Horizontal line in the middle of the television
I have a Magnavox 27 inch television set with just a horizontal line in the middle when turned on. The sound and even the channel changer works. I would like to know if this is a costly repair, or is there something that I could do to fix this? 26" Mitsubishi tv - line through middle, channels volume both work. It did have a problem where the top few inches of the picture were flipped. My Mothers 36" Toshiba did this flipping problem 1st but nothing else has happened to hers...yet. BTW her warranty just ran out before this happened to hers.
We are wondering thees problems are similar. I used to design PC Boards and have soldered before, I haven't broken down my set yet but I know to be careful not to come into contact with the tube. Thank you so much.
  • Mitchell Dodge
    Mitchell Dodge Feb 08, 2009
    yea i have the same thing with my 27" Philips TV 2" or more of lines at the top which shows a mirror image and multi coloured lights at the top when turned on how do we fix this...?
    Champion:
  • 230 Answers
Look maybe if you resolder vertical IC you will repair this set ,Or replaced it. But a lot times just need be re solder. Thank you
Posted on Aug 19, 2008
My 27 inch Insignia flat screen tube TV goes blank
The vertical deflection has gone out. Put it in the shop.
Apr 24, 2010 | Insignia NS-27RTV 27" TV
My tv will turn on but with white light line then shut off itself
If the line is horizontal (it is a vertical problem) If its a Vertical line (it a horizontal problem) So it could be just a bad solder joint or a component has failed in the horizontal or vertical section. Hope this is helpful.
Nov 28, 2009 | Philips Magnavox 27MS343S 27" TV
RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Aug 16, 2009 | RCA TruFlat 27F520T 27" TV
Single horizontal line
this problem is field collapse usually causd either by the field oscillator or field output stage to advise you further i would need to look at the circuit diagram
Feb 09, 2009 | Philips Magnavox 27MS343S 27" TV
White horizontal lines in my 27 in Phillips Magnnavox tv
I have seen this on mine. Check the cable going into your TV and make sure it is good. The ground portion of the cable could not be making a good connection.
Jan 17, 2009 | Philips Magnavox 27MS343S 27" TV
Magnavox 27 Inch TV- no picture but has sound
the vert. circuit need to be rebuilted
Aug 04, 2008 | Televison & Video
Hello RENE1223,
Normally this is not a costly repair. This is because it could be the vertical coupling capacitor. However if it is the yoke transformer it could get costly. There is no way for you to repair this problem if you do not have a background in electronics. So I would suggest taking the TV to a repair shop to get an estimate. If the estimate is within the range you are willing to spend let them fix it.
I hope this helps,
thank you,
Shuttle83
Mar 26, 2008 | Televison & Video
Jvc av-29ts2ek
It sounds like a vertical deflection problem. You mentioned you had a white HORIZONTAL LINE in the middle of the screen. If this line runs from left to right across the screen it's in Verticla deflection. If it runs from top to bottom, it's in Horizontal deflection. I am assuming the problem is a Vertical deflaecion problem. The repairs necessary are most likley to replace the vertical capacitors or the verticla deflection chip.
Good Luck
Ed
NC Electronic Mills, Wyo USA
Jan 05, 2008 | JVC TM-2703SU 27" TV
From your description of the problem, there seems to be a Cold solder in the Vertical Oscillator or Deflection Coil circuits.
If you know Solid State electronics, and are good with a soldering Iron, sure u can do this yourself.
U gotta trace the Vertical section components and locate the cold solder. In most cases it will be a loose connector from the Deflection coil to the main PCB.Also check for the soldering of the Vertical output IC.
Oct 19, 2007 | Philips Magnavox 27MS343S 27" TV
Black screen, high pitched squeal
A set that has only a 1/2 inch bright line through the middle of the picture, from left to right, has a vertical output IC that is not working correctly. If the 1/2 inch line is in the middle but going up and down, then the horizontal yoke circuit has stopped working. These are problems which should be looked at by a qualified tech, but if the set was purchased 6 months ago then it should still be under the manufacturer's warranty.
Aug 29, 2007 | Philips Magnavox 20MT4405 20" TV
Televison & Video Logo
192 people viewed this question
Top Televison & Video Experts
