Question about Panasonic KX-TG5632 Phone
How to use intercom between two handsets
How do I use the intercom between two handsets?
  • Anonymous Apr 01, 2014
    When i lift the handset the intercom light comes on - How do you cancel this - is this a way for someone else to eavesdrop into a private conversation - how do you know who! is lestening
  • 79 Answers
For models with 2 or more
handsets included
Making an intercom call
1 Press {INTERCOM}
2 To page the base unit, press {0}.
To page another handset, enter its
extension number ({1} – {4}).
The destination unit beeps for up to 1
minute. Someone else can answer the other unit and talk to you.
3 To end the intercom call, press {OFF}.
Posted on Aug 24, 2008
SOURCE:
How do I call a twin binatone cordless in another room
  • 1. In standby mode, press (intercom).
    • • Intercom is established immediately if there are only 2 registered handsets.
    • • If there are more than 2 registered handsets, the handset numbers which are available for intercom will be displayed.
  • 2. Press the handset number you wish to call or press * to call all handsets.
  • 3. Press (Talk) on a called handset to answer the internal call, where both internal callers can talk.
  • 4. To end the intercom call, press (End/off) on either handset.
Nov 27, 2015 | Binatone Lands Phones
How does one use the intercom
To Page another phone to initiate intercom:-
From the base station - press Find hs/Intercom.
From a handset - Press Intercom/clear.
Then select the station you want to talk with or All to
page all stations at the same time.
To answer a page:-
From the base station - press Find hs /Intercom or Speaker.
From a handset - press Intercom/clear or Talk/Flash.
Hope this helps
Ive also included a link to the D1785 Series User's Guide
http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/D1785om.pdf
Feb 01, 2014 | Uniden D1785-3t Dect 6.0 Cordless Phone...
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
Intercom does not work
There needs to be an additional instruction. I am having the same problem. From standby mode, I press Intercom, the screen says "Please wait" for 2-3 seconds, then I choose a handset. Nothing happens. The user guide doesn't have any additional instructions after this point. I don't hear any paging or anything other than silence on any handset.
Jun 15, 2011 | Uniden D16602 Twin Cordless Phone
Can not rec a dial tone, phone states no link to base move closer
If “No link to base. Move closer to base, try again.” is displayed
even when using the handset near the base unit, the handset may have lost communication with the base unit. You need to re-register the handset to the base unit.
• Make sure the base unit is not being used.
• Have both handsets and base unit nearby during registration.
• Follow steps 1–3 listed below. You have about 1 minute to complete them.
• Confirm the extension number of the handset which has lost the communication by placing the handset on the base unit or charger.
If you re-register the handset using the other handset’s extension number, the other handset will not function.
• If the handset beeps 3 times and “Error!!” is displayed, an error occurred. Try again from step 1.
• You can stop registration by pressing [OFF] on the handset, and pressing [LOCATOR/INTERCOM] on the base unit.
1 Base unit: Press and hold [LOCATOR/INTERCOM] until a beep sounds.
• The CHARGE indicator flashes.
2 Base unit: Press the extension number [1] (handset symbol 1 ) or [2] (handset symbol 2) of the
handset which has lost the communication.
3 Handset: Press and hold [FLASH/CALL WAIT] until “Handset Registering” is displayed.
• When registration is complete, a beep sounds from the handset and the display shows the number.
• Wait for 20 seconds after registration is complete while the handset establishes communication with the base unit.
Feb 23, 2010 | Panasonic KX-TG2357 Cordless Phone
How do I make internal calls to another Panasonic KG-TGA711E handset in the house?
1 Press {INTERCOM}
2 Select the handset you want to page
by pressing the desired handset
number ({1} – {6}).
To stop paging, press {OFF}.
3 When you finish talking, press
{OFF}.
Answering an intercom call
1 Press {handset icon} or {speaker icon} to answer the
page.
2 When you finish talking, press
{OFF}.
Note:
When the ringer volume is set to off,
the handset rings at the low level for
the intercom calls.
Feb 20, 2010 | Panasonic (KX-TG1032S) Phone
How do i use the intercom on my Uniden dect. 6.0?
March 25, 2013 - INTERCOM INSTRUCTIONS
Here is the answer! Press the INTERCOM button one time.
The INTERCOM display will show on the screen.
Use the UP or DOWN arrow button to select the HANDSET number.
Press the MENU/SELECT button to ring the HANDSET selected.
Press the END button when done talking
Sep 01, 2009 | Uniden DECT 6.0 Cordless Telephone...
RED INDICATOR LIGHTS FLASING ON INTERCOM
Thats a common "problem", but its easy to fix. The Intercom lights flashing like that is normal and they will continue to do so until you "assign" the phone its intercom number.  If you have more than one of these phones, go to your other phones, lift the handset and see what intercom number lights on that phone when you do so(the lights/buttons that are flashing). Notate which intercom number that is and move to the next phone. Once you have notated the other intercom numbers go back to the phone you wish to program and push PROGRAM , then push the touch tone key of which intercom number you wish to assign the phone (ie. 1 2 3, etc.), then push MEMORY.  That should do it, and if you need replacements their on Amazon. Good Luck
May 22, 2008 | Dual Handset Cordless Telephone with...
Intercom Question
k whats the question
basics the intercom is switch one unit to another unit so you dont have to get up and also when not in calls the intercom lets you speak to someone else example= hubby in garage and has a handset and your in the kitchen pick up handset hit intercom it rings to hubby and u tell him dinners ready or something like that its really a fun gadget to use :D
Apr 14, 2008 | Uniden Cordless Phone
Panasonic KX-TGA400B De-register handset
You do not need to power up the handset to delete the old intercom number, you do this on your base station. At your base push Function, then scroll up to Registration, push Enter, scroll to de-registration, push enter, scroll to the right and highlight that intercom number that you wish to delete, push Enter then Clear. If your not sure which intercom number it was, take a piece of paper and a pen and look at each functional handset you have, and notate the intercom number which is in the upper right hand corner. You can send your dead handset in for repair to have a backup, so don't toss it.
Mar 17, 2008 | Panasonic KX TGA400B Cordless Expansion...
Panasonic KX-TG5632 Phone Logo
3,051 people viewed this question
Top Panasonic Lands Phones Experts
Ekse
martin hogg
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
