Question about Home Security
Pm 909 Thanks for the advise, I know that my B+ is low but am having difficulties in finding the cause. I cannot adjust to the correct 11 volts I have go so far as to swap components from another known good monitor Flyback swapped CRT and Yoke swapped ALL electrolytics Replaced All coils (chokes) swapped All transistors swapped Power Supply swapped via jumper wires (The supply from the "bad" monitor powered the "good" monitor properly) I think I'm down to Ceramic/mica caps and resistors and ther's a mess of them little buggers I'm at my witt's end Thanks again fo rthe help
  • 258 Answers
Those mica and ceramics don't usually go bad.
if the B+ is low, then keep looking there. It may be in the bias voltage of the regulator? If I had a schematic and some voltages from tests, I might be able to pinpoint it.
Posted on Aug 19, 2008
Samsung Galaxy S4-Alarm Problem
Go to your alarm settings and make sure that the Smart Alarm is off, I know that the smart alarm makes the alarm go off early, this could be possibly be the problem.
May 23, 2013 | Samsung GALAXY S4
Orbit 57515 water goes off and on off andon
Troubleshoot p 16
Have you changed CR2032 battery in front top right compartment?
Is this new or old installation?
Reset timer to clear old memories.
Reprogram and be careful with overlaps and conflicts that cause timer to operated differently than expected. Watch out for am pm. Use 11:59 instead of 12:00 to avoid am pm confusion.
Each ON time need OFF time.
Are there fluorescent lights on same breaker circuit.
Is power at least 80% rated voltage
Does power have correct polarity.
Unit has 6 year limited warranty against defects in workmanship
Return to dealer with receipt.
Or buy new timer and return defect with new receipt if purchased at local box store. Use My Lowes card if purchased at Lowes.
Mar 28, 2013 | Hardware & Accessories
Voltage flexuates from14volts to 11volts when 2003 tahoe is in drive and brake is apply at stop sign and also when idling
Check that the idle speed is not too low in drive . Should be around 900 rpm in neutral and the idle speed is adjuste in drive to no less than 750 rpm. IT takes rpm for the alternator to charge the battery so if you have 11 volts then the car is runnung off the battery and not the alternator. It needs 13.5 volts to charge a battery and most regultors are set at 14 vvolt to 15.5 volts. If the vehicle is runnung from the battery as I stated then items like blinkers and stop light operation will show as fluctuations on the gauge. Have the system check . Make sure the drive belt to the aklternator is correctly adjusted as a slipping belt will also cause a problem.
Feb 06, 2013 | Cars & Trucks
Hello! well i have only one question: how can i do for set the time on it
You can Set the Clock in this way:
1. Press the HOUR button until you reach the correct hour.
2. Press the MIN button until you reach the correct minute.
3. Press the HI/LOW button to choose between high and low clock brightness.
Note: An LED light (PM indicator) will appear in the upper left hand corner of the clock face during the PM hours. Be sure to set the time for the correct 12-hour period - AM (morning) or PM (evening).
I hope I helped.
Sep 16, 2011 | Homedics SS-4000 Clock Radio
Djm-909 DJ Performance Mixer with Effects System: Ch1 is really low and ch2 is really high with grou...
Unusual fault on a 909, they are usually pretty reliable.
I'd 1st check if it is correctly wired - i.e CD into "line" level input and not "phono" or vise versa.
May 06, 2010 | Pioneer Djm-909 DJ Performance Mixer with...
11 blinks onSony KV24LS35U
According to the LED error code (11 times blinking) the problem is in "Jungle controller 8 volts" which are not being produce, this kind of fault bit technically difficult to and i suggest you to contact any expert to find the cause of not producing 8 volts supply,
Hope you will understand my sayings,
Thanks for using fixya.
Jul 25, 2009 | Sony Televison & Video
Ikegami pm 909 shrinking picture
The deflection current is dropping in both vertical and horizontal. This suggests a low B+.This can also be caused by a flyback problem. Check all the Caps in the HV section. If not, it's the flyback.
Aug 13, 2008 | Home Security
Zen Microphoto MTP drivers not installing, stuck in loop
Make sure you have media player 11
If you can, the best test is to try your player with another PC, to see if you still have the problem. This localises whether the problem is with the PC (most likely the USB) or the player. See the link below (search on "connection problems") for a lot more troubleshooting on this.
Download recovery tool off creative's website.
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Jan 12, 2008 | Creative Labs Zen Micro MP3 Player
Home Security Logo
115 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
