Question about Curtis DVD6041 System
Dvd6041 theatre system remote
Remote not working ,i think i have to reprograming
Remote not working
i want to buy a remote control for sony dvd home theatre system dav-fxg9k, where i can get it?
Jan 11, 2014 | Sony SS-FXG9K Multi-System Region Free DVD...
Control Curtis dvd6041 with dish-network remote 5.0 IR
Hey there, Cheri Torres with DISH Network Customer Service here. I came across your post and wanted to see if I could help. We have a few different codes for each of our different models of remotes. I will list here for you the best codes for our more popular models of remotes and the instructions for addressing the remote to your DVD player. I hope you find this information useful but if it does not work or you have any further questions please let me know I would be happy to help further.
Remote model #'s Remote codes
3.0, 3.1, 3.2, 3.4 IR remotes - codes 1594, 1605, 1607, 1675, 1554, 1592, 1677.
5.0, 5.2, 5.3, 5.4 IR remotes - codes 1594, 1684, 1554, 1605, 1607, 1592, 1678.
4.0 and 4.4 IR/UHF remotes - codes 1684, 1554, 1594, 1605, 1607, 1592.
6.0, 6.2, 6.3, 6.4 IR/UHF remotes - codes 1592, 1594, 1605, 1607, 1554, 1683, 1675.
20.0 IR and 21.0 IR/UHF remotes - codes 1585, 1554, 1592, 1594, 1685.
Instructions for addressing the remote to the DVD player
  1. Press and hold the AUX mode button until all mode button back lights come on, then release.
  2. Use the number buttons to enter the device code corresponding to the equipment.
    Note: The light will blink off after each digit is entered and then return to a steady light.
  3. Press the POUND (#) button.
    If the code entered is valid for the remote, the mode light flashes three times.
Oct 10, 2011 | Curtis DVD6041 System
I have lost the remote control for the system. .
here is a link you could buy replacement orignal from http://www.remotes.com/store/curtis_international/dvd6041.html or you can buy universal just make sure iy has curtis dvd player codes on back it should have curtis name with many others to let you know it is capable of programing device
Aug 27, 2010 | Curtis DVD6041 System
The home theater system wont read my disc:(
Well from what I have found in trying to get this problem figured out is that it is a common problem with Curtis Home Theatre Systems; not just your model 6041. Here is a POSSIBLE solution:
Q: The screen is blank!
To reset the video output on your DVD, follow these instruction. Connect to standard composite connection (yellow video input on TV and yellow video output on DVD). Remove any DVD's from the unit. Turn the unit off, wait 10 seconds and then turn it on again. Using the remote, press SETUP, then RIGHT ARROW button 4 times. Press Enter. Then DOWN ARROW button 3 times. Press Enter.
That is for your 6041. For what I have discovered elsewhere it may or may Not cure the problem. Give it a try and let me know one way or the other.
Oh, here is a link to the Curtis website Support area: http://www.curtisint.com/support/support.asp?brand=CURTIS .
Nov 29, 2009 | Curtis DVD6041 System
5.1 CH HOME THEATRE SYSTEM I DO NOT HAVE THE DIRECTIONS FOR HOOK UP
Manual available here
http://www.curtisint.com/web/browser.asp?productID=DVD6041&catName=&brand=CURTIS&manual=DVD6041
Aug 02, 2009 | Curtis DVD6041 System
No picture
Try changing the settings back to factory default. Both of my surround speakers stopped working, and doing this brought them back. If your remote functions properly, it can be done by hitting this exact sequence when in the DVD mode:
Setup>Right Arrow>Right Arrow>Right Arrow>Right Arrow>Enter>Down Arrow>Down Arrow>Enter
Note: The Arrow buttons are the ones that surround the Enter button.
This is a very poorly designed system, and the remote will not work from slight angles. You must be directly in front of the unit for the best signal reception from the remote.
Aug 23, 2008 | Curtis DVD6041 System
Remote Code for HDX500/I
Get a Logitech Harmony 880 universal remote. I have it operating my home theatre, TV, iPod and cable just fine - all with one remote.
Nov 19, 2007 | Sony DAV-HDX500 System
Curtis DVD6041 System Logo
90 people viewed this question
Top Curtis Audio Players & Recorders Experts
Damen Wong
Damen Wong
Ekse
Joaquim Martins
Are you a Curtis Audio Player and Recorder Expert? Answer questions, earn points and help others
