the right margin. Could this be the bulb
  • nicksterkell Dec 02, 2008
    i have a dark line down the righthand side of the image shown from my infocus x3 projector
The light tunnel is between the color wheel and the mirrors. It is a square 4 sided tube, the inside is a mirror finish. the tube is either broken or the glue holding the assembly together has given out allowing the mirror to partially block the light. Advanced repair
Posted on Dec 18, 2008
Check out joemeister's post on 9/15/07 here:
http://www.avsforum.com/avs-vb/archive/index.php/t-618877.html
Posted on Jan 03, 2009
InFocus X3 plastic lens
If you still have the owners manual there should be an 800 number or some sort of customer support for it. Unless it's really old that is your best bet for the internal pieces
Nov 23, 2012 | InFocus X3 DLP Projector
Dark haze left side of screen about 4 to 6 inches wide only in the wider screens not in the native
Its a Light Tunnel failure. Go to www.avsforums.com and search for 4805 Light Tunnel. There are instructions to open the PJ and repair the Tunnel. Also, I posted a DIY replacement option in lieu of fixing the very fragile tunnel.
http://www.avsforum.com/avs-vb/showthread.php?t=1304694
Jan 02, 2011 | InFocus ScreenPlay 4805 Multimedia...
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
We have an Infocus X3 projector. It has been
the light tunnel is collapsing and needs to be replaced. contact an infocus authorized service center to either send it in for repair or purchase the part and do it yourself. try av solutions in ny. they're pretty good.
Oct 26, 2009 | InFocus X3 Multimedia Projector
We have an InFocus L120 and the is a vertical line with a band of horizontal lines about three inches in width that flicker from the top to the bottom of the screen.
The connection between the main board and the dmd board might have some dust in the connection. If that doesn't work then your dmd board needs to be repaired or replaced. I do projector repairs if interested my ebay id is gtitubro
Jul 09, 2009 | InFocus Office Equipment & Supplies
Infocus X1A Projector
This is a very common issue with the Infocus projectors. Sounds like the mirror tunnel that sits right behind the Color Wheel and concentrates the light source onto the DLP chip. This tunnel which is shaped like a small prism is very fragile and can "fall apart" over time. Some have attempted to try and remove the tunnel and repair with limited success. Otherwise you may either need to send the unit in for repair or find a dealer who can order the part for you.
Here is another who had the same issue;
http://www.fixya.com/support/t401456-infocus_x3_video_problem
Mar 14, 2008 | InFocus X1 Multimedia Projector
Infocus 70+
We have had similar issue w/ multiple LP70+ projectors. The units get to be 1-2 years old and suddenly the right vertical edge of the display is distorted. There is usually a shadowed vertical bar that clouds about 3-5% of the horizontal space from the right edge.
What's the cause?
Nov 13, 2007 | InFocus LP70+ Multimedia Projector
InFocus Proxima UltraLight X350 Multimedia Projector Logo
422 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
