Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
WD320 mybook power supply is lost
I want to buy a transformer locally but don't know what the right output / polarity is. Anyone have one that can read me the specs?
  • jbaker4041 Aug 19, 2008
    Thanks!
  • GraemeSP Dec 29, 2008
    I know the voltage current etc - what I really need to know is the polarity - is the centre pin positive or negative? It's a 50/50 chance of kapowee, Goodnight Sooty.
    Problem Solver:
  • 16 Answers
The transformer I have says:
DC output: 12Vdc == 2A
hopefully that helps...
Posted on Aug 19, 2008
Just bought an aditional DC-supply because I'm miles away from the original.
I can confirme that center pin is positive voltage.
Posted on Mar 17, 2009
  • HardwareHeck Mar 17, 2009
If you believe this, it's centre-positive:
http://support.moonpoint.com/hardware/power/adapters/
Posted on Feb 17, 2009
    Scholar:
  • 94 Answers
Assuming you are in the U.S. you can buy the power supply directly from WD
Here is the link...
http://www.wdc.com/en/products/accessories.asp?ProdID=247
Surprisingly it is not that expensive $9.99 plus P&P
If you are not in the US, you should be able to buy a convertorvto suit your wall socket.
Hope This helps
Please remember to rate.
  • 3 Answers
Try ASIAN POWER DEVICE WA-18G12U
IT FUNCTIONS PROPERLY FOR MY HP 160G B AND MY HP1T
Posted on Feb 20, 2011
Batteries wear out very fast, I need a 6V transformer
You can use any power supply with the following requirments:
output 6vdc, 400ma, plug 5.5mm x 2.1 mm with negative center.
You can buy one from your local market or from this link. In the last case you will get some various connectors and you have to check for the one that is better fixing. Also beware the polarity of this connector, the negative point HAS to feed in the center of the connector.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
May 08, 2011 | Labtec SS-100 Computer Speakers
Buying a used Tascam 788. P.O. lost the power supply. How can I get a replacement? Couldn't find anything on TASCAM site.
Hi, Provided there is a tag on the back showing the units model number, on that same tag should be the power requirements for it-buying a universal power supply, or even a used working one to another piece of equipment is acceptable as long as the polarity is the same. Polarity is located right next to where the power supply plugs into the unit. It will be a " circle with a dash inside it with a line connecting to a C looking symbol with a line coming out of it connecting another circle with a plus sign inside. " that is a typical outer ground/inner positive marking. a power supply will be marked the same. If they match the polarities are the same. Next make sure the power supply says the proper DC voltage and Milliamps or amps-Ma/A example: 2400Ma, 2.4a. I hope this helps and thank you for asking FixYa, good luck and don't forget to write back and let me know how I did, Prodzilla.
Apr 23, 2011 | Record Tools Tascam Dp02 8 Track Digital...
Hello! I have lost the original power supply for my Fanatec Speedster 3 Forceshock steering wheel; I have a universal adapter that should work; however, I don't know what voltage setting to set the...
I have this same wheel. The information off of the power supply: Model: AD-48130850, Input: 120V AC 60Hz 0.3mA., Output: 13V DC 850mA. Hope this helps.
Mar 15, 2011 | Video Game Consoles & Games
Power transformer appears bad. What is the ac voltage out of the transformer?
Check the part number on the transformer: the link at the bottom may help it if it is listed there..The transformer that i had. PN: E190246 Mfr: HF-4822L2TN (single in/output) (ie... two wires in and two wires out)
(Hang Fung Eletronic Ltd.) has a 42.2 vpk >15watts
(power supply for an Emerson 4 in one Entertainment system
(record, CD, cassett, radio)
Emerson Model: NR305TT 19watt
Found info here http://www.olilio.com/file/detail/FQGS2.E190246.html
I hope this helps somebody..
wildhoss109
Jan 15, 2011 | Emerson NR303TT CD Shelf System
Power switch not working
is this a transformer power supply? if so get a volt meter and check output a power supply connector to see if it matches what is on the power supply as output voltage. good luck
May 19, 2010 | Western Digital 250GB MyBook External USB...
I lost my GE Ultrasonic 2.1 Speaker power adapter and i need need ones but i dont know what to buy, the voltage it requires..6 or 9 volts?
at most electrical stores you can buy a universal power adaptors with a selection of socents to fit most connections. and which has a selector on it for various voltages settings.
take one of the little connectors and see which one fits. then checking the polarity on your device set the polarity the same when plugging the connector into the power supply cable. adjust voltage as needed.
Warning: when connecting a variable power adaptor alway connect on the lowest voltage setting and work up as too high voltage can distroy your appliance.
Nov 13, 2009 | GE Ultrasonic 2.1 Speaker
BEFSR41 power supply?
Both the voltage and the polarity should be printed on the case of the router. The polarity should be right next to where the power plugs in.
The polarity information will look something like this:
If you take the router into a local Radio Shack, the clerk will probably be able to tell you which power supply you need.
Jan 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Input voltage ?? lost power supply WHP-150C
the adapter is a thomson output is 19v-200ma--neg polarity
Apr 30, 2008 | RCA WHP150C Consumer Headphones
Visioneer 5800 power supply
My power supply for my Visoneer 5800 appears to just have kicked the bucket... And, I stumbled across your post in a search for a replacement.
Anyhow, here are the specs off mine:
YHI Power Adaptor
Model: YS-1015-U12
Input: 100-120V 60HZ, 0.45A
Output: +12VDC/1.25A
Dec 16, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
6,940 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
