Question about Mitsubishi WS-55511 55" Rear Projection Television
Ws-55511 no power
No power. no response from remote or front panel. no flashing light. power is good. service tech said it was the "brain board". quoted 820.00
  • volkl184 Sep 17, 2008
    My set was working fine till I disconnected it to move it across the room. Plugged it in and no power to set. No lights, nothing.
    Reset button no help. Ideas?
  • 927 Answers
Good Day;
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. OR your TV has "COOLANT" (ethylene glycol) on the circuit boards. This fluid comes from the CRT's (picture tube) this fluid is used to keep the CRT's cool, such the name. This fluid from the CRT's leak when TV is on for long periods of time, the chamber expands and the seals leak.
One can remove this fluid by using "acetone" & small brush. The fluid is hard to see, use bright light, they spots can be smaller then a DIME. Also, the fluid can corrode the parts and traces on the boards. To protect the TV in future place heavy plastic or thick cardboard over affective area, make sure TV has proper air flow around TV. Good Luck, big IRISH.
Posted on Oct 01, 2008
Bypass Mitsubishi HDTV Lock
Bypass Mitsubishi HDTV Front Button Lock
Models: WS-B55 / WS-48511 / WS-55511 / WS-55711 / WS-65511
Models: WS-65611 / WS-65711 / WS-65712 / WS-73711
Would you like to bypass, defeat or reset your Mitsubishi HDTV Front Button lock?
If you have misplaced your remote control, and have engaged the Mitsubishi HDTV Front Button Lock, you can bypass the front button lock by pressing and holding the MENU button on the front panel for more than 8 seconds.
I hope that helps.
Reset Mitsubishi HDTV VChip Password
Mitsubishi Projection HDTV Manual Download
on Apr 30, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I have a mitsubishi ws-55511 had power failure blinking light asked expert was told to un hook front control box which left tv working with remote control functions only. now we had a fower failure &...
I am the one here who first posted about taking the front keyboard out; if you replaced the caps in the DM unit and or pico fuses and still have the 'blinking green light of death" consider sending the board unit to PTS electronics.
You can get a quote from them for the repair and they have a 800 number; if you tried the usual things and it does not work go that way. Even with the factory service manual and schematics you will find it nearly impossible with the Unit in the set to take voltages and troubleshoot it.
DM unit in correctly working set should cause set to have blinking power light for about 70 seconds and then go out--it is DM booting up---if it does not stop blinking either a problem with DM or connections where it plugs into main board.
Let me know if you have questions or need help, I am here to help
Oct 14, 2011 | Mitsubishi WS-55511 55" Rear Projection...
The green light on the front panel is flashing but
Try website to buy a refurbish DM power board for the replacement.U know soldreing?Buy capacitors for the replament.
May 14, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 not responding to remote or front panel. Tried System Reset Button several times. No luck.
Sometimes the control panel switches on the front of the set go bad.
Try running your fingers across the buttons to see if it helps.
I ended up disconneting the front panel switch board and just use the remote now.
Oct 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Got a Mitsubishi ws-55511 as a freebie a few weeks ago. Once plugged in it does nothing but flash the power light. Prior owner removed access panel but went no further. I am an audio engineer with lots of...
Thats an easy fix. The capacitors on the DM are known to fail . You can get the WS48511 - WS65511 DM repair kit at the following link which contains the replacement capacitors and the instructions on how to do the repair on CD which also contains the Service Manual
Jun 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Your Solution to the WS-55511
There are 2. One controls the front panel and the other controls the front output. Unplugging it will not interfere with the remote. In fact, you will only be able to operate the tv with the remote. Let me know how you make out. Incidentally, I sent an email off to Mitsubishi and surprisingly they got back to me in a day. I informed them about the problem all these people are having and they are actually looking into it. They even offered to pay for my new front panel. Go figure!!
Nov 06, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 Problem TV out - Getting only continously blinking green light on the front-panel
I had the same problem with the blinking light on the front of the TV and it would not power up. I read all the problems everyone was having and thought I was going to face a huge repair bill. The service guy came out, pulled off the front panel where the speakers are and disconnected the circuit for the front display panel. 3 1/2 minutes in my house, $90 service call. Apparently, when you give the TV too many commands at once, it's safety feature is to"shut down and lock up". He mentioned also that sometimes when these sets get to be about 4-5 years old, the wires in front can "leak" causing a shortage and then locking up the TV. I keep the circuit unplugged and operate the TV solely by the remote. Give it a try, what can it hurt!! Hope this helps.
Oct 05, 2008 | Mitsubishi WS-55511 55" Rear Projection...
WS-B55 - Remote doesn't respond, front panel partial response
Genius!! Thanks! I took a dry cotton towl and ran it across the keys on my front panel and whatever was stuck, became unstuck..The internet just saved me $150.
Jun 15, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Will not power on. Please Help!!
Error code 12 means normal operation. On these models we have found that a switch is sticking on the control panel not allowing the set to turn on. Disconnect the control panel. You will be able to use the remote on it. To find the plugs for the control panel: Remove the speaker grill and front panel, then follow the wire to the connection. Remember to unplug the set before putting your hands inside of it. Tell me how it went. Lead Tech
Dec 14, 2006 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
135 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
