Question about Lands Phones
Panasonic TVS 50 connected to a KXTA624. I want the tvs50 to answer on the first ring, and when an ext phone does not answer then go to user prompt1 instead of voice mail.
    Master:
  • 623 Answers
Visit site for manual
www.worthingtondistribution.com/solutions/Manuals/Panasonic/TVS50-IM.pdf
Posted on Aug 19, 2008
I have Panasonic KX-T7420s with a TVS50. I have voice mail set up at each extension number. I tried calling from an outside number and transferring to a different extension number to see if I can leave...
Take a look at the manual. One of the bits in programming deals with the status of the FWD/DND button. You can make it light solid for FWD and flash for DND. There are other ways to intercept the calls, but trust me, this is the cleanest. You set 7104 165 # and it will forward always on no answer after x rings. Those rings are set system wide and can be adjusted in programming.
If you sit down wiht the PG manual, pay attentiion to programs 202,203,619 and 990 area 9 bits 3&4. A ring cycle is about 6 seconds and the default intercept is TWELVE rings....you should adjust that to no more that 4.
Car
Dec 27, 2010 | Panasonic KX-T7420 Corded Phone
Answer phone from any extension
Pickup code from any extension. *4001 works if your incoming calls are in ring group 1. *41 ext works if a specific phone is ringing and *42 works if the external pager is ringing.
Carl
Dec 20, 2010 | Panasonic KXDT321 Phone
Answering machine is set to fax only i cannot seem to be able to set up the answering machine to receive messages.
Hello
The fax has a phone port labelled 2-EXT. Connect a phone cable to the 2-EXT port on the end, and then the answering machine on the other end. No setup the answering machine to answer the call after 4 rings, and setup the printer to answer after 6 rings, and make sure Auto Answer is turned ON on the printer.
good luck, and do rate the solution if got help
Dec 08, 2010 | HP Photosmart C7280 Printer
Our office has Panasonic KX-T7433 phones installed, but no one knows if they have a voicemail option, when someone rings the phones just ring out although messages are stored showing the numbers that have...
If nothing answers extension 165 then you probaby don't have voice mail. You can look for something as simple as a TVS-50 or a TVA anything sytsem (US part numbers). Ebay has deals, but check back here before you dive in. You can probably pick up a system for less than $300.
Carl
Oct 14, 2010 | Panasonic KX-T7433B Corded Phone
I need to have our Panasonic KXT7730 to ring at reception but instead one of our lines rings on another phone in another room. How can I change it to ring at reception.
Hello, I presume that you are using this phone on a 308 or 824 system. You will have to check which line is ringing at the other phone. Is it line 1,2 or 3 ? Say for example it is line 2 you need to do the following: From the main phone / switchboard usually ext 101 press PROGRAM * # and your system password ( default is 1234 ). Now enter 408 and press SP-PHONE. The system now asks you to enter the line and in this example we use line 2 - so enter 2. The display now looks like this CO 2:#01: with ENABLE or DISABLE flickering. (CO 2 is the line number. #01 means extension 101, #02 means ext 102 and soforth.) To enable the line to ring at ext 101 choose ENABLE by pressing the AUTO ANS / MUTE button. Now press AUTO DIAL / STORE to save your changes. Now use the right arrow key ( located at the right bottom corner of the phone ) to move to the extension that you don't want to ring - say for example 106. Your diplay should now look like this CO 2:#06 with ENABLE flickering. Now use the AUTO ANS / MUTE button to set it to DISABLE and press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
PLEASE VOTE / RATE MY ANSWER IF THIS WA HELPFUL - THANK YOU.
Feb 08, 2010 | Panasonic KX-T7730 Corded Phone
I have a kxtd824 with a tvs50 voicemail. When in
DIL? It's a term not used in an 824. Incoming ringing is controlled via MC 3.2 or programs 408 and 411 for DAY ringing. Ring delay (411) could alter the ringing even if it's set to ring in 408.
Carl
Dec 07, 2009 | Panasonic Lands Phones
Need to make a new phone ring
Go to GROUP Incoming Call Distribution (probably Group 1 for 300) and add your extension as a member of the group.
Carl
Aug 31, 2009 | Panasonic KX-TDA50 Phone
KX-T7630 - forward to voice mail
Assuming this is a Panasonic system TDA50, TDA or TDE 100/200 or NCP systems. There are many fwd codes on these systems,done on a per phone basis. To do a fwd all calls (meaning the phone will not ring) dial code *7102+9+number+pound. If you would like to set for call fwd no answer then *7104+9+number+pound. And for call fwd busy no anser the code is *7105+9+number+pound. Keep in mind this is on a per phone basis. If your company is using a ring group to ring the phones this will need to be setup different using the day/night mode and set the night to go to a group that is fwd to your answer service. A phone must be assigned to the group then that phone can set group fwd by dialing *7141+group number+9+phone number+pound. Example if I was using group 3, defualt number 603, to number 555-1234 and group 603 has ext. 102 assign to it then from ext. 102 dial *714160395551234#.
Hope this helps!
Jul 27, 2009 | Panasonic KX-T7630 Corded Phone
Panasonic TVS50
sorry...i don't think it's possible,it will only answer on 7th or 8th ring
thank you...
Aug 19, 2008 | Lands Phones
Panasonic KXTA624
Barry Decker,
I have the same system in my home and having problems with my phones as well... Didderent problems but problems... Do you know where you would call to get it serviced??
Thank you,
Brad Wilson
Mar 15, 2007 | Panasonic KX-TA62470-2 (KXTA624702)...
Lands Phones Logo
75 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
