Question about Vitamix Vita-Mix 1364 3-Speed Blender
I have a Vita Mix 3600. I was making a fruit smoothie (banana, blueberry, raspberry), milk, small scoop of protein powder . Speed was on 1. I depressed the lever to reverse. I don't remember if I had released the lever and put it in forward. ? Anyway, it ran only 30 seconds or so and then stopped. No smell. I unplugged and pressed the reset button. Still nothing. I have been using the vita mix 4-5 times per week to make a single smoothie for about 2 weeks (after unit was in storage for quite awhile). First problem I've had with it. Any ideas?
  • 3,053 Answers
Yes that is strange, if you let it cool down and try it again with pushing the re-set button and still does not work, try plugging it into a different outlet. Find something in your place that you know outlet is working, lamp, toaster you know. If does work in another out let, then you of course griped that breaker. Then check your breaker box to see what breaker is tripped, and switch it back on, might just of had a power surge based on putting on reverse. If that don't work, I suppose possibly something in motor or switch went out. Please let me know, if it works, I will take a banana smoothie LOL
Posted on Jun 09, 2011
SOURCE:
Recepies for the cactus smoothie
Ingredients:
  • ½ cup nopal (cactus pads cleaned, spines removed), julienned.
  • 1/2 cucumber, peeled and chopped.
  • 1 lime, juiced.
  • 1 cup water.
  • Crushed ice (optional)
Licuado de Nopal (Cactus Smoothie) - Muy Bueno Cookbook
muybuenocookbook.com/2011/01/licuado-de-nopal-cactus-smoothie/ Recepies for the cactus smoothie Google Search
Nov 29, 2016 | Blenders
When i turn it onto high speed it willl fuse istanlty. (Even with somthing easy to blend like a smoothie) .Any ideas what could be wrong?
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
Mar 31, 2015 | Vitamix 5000 Work Top Blender
Can I upgrade motor on vitamix 4500...it wont make almond butter...
Contact Vitamix, find a service agent through them and have it looked at. You are only going to be able to get your motor (if you need one) through someone associated with Vitamix anyway.
Aug 27, 2012 | Vitamix Turbo Blend 4500 - Heavy Duty Vita...
How to make a smoothie with my bamix handheld blender
That wonderful little stick is all you need, I sure love mine! Make sure your Mixing cup is larger than the one supplied and remember to pump up and down vigorously as you blend. Keep swirling the bottom to make sure everything got picked up and blended. You can also make powdered salt,(great for french fries) powdered sugar, Dried garlic can be made into your own freshest garlic powder (great for spaghetti and pizza). peanut butter, apple butter and Whipped cream. I also use mine to make a crazy Jello only treat that tastes like sherbet, ice cream and Jello just by blending Jello and Ice cubes. Then I chill right away after pouring it into small 3 inch glasses.
Mar 13, 2010 | Bamix Mono Single-Speed Handheld Blender
Cuisinart Quick Prep is not working properly
I think the ice was too hard for a hand blender. I think the impact has caused the blade to separate from the shaft or caused the shaft to separate internally. If your blender is still under warranty you might be able to get it fixed. Note: none of the "Smoothy" recipes in the manual call for ice. One uses ice-cream. One uses "partially thawed frozen strawberries" and one uses sherbet.
Oct 11, 2009 | Cuisinart CSB-33 Quick Prep Handheld...
Vitamix Vita-Mix 1364 3-Speed Blender Logo
1,157 people viewed this question
Top Vitamix Blenders Experts
Marvin
Marvin
Craig Butler
Craig Butler
Andrew Taylor
Andrew Taylor
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
