Question about Sanyo DS31520 31" TV
Dead, no power indications at all
I am a Tech. No schematic for this TV. Fuse is OK all high power Semi's seem to be not shorted. Will not turn on.
  • jplandry Aug 28, 2008
    The problem was the error amp, Q 605. I had two instances of this. I replaced it with a 1 amp PNP 100 MHZ device and it works fine...even at high ambient temperatures...which is the cause of this failure. It is a design problem in my opinion because this part is directly driving Q604. I measured the nominal Collector to Base (of 604) current to be higher than the devices spec. It is just a cheap **** 3906-like part.
    I hope this helps others.
  • Anonymous Sep 15, 2008
    tv. sanyo mod.ds19380 not channel
  • 85 Answers
Hi there.there are two 150k resistors in series on the psu,which tend to go open circuit.if this is the case,watch for the main cap as it can bite.switch set on and off,then check for 300 plus volts accross it five mins after switch off.if thats thecase,its those resistors.hope this helps.seve
Posted on Aug 28, 2008
I have a jbl 515 eon no power every thing is dead the fuse is ok
If you can watch the fuse kind of twitch. Most likely you have somthing shorted in your output amps. ( the ones on the heatsink underneath PCB) you'll probolly need a tech for this one to change out the transistors. Still under warranty?
Aug 26, 2011 | JBL EON 515 Speaker System
Schematics for fuses 52hm95 tv. 2a250v fuse may
hello the fuse would be located in the power supply, if the fuse is black it's blown if you put another 1 in and it blows again you have dead short somewhare make sure the powers off and the same rated fuse, ps there may 2 fuses
shaun
Nov 17, 2009 | Toshiba 52HM95 52" HDTV Projection...
35" RCA 35" Entertainment Series - PIP
ok is the set completlely dead. DOEs the Led on the front flash. if it does not flash this is an indication of a primary power interuption. POSSIbley main fuse. Now generally the main fuse does not blow unless there something else wrong. some other component shorted. Now if the light flashes then this is an indication that the main fuse is still good and that the processor is getting power and that it has detected a condition that requires it to shut down. ussaly a high voltage issue
Dec 11, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RT-49NZ21RB
hi my lg projection tv model RT-49NZ21RB suddenly went dead while we are using it. The fuse seems to be OK and whenever I turned on the tv, there was a short high pitch noise but no audio/ video. I am not familiar with the projection TV, would it be the lamps but my best guess is it is not the lamps because there are three of them. Please help. Thanks.
Apr 21, 2008 | Televison & Video
Panasonic CT-32HX42F Powers down by itself
it is due to plug or socket loose or sparking in that area. if it is ok then it is due to some component failure in power supply of tv. as per schematic is concern please go to. www.serviceinfo.com go in search & give model no.it is freely available.
Oct 04, 2007 | Televison & Video
1993 Sony Trinitron 27"
as set is dead the problem is in power supply or horizontal section. though it is a simple &less time taking. but if you have no TV repair experience, or any experience tracing circuit flow with a schematic, call in a tech to assist you with this repair. This tv set is not the place to be experiementing inside of. You probably have bad capacitors and transistors in the power supply or the sweep power supply. Good Luck
Sep 30, 2007 | Televison & Video
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
TV WON'T COME ON
If the fuses are good and the on indicator lights you could have a short in the power supply, the high voltage section or just about any part of the circuitry. The most common problem is the high voltage. If you know TV safety and how to check transistors, unplug the unit and check the horizontal output transistor. If it is shorted replace the transistor, flyback and HV divider. If this does not solve the problem you will probably need a repair tech as this symptom could be a short anywhere in the unit. Good luck and remember to be safe.
Jun 30, 2006 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sanyo DS31520 31" TV Logo
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
