Question about Cuisinart Grind and Brew 10 Cup Coffee Maker
Product is not completely brewing all of the water - it takes 3 times to brew a full pot of coffee. very frustrating.
  • 7 more comments
  • jjemmm Aug 29, 2008
    Coffee maker grinds beans, then brews about 1/3 of the water. I restart
    with no-grind option and another 1/3 brews. The third time seems to
    make a full pot?
  • Anonymous Sep 12, 2008
    About 7 cups of water stays in the Maker reservoir after repushing buttons three to 4 times some will come out but still alot stays in ???
  • groovedog Sep 19, 2008
    i've been through two of these under warrant now with the exact same problem. i've tried cleaning them with vinegar, CLR, you name it, to no avail. how can i fix this?
  • pnwfan Sep 22, 2008
    I'm having exactly the same problem as described above. Must resart brewing process (w/ grind off) 4-5 times in order to brew an entire pot.
  • Anonymous Oct 11, 2008
    We have the same problem. We are on our 3rd Cuisinart Grind & Brew coffeemaker, and each one has done this. It's time to change products!
  • squire4325 Oct 21, 2008
    I have to turn the "grind off" and restatrt the machine 3-4 times to get all the water brewed.
  • Anonymous Oct 24, 2008
    We had the same problem, a whole pot of coffee was not brewing. Tried hitting the 1-4 brew button. Worked for a while. We are on our second Cuisinart Grind and Brew, (first one was replaced, same problem). We were told to clean the machine every now and then. We did run it through with a cleaning product supplied by dealer. Now the machine won't work at all.
  • BSpohn Nov 08, 2008
    My wife says that it seems to work better when full of water, that lends credence to the thermostat issue.
    If I locate which of three thermostats is flaky, A) can I find a replacement part, B) Can I easily replace it?
    I also tried removing the control board and looked for contacts or buttons that were worn out or loose connections, etc. No visible problem found, but I did clean the contact pads for the rotary switches (2 knobs), it seemed to help for a while, then it went back to no completing a brewing cycle without multiple restarts.
    (Nifty, interlocking design to keep water out!
    You'll need a small, stubby shaft Torx screwdriver for 2 of the panel fastening screws under the lid, if you want to try this, but as I said it was not a cure.)
  • Anonymous Mar 23, 2014
    water tank is full and coffee has ground but won't brew
Tried using the 4 cup button with not success. I noticed there were vents on the back of the top lid (for water and grinder), and I had the coffeemaker against a wall and under a cabinet. So far, if I move the pot out and expose the vents before starting it seems to work OK. It's been a week. Thanks for the information about the thermostat.
Posted on Oct 01, 2008
Ok, so this works (for me at least): before brewing, just hit the button to brew 1-4 cups. It'll still brew a whole pot, it'll use all the water, the coffee will taste no different, and you can still program it however you'd like. Cheers!
Posted on Sep 23, 2008
Ok, so this works (for me at least): just hit the button to brew 1-4 cups. It will still brew a whole pot, it'll use all the water and you can still program it just fine. Doesn't change the taste of the coffee at all.
Having the same problem. It's a thermostat issue. The product seems to have three. Trying to figure out which one is causing the problem.
Posted on Aug 22, 2008
My coffee maker takes a long time to brew
Pour 2/3 water and 1/3 white vinegar into it and with the basket empty hit brew. Watch the lime and scale build up come out of it. Initially it will look like small rocks but they will further break down in the pot. Upon completion run 2 additional pots of fresh water through it. If it is still slow repeat the process.
Oct 09, 2017 | Coffee Makers & Espresso Machines
Hello. Bunn coffeemaker VPR Series. When water is poured in coffee starts to make. Carafe gets about 1/3 full and then just drips through filter for about 5 minutes. Never makes full pot.
VPS/VPR are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
BUT there is one main difference! The VPR and similar COMMERCIAL coffee machines are quick brewers. They usually have a pre-heated pot of water stored inside the machine.
* VPR's and similar machines REQUIRE a pre-fill and heating period prior to brewing. This means it's sitting on a level table and filled with water until water sprays from the brew head. At this point the unit is plugged in and the heater is turned on (there may be some water discharge from brew head as the water expands). Ready light will come on in about 15 mins.
* To Brew; Place coffee grounds in filter, place in funnel and brew head, clean empty decanter under funnel, slowly pour one full decanter of water (cold or hot) into brew tray. Do not overflow tray. Allow water level to sink before adding more water. Only fill with one pot as an equal amount will come out the brew head and funnel.
* Make sure the decanters are all the same size. do not mix a 12 cup pot with a 10 cup pot. One will over fill and the other will under fill. Make sure they match (in cup volume) FYI; Thermo Air pump pots are usually bigger than one pot. Typical filling only to 3/4th of the container. (I think most are in 2.5 to 3 liter sizes)
* If your not getting a full pot then the brewer was partially empty. The second brew (if done within the next hour) should come out full.
* If your still not getting a full pot then the water is leaking or is boiling off. Does it always steam from the top? Thermostat is shorted. Unplug the brewer and call vendor for service.
* Final; If your unplugging when not in use. Then follow the Pre-heat instructions mentioned above prior to plugging the brewer back in. If the tank has been emptied at night or dried up after an idle week. Then there is a chance you may over heat and blow the thermal fuse. Or at best have a half pot short brew as the water dried up.
* Note leaving the brewer plugged in without brewing daily is not a good idea. The water evaporates and eventually drys out the pot. Takes about 1-2 weeks but it does blow the fuse(s) and the unit will need service.
* Final; Follow the Bunn set up and care instructions (manuals from Bunn.com for down loading. *FREE*)
Aloha, ukeboy57
Jul 20, 2017 | Bunn Coffee Makers & Espresso Machines
Cant start the coffee
VPS/VPR (VP17-3 are the same except it has 3 lower warmers) are pour over brewers. Like the 12 cup brewers you find at home, they need to be filled with 12 cups of water (a full pot), heated and then peculated over the coffee grounds and collected in a decanter.
Aloha, ukeboy57
Mar 28, 2014 | Bunn VP17-3 Coffee Maker
Doesn't always brew all the water, stops early
All coffee makers do this over time from calcium, lime, and mineral deposits building up inside the tubes and heating coil. Fill the reservoir with a 50/50 mixture of water and white vinegar and run a normal brew cycle, turning it off and on if necessary to completely empty the reservoir. Repeat this 2 or 3 times with fresh mixture of vinegar and water until it brews the reservoir empty without the need to cycle the power. Follow this procedure with plain water 2 or 3 times to clean the vinegar out. This should get it working like new again. It's best to use distilled water for brewing coffee as distilled water does not have the minerals that regular tap water has and therefore will not clog up the machine.
Mar 02, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
The coffe pot will not produce full pot of coffee it only produces 1/3 then stops i cked water supply that is fine when restart it will only produce another small portion so it is three or four times for...
Check programming.This is very simple;turn switch on and hold brew switch until you here 3 clicks to start brew timer .When desired level is reached turn off on/off switch on front panel to set brew time.Check brew level now.
Jan 24, 2011 | Bunn CDBCF 15 APS Coffee Maker
How to clean
mcdevito75 here, Start with a new paper filter or claen the perminant one, you"ll need enough WHITE VINEGAT to fill the pot itself 3/4 full of this WHITE VINEGAR, NOW pour the pot of 3/4 full of WHITE VINEGAR into the resovoir, replace pot in the coffeee maker and cycle thru the vinegar 3 times, each time letting the mavhine cool a bit for easy handleing, on the 3 rd cycle stop 1/2 thru the brew cycle, let machine cool for 30 Minutes, then complete that cycle. Now repeat with fresh water to reove all the vinegar from the machine. Your coffee maker should now be good as new.
Jun 22, 2010 | Cuisinart Brew Central 12-cup Coffee Maker
Not brewing full pots of coffee
Check the in line water fliter. It may need to be changed.
You can try this also.
Put the brew basket in place with no coffee in it, put an empty decanter under the basket. take a full decanter and pour it in the water fill screen at the top of the unit. When the wtaer stops dripping and the unit is back up to temp, try a full brew cycle.
If it works OK, it just got low on water in the tank
Could be caused by a plugged up filter or lime scale build up.
Dec 28, 2009 | Bloomfield 8572 Coffee Maker
Brewing time is too long 20 min for 6cups
You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
GE 169164 Coffee Pot Not Brewing
Loosen the charcoal filter. You only need to GENTLY place it in. Your problems will all be solved. I just did it 5 minutes ago and i just brewed a 6 cup pot of coffee completely.
Jan 07, 2009 | GE 106591 Coffee Maker
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart Grind and Brew 10 Cup Coffee Maker Logo
545 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
